16,000 watt system build
Discussion in 'Other Toyota Vehicles' started by Bgsxrunner, Jun 12, 2019.
  1. Jun 12, 2019 at 2:40 PM
    Bgsxrunner
    Bgsxrunner [OP] New Member
    New Mexico
    2012 Black Toyota Tundra Crewmax Platinum 5.7 4WD
    Pretty much everything
    So there will be a lot of pics attached to this one...and I’m just gonna supply basic specs unless otherwise requested.
    The original setup
    I had an 07 4Runner that originally had two pioneer 1400 watt 12” subs.
    That lasted about 6 months then I upgraded to that plus 4 pioneer 2000 watt 12 subsFF911434-FF39-47A8-B255-3BB6509DA808.jpg
    I was also running 3 amps with it seen below DD35156E-4B0B-409D-AA72-E0B12DAA65A7.jpgThis ends up totaled in a front end collision with a Tahoe that dashcam captures. In the end it was a 10,800 watt system running on factory alternator and an optima 35 yellow top
    So the we move on to the Tundra. I originally had a little kicker piece of shit that looked like two speakers but it was actually a speaker and a weight? I don’t know that shit confuses me. It worked okay for what it was but nothing compared to what I was use to. 8749BF8E-0256-418B-BC98-BAA519CE85E5.jpg
    So that last a week then I move on to two jl 13” 1200 watt slim series (unfortunately unable to find a pic on those) and for about a year that worked because I was focused on everything else. Then I got around some wood working equipment and decided it was time to upgrade. I started thinking about it and I wanted everything. I wanted to do 2 sealed, 4 ported and 4 band pass for a total of 16,000 watts.
    The pics are few and far between but in order to get 4 flat with the two on the sides we had to stager themCC251280-D0A1-49AE-BC03-4ABC50C546B9.jpgWhen we had the bottom and the sides done we started on the band pass that would mount on the back 548EEB44-512C-4B35-BACE-56720C5C156D.jpgThose boxes were quite a pain to build. I had done quite a bit of research on those and found they literally have to be built to spec which is exactly what we did F4A2E725-8082-4284-B5D1-81BAC0C68D47.jpgLooked good sounded great. Literally rattles building. But with the amount of space the band pass took up and it not seeming that much louder whether they were on or off I decided to switch it up1717DB7F-487F-4005-8624-5DE17CD8743B.jpg
    We did four flat across the back and we had to mount it slightly back from the rest of the setup even though I would have rather it been flush.124947B9-2B4B-4209-9714-86663A3729B9.jpgPart of the speakers are hidden by the other boxes but the cone area is not 28876512-0946-4FE0-BF0D-C1AE809917B6.jpgOnce the carpet was in you could barely tell
    This setup requires 4 amps, two optima blue top 31s one under hood one in bed, one capacitor and the factory alternator
  2. Jun 12, 2019 at 3:17 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
  3. Jun 12, 2019 at 3:21 PM
    NE_WARRIOR
    NE_WARRIOR [HOONIGAN] Wannabe
    Union, ME
    08 DC SR5
    giving me a reason to get a hard top shell. damn that's impressive :thumbsup:
    Mountun Goat and Bgsxrunner[OP] like this.
  4. Jun 12, 2019 at 3:25 PM
    Bgsxrunner
    New Mexico
    It was a hell of a lot of work but well worth it
    Black@Blue19 likes this.
  5. Jun 12, 2019 at 3:28 PM
    NE_WARRIOR
    Union, ME
    08 DC SR5
    what shell do you have on? is the box enclosed to keep water out in some way or does the shell have weather stripping attaching it to the roof of the truck
  6. Jun 12, 2019 at 3:29 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    By the Beard Of Zeus !
  7. Jun 12, 2019 at 3:30 PM
    Bgsxrunner
    New Mexico
    Its the leer 105? Model? I think it’s got the power lock on the window. And if you look at the second to last bottom you can see the weather strip between the back window and camper
  8. Jun 12, 2019 at 3:30 PM
    SpacecoastHusker
    SpacecoastHusker New Member
    Brevard County, FL
    2014 Toyota Tundra Limited CM
    My neighbors get pissed with my 1,000 system. I think I might get arrested with this system. Impressive.
