Dealer couldn't install bed rail kit due to spray on liner
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike19, Jun 1, 2019.
  1. Jun 1, 2019 at 4:43 PM
    Mike19
    Mike19 [OP] New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Hi Everyone,
    I bought the bed rail kit for my 19 Tundra TRD Sport Crewmax from the dealer and had them install it. They told me they couldn't because my bed had spayon bed liner which was added at port. It covered over the screw holes. Anyone else get that? They couldn't install their own accessory.
  2. Jun 1, 2019 at 4:45 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    That's BS! A utility knife around the hole will get the liner off.
  3. Jun 1, 2019 at 4:46 PM
    I smell BS. What's so hard to knock the liner out of the holes.
  4. Jun 1, 2019 at 4:46 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Lazy and/or incompetent.
  5. Jun 1, 2019 at 4:49 PM
    charliebison
    charliebison New Member
    Just install the railt kit yourself. It only takes a few minutes and a torx screwdriver. Also, if there is spray on liner in the holes, just dig it out and install.
    jewsNbrews, Bigboitundra and Sas like this.
  6. Jun 1, 2019 at 4:50 PM
    Professional Hand Model
    Fred
    Hand Protectors
  7. Jun 1, 2019 at 4:55 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Hearing dealership stories like this scare me....if they can’t get past bed-liner....do I trust them doing anything remotely engine related? o_O
  8. Jun 1, 2019 at 5:15 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I had mine linexd and put mine on just fine u can see the hole outlines, they probably have a cheap spray and know it will chip.
    Black Wolf likes this.
  9. Jun 1, 2019 at 5:16 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I cleaned mine out with an m6 x 1.0 tap, easy peasy...
  10. Jun 1, 2019 at 5:18 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I would bet 100% this is the truth. Lazy.
    Ely010606 and darkknight2014 like this.
  11. Jun 1, 2019 at 5:19 PM
    Aurora CO
    This^^^^
    Omohundro, ColoradoTJ and 15whtrd like this.
  12. Jun 1, 2019 at 5:20 PM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
    Torx not Phillips 25 or 30 I think
    Also, on the plus side, now you know not to let those idiots anywhere near your truck. I did this in my drive way while drinking a beer.
  13. Jun 1, 2019 at 5:28 PM
    Zero One Actual
    It takes longer to get the bolts off for mods when they have spray liner over them than it does to take a drill bit or punch and make a hole.
    Do it yourself. Should take under twenty minutes.
  14. Jun 1, 2019 at 5:28 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Also, do yourself a favor and use stainless steel bolts if none were supplied. Digging the liner out takes no time and if you throw a couple shots of PB Blaster in the holes, you're golden
  15. Jun 1, 2019 at 5:44 PM
    Twise
    Trever
    The existing holes are threaded and there to accept the screws that come with the rails. DIY holes not needed or necessary. Grab an awl and just feel around for the hole, it will be soft where the hole is. Find one, cut away liner with utility knife. Once you find one mount rail and the holes in the rail will show you exactly where the other holes are. For the front rail, mount it with the fixed mount in the middle, just insert over the mount and slide to right. Then it will locate the other 4 holes. Clean liner away, drink beer, repeat.
    Easy to do, and you can’t really screw anything up.
  16. Jun 1, 2019 at 5:47 PM
    Twise
    Trever
    I didn’t use a tap, just run the provided screw until you feel resistance, then back it out, clean it off and thread it in again until it goes all the way in without resistance.
    I have tools that make tools, but most people have a hard time locating a screw driver. They are for sure not gonna know what a tap is or how to use it. And a slip of the wrist there will ruin the threads.
  17. Jun 1, 2019 at 5:52 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    PLEASE do yourself a favor and go somewhere else
    Sas likes this.
  18. Jun 1, 2019 at 5:53 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    You'd think they would hold Toyota dealers to the same standards. Who told you this? Sales guy or service?
  19. Jun 1, 2019 at 5:57 PM
    Twise
    Trever
    They do, but it’s based on customer reviews and quarterly / yearly audits. If the service manager knows his shit then his crew will as well. I find most dealers have service managers wearing so many hats that chaos reigns.
    This is a 20 to 30 minute install. No reason why they couldn’t have knocked this out while you had a coffee.
    My driveway is available to any and all locals with no tools. Chances are you do something professionally that I couldn’t do..
    Drop a pm or email. Yes, I am serious.
    Pudge, Darkness, Omohundro and 4 others like this.
  20. Jun 1, 2019 at 7:08 PM
    Moon Puppy
    Bob
    2020 Tundra Limited
    Nice offer, where are ya?
  21. Jun 1, 2019 at 7:32 PM
    gosolo
    Ray
    NW Oregon
    Yep, no kidding. Imagine that dealership doing a cam tower leak repair!
  22. Jun 2, 2019 at 2:30 AM
    Twise
    Trever
    Temecula, Ca.
  23. Jun 2, 2019 at 2:56 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    What a bunch of ZAZY - Incompetent idiots
    Would NEVER take ur truck there again!!
    Sas likes this.
  24. Jun 2, 2019 at 2:57 AM
    Zero One Actual
    I see how I wrote that incorrectly. I didn’t mean make your own new holes. I meant find the ones and uncover them like buried treasure and it takes twenty minutes.
  25. Jun 2, 2019 at 5:34 AM
    Moon Puppy
    Bob
    2020 Tundra Limited
    Oof....bit too far for me. But if I ever get a chance to make a 5k mile road trip to get some work done on the Tundra, i'll bring the beer. :woot:
    Pudge and NewImprovedRon like this.
  26. Jun 2, 2019 at 5:46 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    They didn’t wanna take the chance of messing up your liner. Just drill thru it
  27. Jun 2, 2019 at 8:50 AM
    Mike19
    Chi town
    Thanks everyone.
    texasrho83 likes this.
  28. Jun 3, 2019 at 8:09 PM
    Twise
    Trever
    Done
  29. Jun 3, 2019 at 9:11 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Yep same with mine. I found them with help. See this thread. https://www.tundras.com/threads/diy...aper-option-than-oem.1906/page-6#post-1223414
    I just poked it then used a razor blade to slowly cut inside the circle, screw M6x1
  30. Jun 9, 2019 at 12:37 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    What the heck? Mine has a spray-in bedliner and the rails, so it's certainly possible. Heck, just do it yourself. Use the holes in the rails to figure out roughly where the holes are in the truck and poke around (for cosmetics, keep that poking under the area where the rails will go). Once you find the holes, clean them out with a pocket knife or similar. After that, it's just a matter of screwing bolts into the existing nuts behind those holes - a bolt-on option that shouldn't take you all that long.
