Is this normal? Transmission grab when accelerating
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundraal, Apr 28, 2019.
  1. Apr 28, 2019 at 2:35 PM
    tundraal
    tundraal [OP] New Member
    So I am starting to get use to driving my 2019 SR5 and noticed something odd about the transmission. When I go from coasting on the highway without much throttle, to adding throttle again, the truck seems to clunk. It feels like the gear catches/engages. For example, if you are going down a hill and have no throttle, and the when you get back on the throttle it grabs hard. It's pretty abrupt and I've never noticed this on any other vehicle. Is this just normal for the Tundra's six speed, or something I should take to the dealer?
  2. Apr 28, 2019 at 2:49 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Is it stock or lifted? What mods have you done?
  3. Apr 28, 2019 at 2:55 PM
    tundraal
    It's stock... I noticed there is lots of back-pressure when you let off the throttle and just coast. When you get back on the gas, it engages all at once.
  4. Apr 28, 2019 at 3:00 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    my 2007 and my former 2014 does/did the same thing.
  5. Apr 28, 2019 at 3:18 PM
    Mr Badwrench
    Mr Badwrench New Member
    I notice it a little too. These six speeds take some getting-used-to, I guess. I have learned how to drive it in such a way that I can manage the "grab" feeling.
    15whtrd likes this.
  6. Apr 28, 2019 at 4:14 PM
    timsp8
    NY
    My 2018 does it.
  7. Apr 28, 2019 at 4:41 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    That's what you call the torque converter. When you release from the throttle it disengages then when you touch the gas again it engages. It's not shifting gears.
  8. Apr 28, 2019 at 5:19 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    My 2019 does it also. My previous truck had a standard transmission, so the sounds and feel of a six speed automatic is very different for me. I am glad you posted this so I know it is not a problem with the truck.
  9. Apr 29, 2019 at 5:29 AM
    zitman11
    zitman11 New Member
    I have a, new-to-me, 2017 and occasionally feel something similar when getting back on it after slowing to turn corners. Will have to see if I feel it at highway speeds also.
  10. Apr 29, 2019 at 9:34 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    The snappy throttle response in TOW/HAUL can add to this sensation. It is a bit jumpy off idle which took a bit of getting used to but I like it.
  11. Apr 29, 2019 at 9:42 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Mine does this as well. My 2012 didn’t do it nearly as bad though.