    Bgsxrunner[OP] likes this.
  9. Jun 12, 2019 at 3:34 PM
    Bgsxrunner
    New Mexico
    Surprisingly I have yet to be pulled over for it. I’ve had it full blast with them right behind me, nothing. They don’t even flash the lights to warn me. Of course the list of illegal mods on my truck is rather extensive
    Tundyfundy and htw_hawaii like this.
  10. Jun 12, 2019 at 3:44 PM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I think you need more bass.
    But seriously, you're going to rattle your kid's teeth out. I guess that's one way to remove baby teeth or ear drums.
    Bgsxrunner[OP] and Trooper2 like this.
  11. Jun 12, 2019 at 3:45 PM
    Bgsxrunner
    New Mexico
    Na I’ve got bass control knobs so it can be reasonable with children or parents
  12. Jun 12, 2019 at 4:35 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I put a duel 10" in my truck and the 26 year old friend loves it.
    She has been in there for three days now
    I should bring her more water.
  13. Jun 12, 2019 at 7:07 PM
    Toyotasonly314
    Toyotasonly314 New Member
    Bet your kids def now.
  14. Jun 12, 2019 at 7:08 PM
    Bgsxrunner
    New Mexico
    ....no I’ve got bass knobs....
  15. Jun 12, 2019 at 8:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    we're the jl's the 13tw5's?
    I've got the stealthbox with 10s but would be awesome to upgrade to those 13s.
  16. Jun 12, 2019 at 8:55 PM
    Bgsxrunner
    New Mexico
    I think they are t7 but I may be wrong you may be spot on
  17. Jun 12, 2019 at 9:15 PM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    Are you sure 16k Watts is enough?
    Black@Blue19 and Bgsxrunner[OP] like this.
  18. Jun 12, 2019 at 9:25 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I love seeing extreme systems, especially pics of different stages and their pros and cons. There's also the ridiculous amount of time it takes to get what you're looking a for. It is also a shitload of fun to crank "the knobs" up! Thanks for sharing.
  19. Jun 12, 2019 at 9:44 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Jesus!!! Did you regear your truck and add a super charger to be able to haul around all that weight!
    That’s an impressive setup!
    I used to do comp sound systems 20 years ago boy tech sure has changed
  20. Jun 12, 2019 at 9:58 PM
    Bgsxrunner
    New Mexico
    That’s what I wanted was something extreme, something no ones ever seen before. I think I achieved it
  21. Jun 12, 2019 at 9:58 PM
    Bgsxrunner
    New Mexico
    Honestly even with the 37 I don’t think I need to regear yet
  22. Jun 12, 2019 at 10:06 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    That’s unreal!
  23. Jun 12, 2019 at 10:41 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I was just kidding I ran 37’s w stock 4.30 gears for 2 years
  24. Jun 12, 2019 at 11:25 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Speak up.
    papasmurf likes this.
  25. Jun 12, 2019 at 11:29 PM
    Bgsxrunner
    New Mexico
    I’m sure it would help with towing but I don’t tow often enough for it to matter
    papasmurf[QUOTED] likes this.
  26. Jun 13, 2019 at 9:47 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    You sure did!
  27. Jul 27, 2019 at 10:05 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
  28. Jul 27, 2019 at 1:27 PM
    gdisarray
    gdisarray Short term member
    MGM SR5 TSS
    Get used to saying "Huh?" when you get older! LOL. First hand knowledge here? Huh? You say something? Lol
  29. Jul 27, 2019 at 1:51 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    Would love to hear it in person with some Motley Crue playin!!!!:) Gotta have more COW BELL!!!!!:)
  30. Jul 28, 2019 at 4:26 PM
    Bgsxrunner
    New Mexico
    Honestly I was never a fan of pioneer but I got two for a decent price and for the price they are actually a rather good sub. I plan on getting two slims to replaces the jls then swap all the amps out for pioneer then the factory stuff. I always wanted an lms 18 from tc sounds but it’s just not in the budget.
