Replacing the water pump- how hard?
Discussion in '1st Gen Tundras (2000-2006)' started by Matty4wd, Apr 30, 2019.
  1. May 1, 2019 at 4:35 AM
    The Zerex I bought said not to add water. Or are you using that to flush to system? I was amazed at how much crud/debris was in my drain pan after I drained the coolant. No idea what it was. It took just over 3 gallons of Zerex to fill it back up.
    Matty4wd[OP] likes this.
  2. May 1, 2019 at 6:02 AM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    I think i also need to do a long travel suspension, rear leafs, bigger tires , and other maintenance since i got the hood open right ?
  3. May 1, 2019 at 6:56 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I usually buy the concentrate instead of pre-mixed.
  4. May 1, 2019 at 8:48 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Absolutely!!!!! It will be much easier to do since you have the radiator out already!!!!
  5. May 1, 2019 at 1:07 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    :rofl::rofl::rofl:
  6. May 1, 2019 at 1:31 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Curious if you took the front body off the trk for changing out the water pump?
  7. May 1, 2019 at 1:52 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    It was 'Hard' for days.
  8. May 1, 2019 at 5:01 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Nah. Just the stuff I listed. The suspension and tires take second priority behind mechanicals.
    But if you insist. Hoot!
  9. May 1, 2019 at 10:36 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    While you're at it, long travel opens up some space to make header install easier. :D
    Hope you get back on the road soon.
  10. May 5, 2019 at 4:43 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    If you don't mind me saying, that last move to retire until your friend comes is called wisdom. I am confident you will know how to work on your baby in no time. Just watch your friend as closely as comfortable to him, and if possible video the finer parts. Good luck.
    Sunnier and Matty4wd[OP] like this.
  11. May 23, 2019 at 5:36 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Well... my friend flaked on me! Some friend right.. stay tuned, ive been doing it myself
  12. May 23, 2019 at 6:35 AM
    Your friend :mad:
    You:thumbsup::smokertransformer:
    Sunnier and Matty4wd[QUOTED][OP] like this.
  13. May 23, 2019 at 6:38 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Just take your time with it and triple check your work. You got it.
    Matty4wd[QUOTED][OP] likes this.
  14. May 23, 2019 at 11:06 AM
    marbleville
    Yep, last name too.
    State of Confusion
    Remember there are videos on YouTube that can show the way if things start appearing dicey. Take a break and check them out when you feel over your head in the matter. The breather and instructions are sure to clear your mind of any apprehension.:muscleflexing:
  15. May 23, 2019 at 9:17 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    WHOOP WHOOP, got it, but have to get a new radiator since the brass fitting is stripped, bought it and will install this weekend
    TX-TRD1stGEN, FirstGenVol and Sunnier like this.
  16. May 23, 2019 at 11:43 PM
    Sunnier
    Sunny
    San Diego, CA
    Well, yes. Of course. :cool:
    Good going, Matt! :thumbsup:
