DIY Timbren Installation
Discussion in 'Towing & Hauling' started by WFD473, Apr 22, 2019.
  1. Apr 22, 2019 at 6:53 PM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    With camping season coming up, I decided to install a set of Timbren's in the rear to combat some of the squat when towing our camper. These basically replace the rear bump stops with something much beefier. It was pretty easy and required minimal tools.
    Here you can see the factory bump stop clamped onto the leaf spring. This is what gets replaced.
    This is from underneath the U shaped bolts. I soaked the nuts down with some PB Blaster the day before to help break down some of the rust. The nuts are 21mm. You can pretty much just loosen them without taking them completely off and remove and replace the bump stops, but I took the bolts completely off and cleaned the threads with my bench grinder.
    Factory vs. Timbren SES
    Here you see once the nuts and bottom plate removed, the U bolts simply slide up to be cleaned if you wish.
    Factory
    Timbren's
    Reverse the process to install them and torque the nuts to spec. As you can see, there's maybe an inch gap in between the Timbren's and the frame. When unloaded, the ride is unaffected. But once a load is placed in the bed or you tow, the frame sits on the Timbren's and the squat is greatly reduced. My first ride with them towing is coming up soon, so I will update with the results.
  2. Apr 22, 2019 at 6:58 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I was looking at these earlier today, comparing with sumo springs. I’m curious to see how you like them after a little bit.
  3. Apr 22, 2019 at 7:07 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Yeah, I was going back and forth between those as well. I went with the Timbren's just based on peoples experience with them. They seem a little more heavy duty compared to the sumo springs. We'll see...
  4. Apr 22, 2019 at 7:13 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I worry about how much different they would feel off road, if they would make for a harsh ride
  5. Apr 22, 2019 at 7:13 PM
    15whtrd
    15whtrd Mr. Blonde
    Heads up, you can bolt on a super bump in place of the timbren if you’d like to gain some travel back. Then bolt the timbren back in when you need, for load. @JoshuaA did this.
    Smiley and JoshuaA like this.
  6. Apr 22, 2019 at 7:13 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    Something that should go along with the sale of items like these should be a replacement set of U-bolts. They may say it in the fine print, they may not but those bolts are a ONE TIME usage item. Once they are installed and torqued they should not be removed and than reused. Just a little safety issue you or anybody else looking to add something that is attached like the Timbrens are.
    On the other hand, how do you like them? Have you put them to work yet?
    Black Wolf and 15whtrd like this.
  7. Apr 22, 2019 at 7:18 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I have 1.5” shackles so I use 1.5” spacers with my Timbrens. When not towing, I remove the spacers. The footing stays so it’s just a matter of unbolting and bolting. The increased space means it never hits in day-to-day driving. However, those who aren’t lifted in the back may find hitting the Timbrens a little jarring, which you’d only notice over speed bumps and potholes if that.
    For people that tow all year and with varying weights, I’d go airbags.
    And for people with lighter tongue weights, I’d go Sumos which are more forgiving.
    Timbrens are pretty solid. You’d want a heavy TW riding on them all the time to prevent shudder. Bouncing up and down off of them would not be fun.
  8. Apr 22, 2019 at 7:21 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I can’t remember who does that but I went the spacer route instead as I’m up 1.5” higher in the back. If I was stock height, I would definitely switch them out with shorter Superbumps when not towing, the solution to avoid smacking Timbrens.
    15whtrd[QUOTED] likes this.
  9. Apr 22, 2019 at 7:25 PM
    Krabage
    Krabage New Member
    2014 DC TRD
    Ive had the front and rear timbrens for four seasons now along with the trd rear sway bar. If you want your truck level when you tow i highly recommend them. 6k lb capacity which gets the job done.
    WFD473[OP] likes this.
  10. Apr 27, 2019 at 1:45 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    So I picked up the camper from storage and brought it home to de-winterize it. It was about a 20 mile drive and had a chance to test the timbren's. I'm happy to say it drove GREAT. They kept the truck level and it felt stable the whole time. If anyone's on the fence on whether or not to get these, I highly recommend them. 20190427_095924.jpg
    plumber802 and Mnorris1206 like this.
