BlueBottle's '16 Plat CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueBottle, Sep 24, 2016.
  1. Oct 14, 2016 at 8:39 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    @Bannock452 some of the pictures are from my iPhone 6s but the sharper pictures are from my Sony a6000 with a 16mm 2.8 prime lens. It's a great camera setup.
    Bannock452 likes this.
  2. Oct 14, 2016 at 7:18 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Teaser Shot.....
  3. Oct 14, 2016 at 7:28 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Looks good man! The colors are pretty close.
  4. Oct 14, 2016 at 8:17 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Excellent build so far! Love all the mods you have done. My favorite is the wheels. Nice color choice.
    BlueBottle[OP] likes this.
  5. Oct 14, 2016 at 8:23 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice build, love the new wheels, can't wait to see more pics once you get them all set up.
  6. Oct 14, 2016 at 9:08 PM
    PMG
    PMG New Member
    Can't wait to see the wheels, all of them, on the truck..
    Is it me or does it seem a bit nose up?
    PMG
  7. Oct 14, 2016 at 9:14 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Im uploading some pics I just took tonight.. will be up soon! Stand By.
    It looks like the nose is higher, but not by measurement.. The rear was 1/4" higher when I measured it. Im still waiting for the suspension to settle and I will take new measurements.
    I gained 3" lift up front and 1.5" in rear so it has more rake than a TRD PRO still.. It does look nose high for some reason though...
    NewImprovedRon and dcsleeper408 like this.
  8. Oct 14, 2016 at 9:21 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Needs supercharger to weigh it down in the front! ;)
    AnonVet and BlueBottle[OP] like this.
  9. Oct 14, 2016 at 9:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I finally got my wheels + tires + alignment in today.
    Wheels : FN BFD Wheels 18x9+12 Gunmetal (weighed 22.5lbs on my bathroom scale)
    Tires : Falken Wildpeak AT3 305/65R18
    Suspension : LRO 3" front spacer - CB +3 Shackles (1.5" of lift)
    These wheels/tire combo took very little weights to balance them! I was surprised.
    • Wheel 1 - 3oz
    • Wheel 2 - 1.5oz
    • Wheel 3 - 1oz
    • Wheel 4 - NOTHING!
    Got them installed at my usual spot @ Auto Innovations.
    On the rack!
    Some wet pics...
    1287EF8F-0577-45CE-BC7A-B604340DA461_zps_c038ee6ed2f8d95c288d0366e840028e40f29c84.jpg
    54553001-4C85-4CFB-B27D-1D3F6D7CD495_zps_f9dec1efa1c1bf8db93de43e8cbf4ef5188a76b9.jpg
    33B99B0D-A5CC-437E-98B0-CB460B5655BF_zps_b9110c2bdd05870dc9b31940f4f51b0f60f8fd08.jpg
    D286B106-093A-41BF-BEE6-BC5E52062592_zps_23a89cbb130063c5096cd4aa6821c5df1e1bce89.jpg
    A60EAB7C-49DC-40E4-A170-3E0BB4AE7311_zps_53bc613bff088275cbf2df3192aadb9b02b29a80.jpg
    FF43F937-F387-4B0B-9F6E-8A16BE2CE169_zps_749d2342a387d805c1f2a95928acdeadd73af73d.jpg
    1st impressions :
    So my biggest concern was rubbing.. well my tires does slightly come in contact with both my front liner & rear mud flap(this is with the front flap removed already). I will work on trimming the plastics so hopefully I can get full motion without contact.
    I don't feel much power loss with this setup. These wheels are pretty light(one of the reasons I chose them) so that may have a big impact on the feel. So far the tires are smooth and quiet. The ride actually got more comfortable compared to my stock 20's. It soaks up bumps much better due to the bigger tire I'm sure.
    I wasn't sure how the gunmetal would look on magnetic gray, but it looks better then I thought. It doesn't match perfectly but it doesn't clash either.
    I'm glad I went with 305/65R18's instead of 275/70R18. This tire sits really good on this wheel size. Also fills the well pretty good.
  10. Oct 14, 2016 at 10:03 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :facepalm:
    Darth Tundra likes this.
