TSS Sensor Elevation
Discussion in '2.5 Gen Tundras (2014-2021)' started by BRYMTIME, May 1, 2019.
  1. May 1, 2019 at 1:16 PM
    BRYMTIME
    BRYMTIME [OP] New Member
    Andrew
    Portland, TX.
    21' 1794 CM
    Zone Offroad 5 Inch Lift Nitto Ridge Grapplers 35x12.50xR20 Fuel Wheels - Rogue D709 Chrome Delete - Match Paint & Wrap LED Lighting Upgrade (Headlight Revolution) Decked Truck Bed System Full Factory Speaker Swap - Installed JL 10 Inch Subs & Amp. Helix Door & Dash Speakers. ( All Equipment & Custom Sub Box - Tech 12 Volts)
    Afternoon, I'm looking to install a front bumper replacement or bull bar. Before I make a purchase I wanted to check if anyone has installed any with the push bar.
    Im currently looking at the Iron Cross HD bumper with the push bar, or the Aries bull bar (3" round pipe). Any advice on if the TSS sensor will be blocked? Mine is on aTRD Pro grille installed behind the crazy over priced panel below the Toyota lettering. Thanks in advance for any help.
  2. May 1, 2019 at 2:03 PM
    timsp8
    NY
    I don’t think there is any documentation from Toyota on the sensor angles or anything, at least not public, but I’d almost guarantee it needs the entire front clear all the way down to the road surface.
  3. May 1, 2019 at 2:14 PM
    BRYMTIME
    Andrew
    Portland, TX.
    21' 1794 CM
    I kinda figured that, but I wanted to make sure. Maybe I can find a way around it, or relocate it. Thanks
  4. May 1, 2019 at 2:20 PM
    Welcome from NY.
  5. May 1, 2019 at 2:47 PM
    BRYMTIME
    Andrew
    Portland, TX.
    21' 1794 CM
    Thank you, I've read threads on here for a long time just never joined. But I'm glad to be a part of it.
    Just switched back to Tundra, a had a 2015 blue ribbon metallic that I traded for an F250. Had a lot of issues with the powerstroke and decided to get back in a Tundra right before Christmas.
    DaBoro54, 1UPPER and HappyGilmore like this.
  6. May 1, 2019 at 3:28 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Im just got a new winch bumper I haven't installed yet on my '19. There mws a bull bar option for it... but the sensor problem crap scared me off of it.
  7. May 1, 2019 at 4:16 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Aries 3” works fine with the PCS sensor, I had one for a while. I have a new and used one for sale on the market place forum if you’re interested.
  8. May 1, 2019 at 4:24 PM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    I have the go Rhino bumper with bar, no TSS issues. It’s by no means a bull bar though
  9. May 1, 2019 at 4:50 PM
    BRYMTIME
    Andrew
    Portland, TX.
    21' 1794 CM
    Nice truck @deedubb, I think it will fit. I already bought the Aries bull bar a few weeks ago but I was going to return it. My only question now is if the sensor is positioned lower on the pro grille insert than it is now on my center badge.
    But I'm going to give it a shot, I'll post some pics if it works, incase anyone else goes this route. Thanks for the info everyone.
    deedubb likes this.
  10. May 2, 2019 at 2:57 AM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    Deedub, THAT is a proper looking truck!!! :thumbsup:
    deedubb likes this.
  11. May 2, 2019 at 4:03 AM
    BRYMTIME
    Andrew
    Portland, TX.
    21' 1794 CM
    What lift did you go with @deedubb, I'm thinking about doing a 4.5" BDS Coilover, but might go 7". I like the stance yours has though.
  12. May 2, 2019 at 10:51 AM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    Thanks! I have the ReadyLift 8”
  13. May 14, 2019 at 7:52 AM
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    I am having the same problem, looking for some added front end protection, other than the stock bumper which I do not want to change, looking for alternatives that will keep the stock sensors, not lose the use of the pull hooks (it appears that most push bars and bull bars use the same mounting holes that the pull hooks use. and still give me a little added front end protection...not asking for much. lol suggestions?
  14. May 14, 2019 at 7:56 AM
    That's nice!
    deedubb[QUOTED] likes this.
  15. Feb 3, 2020 at 6:54 PM
    ringo
    ringo New Member
    2020 Tundra 3” lift Fab Four bumpers
    deedubb has the right idea with Rhino. That is a nice machine. Here’s my issue with Fab Four. The animal bar is right in front of the emblem where the Pre Collision System is. Brand new and it didn’t even cross my mind until now when there’s no cruise control at all. I thought maybe digging the sensor out and remounting it on the bar or mount a mirror or reflective strip to deflect the sensors vision. Toyota says they can’t delete the code due to it being a safety feature. Anyone have any ideas? Or tell the dealer to take the bumper they ordered back.
  16. Feb 3, 2020 at 7:25 PM
    Blueknights75
    Ron
    Clayton, NC
    Good looking bumper! Can you just remove the bull bar portion?
