Coachbuilder vs Toytec Shackles
Discussion in 'Suspension' started by zcarpenter92, Oct 13, 2016.
  1. Jun 10, 2019 at 6:28 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ll throw a bone in and say look into
    Pro form fab shackles super heavy duty I’d say a step above ToyTec and they are only $60.
    I put the 2” ones on my truck and I don’t
    Think you can beat them
    Big J and monaco730 like this.
  2. Jun 10, 2019 at 6:29 AM
    xtyfighterx
    Ty
    North Idaho
  3. Jun 10, 2019 at 8:06 AM
    ab1653
    ab1653 Ew member
    2014 Tundra
    This is the route I’m going and bought mine directly through pro form fab $10 less, but I also went with the 1.5”. I haven’t installed them but for only $50... I don’t think you can beat that price. Worth looking into.
    https://www.proformfabrication.com/...018-toyota-tundra-1-5-rear-lift-shackle-kit-1
  4. Jun 10, 2019 at 8:10 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    xtyfighterx likes this.
  5. Jun 10, 2019 at 9:01 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Another vote for @Coachbuilder1 +2s.
    You really can’t go wrong with either Toytec or Coachbuilder. Do you want adjustable, think your heights needs may change in the near future? Get Toytec. Are you set on knowing what height you need? Coachbuilder is a great option. I bought mine during the group buy which helped my decision. Another positive, both companies have great customer service and are highly regarded around here. I honestly don’t think there is a “right” decision, just personal preference. DO make sure that you swap for the poly bushings either way though.
  6. Jun 10, 2019 at 9:12 AM
    Aurora CO
    I prefer the adjustability of the quite beefy ToyTec shackles and the anodized finish although the CB's are very good and also worth the $. See early post pics of the two. Lots of cheaper shackles out there but you get what you pay for. Rust would be my concern with non anodized steel shackles. CB's are aluminum so rust a non issue there.
    Coachbuilder1 likes this.
  7. Jun 10, 2019 at 9:23 AM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Did you use the factory bushings and hardware? if not what did you use.
  8. Jun 10, 2019 at 9:59 AM
    xtyfighterx
    Ty
    North Idaho
    Just went to the hardware store and got grade 8 hardware was like $15. And I had to go with poly bushings. My stock shackles
    The studs were seized inside the stock bushing/sleeves
    I think I have the size hardware written down somewhere if you need it
    Big J and Black Wolf like this.
  9. Jul 19, 2019 at 3:12 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Yes any info in the bushings or a link to get them would be great.
    Any idea what the size was for the bolts? (Might save taking one off and going to hardware store with it) lo .
  10. Jul 19, 2019 at 4:16 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
  11. Jul 19, 2019 at 4:17 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Do they have zerks for greasing them after installation?
  12. Jul 19, 2019 at 4:23 PM
    Coachbuilder1
    Salt Lake City UT
    The bushings? no... we tested different compounds and finalized on a black poly compound with added graphite. they lube themselves and won't require any maintenance after installing.
    Black Wolf and Yzed608[QUOTED] like this.
  13. Jul 19, 2019 at 4:25 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
  14. Jul 19, 2019 at 4:48 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Cool, thanks for the info.
  15. Aug 23, 2019 at 8:01 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
  16. Aug 23, 2019 at 8:15 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Energy suspension claims to be the "worlds largest manufacturer of performance polyurethane automotive components."
    These are the bushings that Toytec sells with the shackles and what i had on my 2012. They are a $20 adder via Toytec.
    Black Wolf and Netmonkey like this.
  17. Aug 23, 2019 at 8:18 AM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Ok, because I still have stock shackles and want to add poly bushings in there. For $20, I'll give it a try.
  18. Aug 23, 2019 at 8:39 AM
    monaco730
    16 Inferno Tundra
    No, the +3's are 1.75" so i instead went with the 2" pro form fabrication shackles. The link is for 1.5" but you can also find the 2".
  19. Aug 23, 2019 at 8:41 AM
    monaco730
    16 Inferno Tundra
