  1. May 2, 2019 at 10:54 AM
    #6541
    Alltimehigh
    Alltimehigh New Member
    Has anyone replaced a leaky output seal in the past? It seems like this Tacoma vid details the process well -
    https://www.youtube.com/watch?v=aC8yfiTiw3M
    But I got under the truck and realized my 2004 tundra has exhaust piping in the way. Can I still remove the driveshaft and work around the piping or do I need to remove parts of the exhaust as well?
    Might as well do a check on the seal part number as well as its been a bit confusing looking it up. I bought part
    90311-41007 and Im 95% sure thats the one. Any help would be greatly appreciated.
  2. May 2, 2019 at 10:59 AM
    #6542
    Alltimehigh
  3. May 2, 2019 at 12:17 PM
    #6543
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    So far, pulled off my side steps.
  4. May 2, 2019 at 3:26 PM
    #6544
    Professional Hand Model
    Fred
    Hand Protectors
    Scored on a used combo tool box and many drawers of tools. Total cost $175 for everything pictured. Had to clean everything up and put a coat of grease on, but well worth it. Not pictured are some fine measuring tools and assorted goods.
  5. May 2, 2019 at 4:27 PM
    #6545
    FlightSimGuy
    $175? Get out. o_O
  6. May 2, 2019 at 4:55 PM
    #6546
    Fred
    Hand Protectors
    Sick deal. Majority of these tools are a mix of Snap-On, Craftsman, Mac, and Thorsen. Most over 40 years old.
  7. May 2, 2019 at 6:24 PM
    #6547
    I'm having a hard time believing this but I just got 18.6 MPG on the way home from SC tonight. This was through the Smokie Mtns. I got 17.5 on the way there.
    I have never even come close to this before. It was hot and through mountains. It makes no sense.
  8. May 2, 2019 at 6:53 PM
    #6548
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Ok, I've got the 2nd and final pieces of the ultimate headlight mod in the mail today. I'll be installing the wire harness and 100w h4 bulbs tomorrow sometime. Either in the morning after I get home from work or in the afternoon when I wake up.
  9. May 2, 2019 at 7:00 PM
    #6549
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    be sure to post up pics of the output.. im debating doing this or a 50w hid Retrofit with d2s projectors..
  10. May 2, 2019 at 7:31 PM
    #6550
    NMTundra
    NMTundra New Member
    Installed my backup camera today, much needed upgrade IMO. I'll post pics tomorrow.
    because_wumbo-truck and NUDRAT like this.
  11. May 2, 2019 at 8:12 PM
    #6551
    Tundra865
    Tundra865 New Member
    Braxton
    Tennessee
    2000 White Tundra SR5 4.7 4WD
    Brush guard, dual flowmaster exhaust, hella spotlights, bed cover
    331C3D85-79DF-4713-96EA-0E5E1D504309.jpg Got some new wheels for the tundra
  12. May 2, 2019 at 8:24 PM
    #6552
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Theres no debate :muscleflexing:
  13. May 2, 2019 at 8:37 PM
    #6553
    FlightSimGuy
    I get 18-19 on highway.
    Also got the new tires on today.
  14. May 2, 2019 at 8:49 PM
    #6554
    Wings11
    Wings11 New Member
    Wings
    2002 Tundra garage whole life 80k
    So far new kicker speakers in doors and window tint all the way around
    Normally if the exhaust is in the way you can drop the rubber exhaust holders and it can give you some play with the piping
    NUDRAT likes this.
  15. May 2, 2019 at 8:56 PM
    #6555
    Wings11
    Wings11 New Member
    Wings
    IMG_20190502_204331.jpg IMG_20190502_204323.jpg IMG_20190502_204321.jpg just did projector lights on the truck wired them into the existing door Courtesy lights so they go on and off with the door. Sorry for not having a better pic this street lighting takes away from the ahhh experience. With this lighting you can faintly make out the Toyota letters. Need to install the passenger side next
  16. May 2, 2019 at 9:09 PM
    #6556
    Wings11
    Wings11 New Member
    Wings
    Your axle should still be fine tho depending on how the splines look and check where the bearings we're running ... If the axle isn't scored you should be ok no?
  17. May 2, 2019 at 10:09 PM
    #6557
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    I did nothing to my truck today. However, Darkness was kind enough to install a Yellowbox speedo correction device in my truck for me. https://yellr.com/ Man knows what he is doing, having done it on his own truck.
    Install was a success. My speedo was off by about 20 percent due to 4.88 gears and 32" tires. It took several rounds to calibrate the Yellowbox's correction amount, but after doing laps in the parking lot of a local strip mall and a few passes down the freeway, we had it pretty much spot-on.
    Thanks again, Luis. You're the man.
    hammeron, bmf4069, NUDRAT and 4 others like this.
  18. May 2, 2019 at 10:18 PM
    #6558
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Glad it worked out @sakana
    I learned how to start an 02 Tundra haha
  19. May 2, 2019 at 10:26 PM
    #6559
    because_wumbo-truck
    Jon
    Houston, Texas
    You have the DDI injectors installed?
  20. May 2, 2019 at 10:30 PM
    #6560
    because_wumbo-truck
    Jon
    Houston, Texas
    Total cost was under $150 and install should be less than 30 minutes. I'm excited. Will post it.
    Darkness likes this.
  21. May 3, 2019 at 1:13 AM
    #6561
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    The bearing spun on the shaft and Damaged it and the retainer is cracked. It could be rebuilt but it’s not worth it to me to invest much in time or money in one of these axles.
  22. May 3, 2019 at 2:11 AM
    #6562
    because_wumbo-truck
    Jon
    Houston, Texas
    Which setup is that?
    Darkness[QUOTED] likes this.
  23. May 3, 2019 at 4:12 AM
    #6563
    Nope. I haven't purchased them yet.
  24. May 3, 2019 at 4:28 AM
    #6564
    Fred
    Hand Protectors
    With fuel mileage like yours no need! I think the injectors provided a 1 MPG gain in Highway Miles from 16 up to 17. City no change, but the shift points seem nicer with the gears holding longer.
    I wonder if the summer blended gas is helping MPG? Seems mine ticked up a notch, but not much. My pedal response feels real good. Hot weather related?
    Wish we knew exactly when the winter/summer blend switch occurs.
    I do know the CerTec has made the already quiet 4.7L engine even quieter. It’ll be a few days before a hand calc on MPG.
    because_wumbo-truck likes this.
  25. May 3, 2019 at 4:44 AM
    #6565
    because_wumbo-truck
    Jon
    Houston, Texas
    What's the certec?
  26. May 3, 2019 at 4:49 AM
    #6566
    because_wumbo-truck
    Jon
    Houston, Texas
    Mine come in today. I need to figure out when I'll have time to get em installed. I wish I had a second vehicle so I could just leave the tundra at my mechanic's.
  27. May 3, 2019 at 4:49 AM
    #6567
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Better be out now, the way gas prices have been creeping up, creeping up, creeping up....
  28. May 3, 2019 at 4:53 AM
    #6568
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Check w. your mechanic - may have something you can borrow, might know of something decent another customer is selling. just don't spend the install money on a second vehicle - LOL.
  29. May 3, 2019 at 4:56 AM
    #6569
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I removed and replaced the steel wheels with snow tires with my alloys and street tires, the winter kit is back in storage... we didn't have any ice or snow this winter.
  30. May 3, 2019 at 5:04 AM
    #6570
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Nice looking rig, how do you like that cap?
    I've often wondered if those are simply stylistic, or day to day there's a benefit I'd appreciate.
    I know it's taller, just wonder if you find yourself often glad for the extra height in back?
