Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. May 20, 2019 at 1:49 PM
    #211
    916tundra
    916tundra [OP] New Member
    Ken
    2017 Tundra Crewmax
    Yes, a physical switch for the 12v constant feeding the HU.
  2. May 20, 2019 at 2:25 PM
    #212
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    916tundra[OP] likes this.
  3. May 20, 2019 at 6:36 PM
    #213
    minter66
    minter66 2007 TSS CrewMax
    Well I had a hunch, I can’t explain why I tested this but my spider sense was tingling.
    My FCAM for some reason still has 12V when the system is off and after the sleep function of 30s kicks in. I disconnected the power cable in the engine bay and my battery has been holding solid at 12.20v for over an hour.
    I’ll check it again in the morning after taking readings (about to go drive) and compare. I expect .01 to .02 loss or volts due to constant 12V for memory (yellow wire)
    Big issue now is, how does Dasaita fix this?
    If anyone has a chance, I’d like to see if your FCAM power lead still has 12V after the system supposedly is full off
  4. May 20, 2019 at 6:50 PM
    #214
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    It was my understanding that the front camera gets power through the head unit from the canbus. What did you have to disconnect in the engine bay?
    EDIT: I guess you are trying to find out if the FCAM power lead (from head unit) is still supplying 12v even after it is off.
  5. May 20, 2019 at 6:51 PM
    #215
    tinman10101
    Tinman
    2016 MGM Crewmax
    Ken @916tundra
    I just updated my wife's CX-9 Android firmware from 8.0 to 9.0. It was very easy:
    • Load IMG file to root of SD Card
    • Load in Map SD Card Slot
    • HU will prompt for update but you will Cancel
    • Instead go to System Settings and Update through there.
    This was the video they sent me on instructions and it worked like a charm. Just FYI if you ever decide. PS i also updated my wife's HU with a new MCU update as well.
    Cheers
    Tin
    916tundra[QUOTED][OP] likes this.
  6. May 20, 2019 at 7:05 PM
    #216
    916tundra
    Ken
    2017 Tundra Crewmax
    @minter66
    I have not installed the front camera so I cannot test this out but the way you explained, it sounds like you have two power sources running ur fcam. Power at the HU and power at the battery, correct? I don’t think you will need to hook up both power sources, only need the power sources at the HU. If you connect it to the battery, then the fcam is constantly on. I think u should be fine now that u disconnected the power at the battery
    VTYOTA likes this.
  7. May 20, 2019 at 7:09 PM
    #217
    916tundra
    Ken
    2017 Tundra Crewmax
    Finally was able to mess around with jailbreak and CarBridge and now I can use any apps I want thru CarPlay.
  8. May 20, 2019 at 7:12 PM
    #218
    minter66
    Correct, I was testing to see what was still on when the system was completely power off, doors shut, car “asleep”
    My F Cam gets its power directly from the head unit via the F Cam yellow power wire. Even after everything had gone to sleep and shut down I was still getting 12 V for no reason
    I disconnected the power in the engine bay because that is where I put the end of the power cable from the head unit, it’s not powered via my battery.
    Simply put I unplugged the power at the camera. This way when I know the truck will be used consistently, I can plug it back in until dasaita sends me a fix (new harness?)
    Edit: Do you guys think me wiring the FCAM power wire into the red ACC wire would still allow the FCAM to work when the car is on, but kill voltage when its off? I dont know if the FCAM app is power sensing? If it doesn't detect power to the yellow FCAM wire, will it not work?
  9. May 20, 2019 at 8:05 PM
    #219
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Interesting, so you had to supply power to the FCAM yellow power wire from the engine bay? I’m probably a little confused because I haven’t installed a front camera yet. The actual head unit install didn’t entail any work in the engine bay for me. My cam should be here this week and I’ll try to install it this weekend.
  10. May 20, 2019 at 8:26 PM
    #220
    minter66
    The RCA cable and the power cable are one. So I had to run the RCA out to the engine bay with the power cable to the camera.
    It connects to the FCAM yellow power wire behind the head unit
    Edit: Checked voltage this morning and while not as bad, still went from 12.39V to 12.26V - so I am probably just going to cut the constant 12V from the harness and wire it into the ACC line - I will lose my Android clock each time (thankfully Audio settings are saved to the memory) but since I use CarPlay - clock is pulled from my phone.
    Dasaita did admit that the FCAM harness wire should not be supplying a constant 12V wire - they might be sending me a new harness as this might be defective.
    And as if I am not having enough upgrade issues, just had to replace my pass side HID bulb again! First one was wrong temp (4300K instead of 6500K) - second one died within 3 days (won't ignite) so I just put a third bulb in.
  11. May 21, 2019 at 7:25 PM
    #221
    tinman10101
    Tinman
    2016 MGM Crewmax
    Did this today. Thanks to @VTYOTA. This thing is insane!!!
    Also thanks to everyone on this thread for their help.
    TNDRA6!9, jmevis, Topherwv and 2 others like this.
  12. May 21, 2019 at 7:29 PM
    #222
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Looks great! You’re going to love it! Let us know if you happen to find any hidden gems.
    Also curious, does the truck still beep when you lock it? Mine does, but some have reported that theirs stopped after install.
  13. May 21, 2019 at 7:35 PM
    #223
    916tundra
    Ken
    2017 Tundra Crewmax
    @minter66
    So I tested the fcam wire today and got 4V when HU is completely shut down and 12V when HU is on or on sleep mode. I’m not sure if 4V will cause any issue later on when I install the front camera. I’m assuming you got 12v regardless if the HU is on or off?
