Fitting 295 70 18 with just a leveling kit?
Discussion in 'Wheels & Tires' started by Ruppster, May 1, 2019.
  1. May 1, 2019 at 3:15 PM
    Ruppster
    Ruppster [OP] New Member
    Just bought my dream truck but admittedly am sort of a rookie at the ins and outs of building the look of my truck. I’ve done my research on the size wheels and tires i like (295 70 18) but i’d like to make those work with only a leveling kit. Is that possible? If so, is there a certain leveling kit that will work? I can deal with a little rubbing if i can fix it myself (watch a youtube video) or have a professional do it. Any advice would be awesome, just be sure to dumb it down for me. Thanks again!
    tbrown likes this.
  2. May 1, 2019 at 3:18 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! @Toytec Lifts will be able to assist with your lift questions and just use the search bar on the forum banner and you will find plenty of answers to your tire fitment question.
    Toytec Lifts likes this.
  3. May 1, 2019 at 3:38 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  4. May 1, 2019 at 4:55 PM
    Tundra17Tom
    Tundra17Tom Passin Thru
    2017 4X4 Tundra SR5 Double Cab 1G3
    HR LED interior HR LED Cargo Light HR LED Backup Light Raised black TUNDRA letters on tailgate Rear and Front bumper painted black Bilstein 5100s front and rear Method NV305 Matte Black Blacked out badges Debadge Iforce and SR5 AVS window vent visors TRD Pro Headlights Auxbeam LED headlight bulbs Driver side Oh Hell Handle
    welcome from SC... have fun with your mods
  5. May 1, 2019 at 7:32 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
  6. May 2, 2019 at 6:27 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Welcome from all of us here at Toytec Lifts! We offer a ton of different options for lifting/ leveling out your Tundra!
    Shoot me a pm or a call anytime and we can get you squared away properly the first time!
    Black Wolf and Blueknights75 like this.
  7. May 2, 2019 at 11:29 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Welcome @Ruppster . @Toytec Lifts will definitely be a big help. I will be running 295 70 18 on their 3/1 lift.
  8. May 2, 2019 at 12:34 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Welcome from Nashville! I had to do a bmc and some mild trimming of front bumper for my 295/70r18 setup.
  9. May 2, 2019 at 3:53 PM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    Welcome from MO. As others have said, use the search bar! Or you can just read a bunch of threads in the wheels and tires and suspension forums. There's a ton of good info in there, and you can find lots of other ideas too for how to spend your money ;)
  10. May 2, 2019 at 4:57 PM
    Hyperlite33
    Hyperlite33 FN-2187
    2018 White Platinum 4x4
    Welcome from Florida.
    I just put 295 70R18s with +25 offset wheels on my 2018 with a Bilstein 6112 with no shims and Coachbuilder +2s. Had some rubbing in the front so I opted for Coachbuilder's bumper shims to push the bumper out 1/2" and no more rubbing. Oh and removed both front mudflaps. Hope that helps!
  11. May 3, 2019 at 3:16 PM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I just put 295/70/18 Yokohama Geolandar AT G015s on my Pro, stock wheels and lift. They look great (pics soon), and the only rub was the front tiny mudflap. Very pleased. Also, I don't think I could have gone any wider on the tire size, they're super close to the UCA.
  12. May 10, 2019 at 9:59 AM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Should work fine but will more than likely require trimming. Do research on your offsets/backspacing. Good luck.
  13. May 10, 2019 at 10:02 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura California
  14. May 10, 2019 at 10:12 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