  11. Oct 15, 2016 at 7:07 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Transformation picture
    Stock/lift/lift+wheels+tires
    626A9E28-A7A4-4EA4-9997-9E83D37BDB96_zps_b56fb32a8eb96fe362b9d5d974120b362de19e21.jpg
  12. Oct 15, 2016 at 7:30 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    Drool drool.....
    Will 295/70/18 smaller or bigger than yours?
  13. Oct 15, 2016 at 8:21 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    295/70 is almost 1" taller but 1/2" narrower. Im guessing it will fit very similar. A lot of people run that size. I just chose 305 because the tire I wanted was in that size.
  14. Oct 15, 2016 at 9:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Looking damn good. It looked a little nose high right after lift but with the new wheels I think it looks perfectly level.
    dcsleeper408 and BlueBottle[OP] like this.
  15. Oct 15, 2016 at 5:51 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Liner clearance mod
    So ... after driving the truck for a day, I realized I was rubbing everywhere especially when turning the wheel & reversing. I could not find a DIY for 14+ trucks which has a different liner from the earlier years. So I though I would take some pictures as I trimmed & adjusted the liner. I was also rubbing on the rear mud flaps but not as bad as the front. I removed the rear flaps for now and will trim it at a later time.
    Here is where I was rubbing with my setup. Keep in mind everyone's setup will rub at a different spot depending on tire size, lift and wheel offset. (this is with the front flap already removed)
    AD4FB0D7-1842-4CD4-BB27-5B3241BBCFEC_zps_437c58e2a5b7f539038c2694cbff1ded8d22451d.jpg
    Here is the front liner removed showing what I cut. I used a dremel to cut it so it would be quick and clean. This renders the two bottom screws useless but the rest of the screws are sufficient to hold the liner in place.
    15EC9970-E4CD-42D3-A0F7-490D23BB8374_zps_a76be7bfa5dee17800591fd804dae2b4c0fd8ff6.jpg
    52433F5C-8322-49EC-A826-65DA644EC04F_zps_e99a8bd1448a101ea4487f210848b9fdf331347e.jpg
    Here is the panel re-installed in the truck. I cut a little too much, if I were to do it again, I could have cut less.
    B4CD3B22-31A3-46CF-84E5-DECA04D8CB6C_zps_b758b4214b6859db4de88ca2f12d255cb45963df.jpg
    This shows the bottom of the liner and how I used the 2 screws(1 silver, 1 black) to secure the bottom. I drilled a new hole for the black one almost an inch back to push the liner forward away from the tires. I used the washer for the silver big screw to hold the liner.
    33C684D8-4287-48DC-A304-C87A5BCCC361_zps_9ae52b6f3b90c0a5c0928abdd0f54afb85bf998c.jpg
    Here is my new clearance
    45BBFF43-398B-4313-BC77-424EDCB8BFB9_zps_2484d57777f0b7a1e24e6d63ccdc3a8506bf249e.jpg
    I was also rubbing on the rear mud flaps with my wheel turned.
    56732852-EF70-411F-99FB-441803FB7F14_zps_fc7affd770ed66be874f470ffe5be82caff2ad01.jpg
    I just removed it for now until I figure how to trim it.
    8FBE6F58-7DE8-419B-BE66-77FFB8C1358B_zps_4516d1824d3f84b970e7a61383f6bc6b5d0a3e24.jpg
    This also shows how close it is to the cab mount. For those that is wondering how much clearance you would have with this setup.
    C8C34718-ED08-4AD0-98E6-D57D199DEC32_zps_17d273d930ba8e00df1f85ba5d7c7ef398ef2a49.jpg
    Now you are done with 1 side & just repeat on the other.
    I test drove it trying to make it rub and now I do NOT rub at all. backing up full turn on a hill, u-turns, lock to lock, no rubbing at all with this setup! So for those that are wondering how much work it takes to clear 33's with low offset wheels, it took me 20 minutes to do both sides!
    *credit to @Tacogeuse for this mod.
    Watt maker and MotoTundra like this.
  16. Oct 15, 2016 at 6:48 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    i ended up needing to trim about the same as you did for my front plastic piece. And I definitely trimmed quite a bit of metal fender on the rear and did the CMC so I could fit my 35s with barley 2" of lift. I hated cutting so much but now you can't tell and I got the clearance with no rubbing off-road exactly how I wanted so I'm happy.