  11. May 22, 2019 at 4:20 PM
    Reedhoppa
    Reedhoppa New Member
    Reed
    Nisswa, MN
    2019 5.7L Tundra TRD Off Road Double Cab
    Extang Encore Solid Folding Tonneau
    Thanks for the info. I’m picking up my new 26’ trailer next week and am considering air bags or Timbrens. This info will help. I had airbags in a previous Tacoma but they didn’t hold up in -20 degree Minnesota winters.
  12. May 22, 2019 at 4:34 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Great post! I went with the black sumo springs last year.
    Prior to installing my family and I went to the river for a load of river rock.
    I hauled them in the bed and on the way home I had to take it easy due to sway.
    After install we went back a few weeks later, the difference was night and day.
    The truck felt well planted.
  13. May 22, 2019 at 4:38 PM
    Mnorris1206
    08 tundra
    I love mine but like others have said. It can be a little bumpy going done the road. But with my lift kit I never feel them unless I have my camper in tow but you may feel them hit going over speed bumps. But over all I recommend them to anyone hauling an decent size load. My camper hooked up with them on. Screenshot_20190522-193741_Gallery.jpg
    WFD473[QUOTED][OP] and Smiley like this.
  14. May 22, 2019 at 4:40 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Nice truck! Tough.
    Mnorris1206[QUOTED] likes this.
  15. May 22, 2019 at 4:42 PM
    Mnorris1206
    08 tundra
    Thanks ! It's been a project for a few yrs. Not completely done yet but getting close. I see you have an 08 as well best yr yet
    Smiley[QUOTED] likes this.
  16. May 22, 2019 at 4:44 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    She's been really good to me!
    I've done the ECGS bushing upgrade and brake pads.
    I need to replace the passenger side valve cover gasket due to an oily plug.
    Mnorris1206 likes this.
  17. May 22, 2019 at 4:46 PM
    Mnorris1206
    08 tundra
    Nice is that all the maintenance? I haven't had much she is my baby only 82k mile on her now . But I'm sure some things will need to be done around 100 k
    TRD ROB likes this.
  18. May 22, 2019 at 4:49 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Yes besides the usual oil and grease.
    I run the toytec shackles at 1.5 so the sumos are about an inch below the contact point.
  19. May 22, 2019 at 4:51 PM
    Mnorris1206
    08 tundra
    Cool ! I was almost about to do air ride because I also want an air horn but it was going to be alot of money so I passed lol
  20. May 22, 2019 at 4:57 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Forgot, I replaced the support bearing and the rear u-joints.
  21. May 22, 2019 at 4:59 PM
    Mnorris1206
    08 tundra
    What kinda miles you have ? And do you drive it every day ?
  22. May 22, 2019 at 5:00 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    I have 131,000 it's my daily.
  23. May 22, 2019 at 5:04 PM
    Mnorris1206
    08 tundra
    I have seen some do plugs at 100k I'm thinking that also and maybe a trans flush because I do tow a camper with it.
  24. May 22, 2019 at 5:08 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    I'm due for tires probably after summer.
    I really like the Cooper at3 xlt and the Falken wildpeak.
    The price says Falken but the weight says Cooper???
  25. May 22, 2019 at 5:13 PM
    Mnorris1206
    08 tundra
    I love my bfgs but I have also looked at the cooper stt pro but I have heard they do not last long when pulling a camper but them again not much does.
  26. May 22, 2019 at 7:45 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thanks! Yeah, I was going back and forth with those. Glad to hear they worked out for you.
  27. Jun 5, 2019 at 8:07 PM
    RJN55
    RJN55 New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    I like my timbrens as well. Had them on my 2007, moved them to my 2018. Definitely make my ride more stable. I pull a gooseneck stock trailer (draft horses) that can hit 10,000 lbs and a 28 foot bumper pull triaxle cargo trailer (8.5 wide, 8.5 high, 28 feet on floor) loaded with show equipment. Loaded it runs about 9,000 lbs. Use weight distributing hitch of course.
  28. Jul 23, 2019 at 8:34 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Sweet!! Glad they're working out for you guys. It's reassuring to know they work so well for so long. Thanks!
  29. Nov 5, 2019 at 7:02 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    Joshua do you need to jack up the truck to unbolt the timbern and the spacer
