LT tires: any TPMS issues?
Discussion in 'Wheels & Tires' started by AK 6.7PSD Replacement, Jun 7, 2019.
  1. Jun 7, 2019 at 6:53 AM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    I’m considering getting LT versus P-metric tires for my truck. Are there any concerns with TPMS if I run them at an LT-ranged pressure (>60psi)? I just don’t know if a higher PSI will freak the truck out even if all tires are within the same range (and is there a TPMS sensor in the spare—if so, it’d be at a lower P-metric PSI, so...??)
    Thanks!
  2. Jun 7, 2019 at 2:37 PM
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    I went to the BFG KO2'S in load range D with no issue .
  3. Jun 7, 2019 at 2:48 PM
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    Per the owners manual on TPMS, you should be able to benchmark a different tire pressure. Page 496 should help with the process.
  4. Jun 7, 2019 at 3:48 PM
    Headbangerpa
    Headbangerpa New Member
    Hello. I don't know what your plans are with the tires but the standard pressure for the Tundra is all you need. Granted the tires are rated to 45 or more but that is max rated pressures. Other than that you shouldn't have a problem, I run E range tires due to sharp rocks and running through the woods with a bed load with no issues but I use 33 psi which is what my truck is suggested for.
    JH5370 likes this.
  5. Jun 16, 2019 at 6:03 AM
    2004lb7
    2004lb7 New Member
    Ian
    Boss plow. Tows trailers everyday.
    After 100,000 miles I've not had any TPS issues.
  6. Jun 17, 2019 at 10:38 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I run mine at 46-50. In fact that is what the door sticker says for KO2s as OEMs. Same on my Tacoma. My TPMS will like up below about 40.
