5100s and a shim
Discussion in 'Suspension' started by Ccraw2323, Feb 13, 2019.
  1. Feb 13, 2019 at 8:02 AM
    Ccraw2323
    Ccraw2323 [OP] New Member
    Christian
    San Antonio, TX
    2016 CrewMax Tundra
    Does anyone have pictures of their 5100s on middle and a cb shim, nothing in the rear?
  2. Feb 13, 2019 at 8:27 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    This is mine with 5100's on the middle setting with 1 cb shim on each side and nothing in the back. With this setup I was even front and back. (I found then when I was carrying a load in the back or when I towed my popup trailer I was a bit nose high so I added shackles to the back set at 1" about 5 months after this was taken.)
    Blueknights75 and TOYOTRD8 like this.
  3. Feb 13, 2019 at 8:54 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    How does this ride compared to stock? I'm waffling between this exact set up or 6112's.
  4. Feb 13, 2019 at 10:32 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I went from the stock TRD shocks to the 5100's on all corners and IMO the ride was a bit improved with the 5100's.
    I think that it comes down to how you use your truck. My original goal was just to level the truck and I had no plans for taking the truck off-road. For this the 5100s worked great. I have since started taking my truck off-road and am currently looking to replace my 5100s with an MT setup. The 6112s would have been better for the trails here in northern California and would have bought me a bit more time but in the end, I would have replaced them as well.
    SIXSEVENONE likes this.
  5. Feb 13, 2019 at 10:46 AM
    Sephon
    Northwest PA
    Thanks!
    sr5shark[QUOTED] likes this.
  6. Feb 14, 2019 at 6:45 AM
    VBTundra
    VBTundra New Member
    What size tires you running?
  7. Feb 14, 2019 at 6:50 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    ^^ What they asked
  8. Feb 14, 2019 at 7:07 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Tires are 295/65 18. No rubbing after removing the small front mud flap and pushing the liner forward about an inch.
  9. Feb 14, 2019 at 8:27 AM
    r1-superstar
    DB
    UTAH
    Thanks! I'm going with 305/65-18 so I should'nt have a problem clearing. Truck looks Great BTW!!
  10. Feb 14, 2019 at 8:42 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Thanks. 305/65-18 is a good size. What would increase the chances of the tires rubbing is the offset of your wheels. I am running wheels with a +25 offset and with this setup a 305/65 would work. If I was running wheels with a +1 offset then I would have had more trimming to do.
  11. Feb 14, 2019 at 8:58 AM
    r1-superstar
    DB
    UTAH
    Yeah, Rays are +25. I'm getting Ray 10s. :thumbsup:
  12. Feb 14, 2019 at 9:19 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Nice! Your truck will look great with the Ray10s
    r1-superstar[QUOTED] likes this.
  13. Feb 14, 2019 at 9:21 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The 6112 is going to ride better than the 5100s regardless. 6112 has a softer spring which reduces the feel of every bump in the road and the larger body gives much better control in every aspect of the shocks rebound. I replaced my brand new (4500 miles) TRD Red bilsteins with 6112s and the ride was substantially better all around. I’ve used 5100s on my previous truck and the 6112 blows it out the water.
    Sephon[QUOTED] and 1794Canuck like this.
  14. Jun 7, 2019 at 2:50 PM
    gmeek2
    gmeek2 New Member
    2017 Silver CM
    sr5shark do you have any driver's side lean??
  15. Jun 7, 2019 at 3:03 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I have not measured for some time but I have not noticed any lean. I have read that the driver's lean may not show until there are some miles on the truck (I am almost at 25K). Also, I am running the 5100's with the stock springs and I've read that Toyota takes the lean into account and the stock driver side springs are different than the passenger side.
    gmeek2[QUOTED] and SIXSEVENONE like this.
  16. Jun 7, 2019 at 7:36 PM
    gmeek2
    gmeek2 New Member
    2017 Silver CM
    Thanks you! I'm at 30k miles right now and I just got my 5100's on the middle setting installed yesterday and they put 1 CB shim on each side. I initially only wanted one on the driver's side. I did have a lil lean prior to the 5100's so I already had 2 shims on the driver side and 1 on the passenger side with the stock suspension. So far its sitting fairly level, which is weird since I defenitely had the lean before.