  17. Feb 3, 2020 at 7:29 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    the sensor absolutely cannot just be removed and placed anywhere in the front end. Nor can you put mirrors or reflective strips to trick it. It’s designed to function in the location it comes in with very little room for recalibration if needed. However, by no means can the sensor be blocked by anything. It’s a shame the salesman didn’t go over any of this with prior to purchasing the vehicle. Most dealerships don’t want the liability or legally can’t delete anything safety related. Your options are limited here. Keep the features of the vehicle and get something that doesn’t block the sensor. Or keep it and live with features you certainly paid for but can’t use and a constant light on the dash.
  18. Feb 3, 2020 at 7:33 PM
    Welcome from NY.
    Can you take a direct head on front picture.
    I think you can get a relocation bracket and lower the TSS sensor.
  19. Feb 3, 2020 at 8:04 PM
    ringo
    ringo New Member
    It’s welded from Fab Four. It could be cut and re-welded shorter or higher. Might look butchered up a bit. $2300 bumper shouldn’t have to be re-welded but here I am. After it was installed the tech said the TSS sensor wouldn’t work I said that’s ok I don’t use that feature but that error doesn’t seem to allow any cruise control at all. Would there be a setting to get around it? I’ve got it turned off. I Unplugged it and a full screen shows up saying see a dealer. Would the other style of grill lower it? Enough?
  20. Feb 3, 2020 at 8:06 PM
    ringo
    ringo New Member
    Here’s a pic from the front.
  21. Feb 4, 2020 at 3:21 AM
    timsp8
    NY
    The dealer put the bumper on? Was it at your request or did they sell it that way? If they did it then they disabled a safety feature and if you didn’t sign a disclaimer agreeing to it, I’d tell them to fix it. Probably by getting a new bumper. Also the cruise will still work. Just have to hold the button when turn it on for 3 sec and it disables the radar cruise and makes it a regular cruise.
    AggiePhil and GODZILLA like this.
  22. Feb 4, 2020 at 4:58 AM
    I remember someone moved their TSS sensor to where I put the red dot. I think they glued it or taped it to the back of the grill surround.
  23. Feb 4, 2020 at 5:04 AM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    My understanding is the height of the sensor isnt as much of an issue as the angle is. Before I knew that, I had my DB Customz grille put on and it came with 4 extra washers on the top mounting bracket (angling it downward in anticipation of a lift I'm assuming). My PCS not available light would be on 50% of the time. Talking with them they said TSS sensor issues come from angling and not so much the height. That being said, I left it in anticipation that my lift/tires (that go on today) will adjust the issue by raising the sensor but the angle returning it more to center.
    You should be fine relocating it above or below the bull bar depending on how you angle (prop) it against whatever relocation bracket you get with washers. I wouldnt want to hack an already coated bumper.
    @ringo
  24. Feb 4, 2020 at 5:29 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
  25. Feb 4, 2020 at 6:27 AM
    18" TRD Off Road Wheels
    You might be able to use the new pro style grille. It moved the sensor down a bit, and it might have a clear shot under the bar. Like @timsp8 said, if they installed it and you didn't sign a waiver or request it, you might be able to get them to upgrade you to the pro grille for free.
  26. Feb 4, 2020 at 8:28 AM
    ringo
    ringo New Member
    The bumpers, rock guards, skid plates and headache rack we’re all part of the original purchase just before Christmas. I picked out what I wanted on the truck, They ordered it all (nothing mentioned about blocking that sensor) and the bumpers were just installed the other day. No waiver signed just a verbal (yeah no problem I don’t use it anyway). Ok so I’ll bring that relocation bracket idea to them, change the grill out or switch that bumper out and tell them to tell Fab Four they have a major design flaw on this model of bumper and hopefully come to an agreement without yelling. These are some options I didn’t have the other day. Thank you guys for the ideas and help processing this issue. Any other ideas are always appreciated. I’ll talk to the dealer today and keep you posted.
  27. Feb 4, 2020 at 8:31 AM
    I hope they will work with you, but because you requested the bumper they might just say that it was your obligation to research compatability of an aftermarket product. Go in friendly, because they technically don't have to do anything at this point. If they do help you out, then they are being really nice. Best of luck! :thumbsup:
    AggiePhil likes this.
  28. Feb 5, 2020 at 5:50 PM
    ringo
    ringo New Member
    Walked through it with the tech today. He says the TRD Pro grill will drop the sensor 4” which should fit under the bull bar. Parts quoted me $1250 CAD. Included 2 hours ($300) shop time to reprogram. And the sensor can be reinstalled in the new grill. I could push back for a better price or just order online and have them do the reprogramming. Any thoughts are always appreciated.
  29. Feb 5, 2020 at 6:40 PM
    Danman34
    Danman34 New Member
    Danny
    Hmmm. Pro grill drops the sensor 2”.
  30. Feb 5, 2020 at 7:05 PM
    ringo
    ringo New Member
    Oh boy. He sure pitched it good. I did mention the relocation bracket earlier to him. Maybe he was considering both?