  17. Oct 16, 2016 at 8:08 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I wanted to put my rear flaps back on since its been raining here lately. I cut a square where I was seeing rub marks so I was still able to retain all the bolts holding down the flap.
    328103C1-6969-4738-B511-070B318D7CE6_zps_d1237f007904e357b6335b9d89f4aab320e98b85.jpg
    821D41B7-6890-4675-A0A4-6A16CC8BF14F_zps_9c1eb5cf378f2c2d7a70fe62750bc10554a94550.jpg
    I didn't get a chance to drive it yet to make sure it is enough clearance. I will check back in once I test it.
    Im looking into possibly getting some flares to add some coverage on my tires. I was thinking of getting some oem or oem style flares. I saw some oem style extended flares? Any thoughts on what flares I should get?
    Flyinryank likes this.
  18. Oct 19, 2016 at 7:33 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I am still slightly rubbing on my flap I believe. Not enough to do anything about it for now but I'm sure if I cut off the inner part of that flap it would be gone.
    Anyway here's 1 more pic just cause I have her a bath!
    B1F294C8-4B03-475A-B9CF-80A0CF4CD555_zps_97aee78f36e1fd70defb7dfcbaa862e2cd1b1454.jpg
  19. Oct 19, 2016 at 8:15 AM
    Bannock452
    Brandon
    Murrieta, CA
    Keep the pix comin! N I like those tires! And that f2.8 too:headbang:
  20. Oct 19, 2016 at 10:11 AM
    #50
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sorry to throw a curve ball on you. Same camera but different lens! 50mm taken at F1.8! =)
    dcsleeper408 likes this.
  21. Oct 20, 2016 at 1:11 PM
    #51
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    Not my camera but the last interior picture was taken with a Sony ILCE-6000, f/2.8 lens, ISO speed 800, focal length 16.0mm and no flash. That info is contained in the metafile of the image posted. Camera around around $700 at Best Buy or Amazon and probably a dozen others.
  22. Oct 20, 2016 at 1:30 PM
    #52
    Bannock452
    Brandon
    Murrieta, CA
    Thank you Mike! I appreciate the info! I didn't know you can look at the photo specs in or on this forum. Good to know though for future!
    I recently purchased the sony a6300 too and have been playing with new lenses and settings! So far I love the camera and the 4k video is unreal!
  23. Oct 20, 2016 at 3:02 PM
    #53
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nice. I highly recommend getting the 16mm 2.8 lens and 50mm 1.8. Really brings out the best out the camera.
  24. Oct 23, 2016 at 3:25 PM
    #54
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Got rid of the last chrome bit on the exterior of the truck. The Platinum badge is now dipped black!
    6E6A3A22-1D5B-45B0-B520-C4E12D7713B6_zps_46a60ebb50358cd9391f212c05dc896dbba49c22.jpg
    2AF313B9-A382-4D90-BF06-56A0CD907751_zps_e418ff0776797f46ad7f5805e2b23d36d3b6be2c.jpg
  25. Oct 23, 2016 at 3:41 PM
    #55
    TheBeast
    TheBeast The Beach
    looks great ! done with taste for sure.
  26. Oct 23, 2016 at 4:25 PM
    #56
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks! I need to get rid of the chrome in my headlamps. When I do my retro that chrome will be gone.
    TheBeast[QUOTED] likes this.
  27. Oct 26, 2016 at 8:53 AM
    #57
    TigerTanker
    TigerTanker Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    Wow, what a nice thread man! I'll be coming back for more. Hey, if you figure out the reboot crap, let me know.
  28. Oct 26, 2016 at 12:32 PM
    #58
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks! I replied to the other thread. I deleted my entune app and re paired my phone. Haven't had an issue so far.
    *update* I ordered a set of bushwhackers extend a fender. Should get t next week. Hoping to cover my tires sticking out of the body. Truck gets crap from the tires too easily with the tires sticking out.
  29. Oct 26, 2016 at 12:34 PM
    #59
    TigerTanker
    Tacoma WA
    none so far
    I just ordered the same antenna you have. The stock wire hangar thingy just looks ridiculous.
  30. Oct 26, 2016 at 8:43 PM
    #60
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You will like it.. I have taken it through drive thru car washes and its fine unlike the oem. Also my FM signal is still pretty good but keep in mind I live in the metro area.
    FallenEagle likes this.