    @VTYOTA can you test the fcam power wire to see what voltage you get when HU is off?
  14. May 21, 2019 at 7:45 PM
    #224
    916tundra
    Ken
    2017 Tundra Crewmax
    I don’t think the FCAM app is power sensing like the reverse camera, so I think you should try splicing the front cam power wire into the red acc wire.
  15. May 21, 2019 at 8:24 PM
    #225
    minter66
    Yep, 12V even after 30 min
    I’ll try splicing into the red ACC wire. I may have to do the same with the main power wire as well
  16. May 21, 2019 at 10:37 PM
    #226
    tinman10101
    Tinman
    2016 MGM Crewmax
    Yeah mine still beeps with no issues. My remote start works fine and beeps as well. And just for everyone else ... I can confirm that the HU works with the FRAC harness too.
  17. May 22, 2019 at 10:59 AM
    #227
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    So, I did a rushed install last night.
    Initially had an airbag light, but that's since disappeared, so I think were good there.
    However, none of my steering controls work. There are a couple plugs from the HU that don't connect to the trucks harness, is that typical or am I missing something?
    Also have a front cam I'll likely be installing this weekend or next.
    Most importantly, any apps I need to download that I cant live without?
  18. May 22, 2019 at 11:09 AM
    #228
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    OK so to make the steering wheels controls work you have to go in to
    Settings > Car > Factory Settings (Password is 126) > Canbus > Select Type 08 Toyota Camry_Rav4 > Apply > Exit
    FYI after you do this your truck my not beep with locking/unlocking. Thats what mine did.
    But yes there are a few things that do not connect to the HU.
  19. May 22, 2019 at 11:11 AM
    #229
    916tundra
    Ken
    2017 Tundra Crewmax
    i believe 2-3 plugs will not be used from the canbus harness. The harness is universal for most Toyota vehicles so not all plugs will be used.
  20. May 22, 2019 at 11:11 AM
    #230
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I downloaded Pulsar Music Player(free version) last night and is way better than the music app that came with the head unit. This is if you wanted to play music from a usb drive. Intuitive and minimalistic.
  21. May 22, 2019 at 11:20 AM
    #231
    916tundra
    Ken
    2017 Tundra Crewmax
    I figured out how to run a wire with a diode to the red acc wire to have the HU turn on with my remote start. If anyone has remote start and wants to do this, I can post some instructions. This solved the cold boot time for me.
  22. May 22, 2019 at 3:32 PM
    #232
    BeachyTundra
    Brandon
    Spokane
    Worked for me, and it seems as though my truck still beeps with lock and unlock, so I'd call that a win!
    I would definitely be interested in this. I've got a remote start myself, but at least with the 9.0, the boot time really didn't seem all that bad.
    Sooooo.....Where does the Mic plug in? I'm not sure I need it though, as I had a phone call today and the person on the other line said it just sounded like I was holding the phone a bit farther away from my face.
    Does anybody know how to prevent the music from stopping when putting it in reverse? Or doing a full screen mirror from an Android phone to the stereo?
  23. May 22, 2019 at 6:28 PM
    #233
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Slowly getting mine set up the way I want. Running Nova Launcher and Maxelus Shadow Galaxy live wallpaper for now.
  24. May 22, 2019 at 7:57 PM
    #234
    tinman10101
    Tinman
    2016 MGM Crewmax
    Mic plugs in on the rear of the deck. you'll see a small whole just to the bottom left of all the connectors for the HU
    There is a setting to disable the music stoppage in reverse. Its under Car Settings ... I forget where it is ... it also allows for option of lower volume by db in reverse too. I'll check tomorrow for exact location of settings
  25. May 22, 2019 at 7:59 PM
    #235
    tinman10101
    Tinman
    2016 MGM Crewmax
    Dope Howard. I stuck with the Car Launcher app that was pre-installed. I like the UI ... here is mine:
    TNDRA6!9, Topherwv and VTYOTA[QUOTED] like this.
  26. May 23, 2019 at 9:17 AM
    #236
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    So I will be installing my front camera hopefully this weekend, but I'm not exactly sure how to wire it all up. This is the diagram that is provided with the camera.
    I assume that I don't need the trigger wire (B) since it will not be used as a back up camera? Then do I just connect the red wire to the head unit FCAM power and ground the black? I think it might be easier to just do an Add-A-Fuse in the engine bay, but I am not sure.
  27. May 23, 2019 at 9:26 AM
    #237
    buffaluphagus
    buffaluphagus —————————————
    Ugh i need this. Having jailbroken phones makes it seem like a must purchase now.
  28. May 23, 2019 at 9:35 AM
    #238
    tinman10101
    Tinman
    2016 MGM Crewmax
    Howard ... you are correct, you dont need to tap into the reverse or else it will only come on when you are in reverse. you only need to connect the rca cable to the input female of HU and as far as power. negative can be a positap into the negative of the canbus and positive you can posi tap into any power source for acc or even the canbus positive 12v source.
    i would just get two positaps and tap into the canbus.
  29. May 23, 2019 at 11:45 PM
    #239
    NMTundra
    NMTundra New Member
    Shouldn't have read this thread. Really tempted to see if I can get this working in my first gen now, even though I have absolutely no reason to do so.
    jmevis likes this.
  30. May 24, 2019 at 11:05 AM
    #240
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    How is this thing with glare? Can't even see my oem nav screen when it is sunny out. Also does it autodim at night?
