Rim offset?
Discussion in 'Wheels & Tires' started by bj46-taco-tundra, Apr 15, 2016.
  1. Apr 15, 2016 at 4:46 PM
    bj46-taco-tundra
    bj46-taco-tundra [OP] New Member
    Mark
    Bj46 taco and now a tundra
    Looking at aftermarket rims and trying to wrap my head around appropiate bs or offset for 20" rims on a platinum 2016. What do we recommend?
  2. Apr 15, 2016 at 5:12 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Depends on wheel width and desired tire width. There is no general answer here. What are you planning on doing to the truck suspension wise and what are you willing to sacrifice? Cutting skid plate? Can mount chop? Removing mud flaps? Mall crawler or actually using it? Stock replacement?
    Black Wolf and Relentless like this.
  3. Apr 15, 2016 at 7:56 PM
    bj46-taco-tundra
    Mark
    Mall crawler ... I like that.
    Honestly, I'll put on a leveling kit, pull the stock tires and rims off, install fender flares and black rims and a A/T tire slightly oversized only to fill in the gaps. I just want to clean it up and dress it right but modest.
    GNTundra likes this.
  4. Apr 18, 2016 at 6:46 AM
    jberry813
    Lake Tahoe
    Around a +18 offset on a 9" wide wheel will allow for a 35x12.50. But you will need to trim the skid plate and do a cab mount chop
    csuviper and Black Wolf like this.
  5. Apr 29, 2016 at 8:30 AM
    Tennis Guy Tulsa
    Tennis Guy Tulsa New Member
    Brad Richison
    silver 08 Tundra
    I have a crewmax 08, I'm looking for black wheels 18" I don't want them to stick out from the fender, What is the proper offset ?
  6. Apr 29, 2016 at 1:53 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    If you want to do least amount of modifications, go with 35 mm offset on a 9 inch wide wheels. I've seen some guys with 35x12.5 on this offset wheels without modification.
    I have 18 mm offset (9 inch wide) and I have 295/70/18, which is about 34.5 inches in diameter. This is just about the largest you could go on 18 mm offset wheels if you do not want to do some serious cutting. Anything larger will require the body mount chop. I have 3.5 inch OME lift, by the way.
    Black Wolf likes this.
  7. Apr 29, 2016 at 7:05 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I have 35x12.50's on fuel 18x9 with a +20mm offset I removed all front plastic and the mud flaps on a leveled front end. The only time I rub anything is backing up I touch the front bumper a little when going over bumps. I haven't done a CMC and frankly I don't ever touch it from what I've seen my caster is at 2.9 so it puts me into the front more. Granted the truck is a street queen and hasn't been off road other then fire roads I've got my Tacoma for wheeling.
  8. Apr 29, 2016 at 7:26 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Check mine out, no spacers and my tires are roughly 12" wide. 20" wheels, no rubbing.
    rons23 likes this.
  9. May 1, 2016 at 8:42 AM
    texanhoyt
    texanhoyt New Member
    Seth
    2016 Texas Edition 4x4
  10. Oct 20, 2016 at 9:22 PM
    bj46-taco-tundra
    Mark
    Looking back at old posts and looks like the mall "crawler might" have been the head on the nail. Lol
    The truck came all tweeked out with 20" fuels that were prettier then I was looking it. But I love it. image.jpg image.jpg
  11. Oct 20, 2016 at 9:39 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    what flares are those and how much do they extend? i like
