AR Trigger
Discussion in 'Guns & Hunting' started by Prostar 190, Dec 27, 2018.
  1. Feb 5, 2019 at 6:22 AM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    I'm a little foggy today. Did I have a typo? :anonymous:
  2. Feb 5, 2019 at 6:25 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    NOPE!just admiring you had more than one!
    Boosted4runner and Grumpy Uncle like this.
  3. Feb 5, 2019 at 6:47 AM
    Grumpy Uncle
    Pat
    CO
    When my dad gave my oldest boy my pop pops 16 gauge it wouldn't fit into my ist safe because the barrel was too long. Sooo, that was my justification for another one. You know, need to protect a family heirloom and keep it locked up.:D
  4. Feb 5, 2019 at 7:54 AM
    aperezsh
    Ali
    Amen!!!
  5. Feb 5, 2019 at 8:02 AM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    I have a Timney 3-4 LB single stage trigger in one of my ARs. It breaks super clean and has a very short throw, almost like clicking a mouse. It is the perfect trigger for a rifle that you would be shooting from a rest. I have found that it scares me a bit since it is so sensitive, and isn't really conducive to the type of shooting I have done recently (walking/jumping out of a truck to shoot at a pig etc).
    My latest build has a Geissele SSA-E two stage trigger and I absolutely LOVE IT. It breaks like the Timney, but since it is a two stage you get to take up the slack and know when it will break.
    Grumpy Uncle likes this.
  6. Feb 5, 2019 at 9:04 AM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
  7. Feb 5, 2019 at 10:03 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    You get used to the single stage, and then a 2-stage becomes wierd to shoot.
    I have 4 or 5 2-stages I’m weeding out.
    Here’s a decent trigger review - Geisselle stage 2 breaks at over 4#.
    Timney breaks over 2#.
    I know that scares some and every platform is for a different purpose. After shooting a 1# Jewel in a bolt-rig, it becomes what you get used to and compare everything else to.
    I will never go back to a 2-stage or a 5-7# MilSpec trigger.
    I guess Tom Vehr who started Velocity Triggers designed and was a big part of Timney for a number of years (and at Knights prior). He broke off and did his own gig. Kind of cool :cool:
    https://www.google.com/amp/s/www.th...remy-s/velocity-triggers-drop-in-trigger/amp/
    https://m.youtube.com/watch?v=OrvHI0h6cwA
    Smoofers[QUOTED] likes this.
  8. May 28, 2019 at 6:49 PM
    bovavet
    bovavet New Member
    2010 SR5 crewmax, 2012 SR5 double cab ,2014 limited double cab, 2016 TRD PRO,2008 FJ, 2010 FJ
    I like Hyper-touch
  9. Feb 28, 2020 at 7:03 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I just went with JP Enterprises AR-15 REDUCED POWER Spring Kit(3.5lb-4.5lb)
  10. Feb 28, 2020 at 7:13 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
  11. Feb 28, 2020 at 7:14 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    That new larue 2 stage looks amazing for the price
  12. Feb 28, 2020 at 7:46 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I have a elf on my 16" ar. I like it but I would go with geissele or jp and larue always makes good products. Elf is smooth super clean break
  13. Feb 28, 2020 at 7:59 PM
    18TRDSport
    18TRDSport New Member
    Western Mass
    2018 TRD Sport Sequoia in White
    Window tint, terrainContact AT tires, skid plate, less restrictive muffler and TRD air cleaner
    For a general all around build not a high dollar custom, you cannot go wrong with a laRue MBT flat trigger for $87.
    Flyinryank likes this.
