Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Oct 15, 2016 at 6:14 AM
    #601
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Here's my contribution to this thread
    18x9 +12 FN BFD wheels - Gunmetal Gray (weight 22.5 on my scale)
    305/65R18 Falken Wildpeak AT3
    3/1.5 lift
    D286B106-093A-41BF-BEE6-BC5E52062592_zps_23a89cbb130063c5096cd4aa6821c5df1e1bce89.jpg
    FF43F937-F387-4B0B-9F6E-8A16BE2CE169_zps_749d2342a387d805c1f2a95928acdeadd73af73d.jpg
    54553001-4C85-4CFB-B27D-1D3F6D7CD495_zps_f9dec1efa1c1bf8db93de43e8cbf4ef5188a76b9.jpg
    mjime714 and T-Rex266 like this.
  2. Oct 22, 2016 at 3:47 PM
    #602
    Royalpeeps
    Royalpeeps Awesome!!!
    Chad
    2017 Blazing Blue Pear Tundra SR5 TRD Package
    20" Fuel Vapor wheels 35" Toyo A/T II Tires 3 inch Toytec Boss kit with SPC UCA NFAB Wheel to Wheel Black Textured Nurf Bars OCD Center Storage Organizer and tray
    Liking the looks of that setup. Those DropStarts look nice. How you liking them? What's your lift and what's the offset on the rims and tire size? Any rubbing? Sorry for all the questions but I'm trying to figure out what to put on mine. Thanks.
  3. Oct 24, 2016 at 4:36 AM
    #603
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have a 2017 Tundra Platinum 4x4. Running a 7" pro comp lift with Fox 2.5" Coil-overs, Icon Upper Control Arms, Ekstrom Designs coachbuilder shim, steering end and billet shackle extensions. I stayed all the parts I have first because running my tire size would be almost problematic without doing the upgraded components I have. I'm running Fuel 22"x12" forged wheels with a -51 offset. Tire are Toyo Open Country M/T 37/22/13.5. I wanted a 13.5 tire to help give the rims more sidewall protection. Typically most 12" wide one pc or two pc rims are a -44 offset but Forged having a bigger lip and offset. I also decided on spiked lug nuts for looks and you have to have a special extra long socket to get them off.
    Biby likes this.
  4. Oct 24, 2016 at 9:49 AM
    #604
    Royalpeeps
    Chad
    @Roman do you guys do bushwackers to color match? Might get some after my lift, new tires a wheels. Depends on how it looks without.
  5. Oct 24, 2016 at 1:09 PM
    #605
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    No sir. At least not currently. The only ones we can get are the unpainted ones.
  6. Oct 24, 2016 at 1:12 PM
    #606
    Royalpeeps
    Chad
    Ah gotcha. Shucks. But can't you get your painter that paints the TDR Pro Gilles to paint them?
  7. Oct 24, 2016 at 1:17 PM
    #607
    Roman
    Roman
    Franklin, TN
    I wish he could. For whatever reason, he has elected not to do the flares.
  8. Oct 24, 2016 at 1:17 PM
    #608
    Royalpeeps
    Chad
    Man. That sucks. Oh well. Still can't wait to get my grille and get that on. Will have to figure out the flares when the time comes. Thanks.
    Roman likes this.
  9. Oct 28, 2016 at 8:19 PM
    #609
    ytank1
    ytank1 New Member
    MD
    Ok Im in need of some help with tire and rime size for the set up that I want. Went to a local shop and told them I wanted a aggressive stance but not looking to stick out past an inch out side of fender. I am getting a 3/1 leveling kit installed and this is what they recommended. Rim : 20x9 5x5.5 5x150 + 1mm offset 5" backspacing. Tires : 275/65/20 34.1 tall x 11 wide. My question is the rims and tires that the shop is recommending seems to be the same size as the stock rims and tires that came on the crewmax. How will that give me a aggressive stance and also with the leveling kit do I need to look to go bigger to fill in the wheel well and if so how big can I go without excessive trimming and or cutting. Any advice will be greatly appreciated. Thanks guys.
  10. Oct 28, 2016 at 8:28 PM
    #610
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Stock 20s are +50 offset. The +1 offset the shop is recommending will stick out 2 inches further than stock. I had 275/65/20s with +18 offset and it only stock out past the fender a little bit. Your +1s will stick out a bit further. But, my biggest complaint about the 275/65/20s is that they looked too skinny. Before my lift, I had 275/60/20s and it looked ok, but once lifted, it didn't look right IMO. I took those off and went to a 295/60/20. Same overall diameter, just wider.
    Be prepaid to do some trimming with the +1 offset.
    ytank1 likes this.
  11. Oct 28, 2016 at 8:46 PM
    #611
    Royalpeeps
    Chad
    Take a look at my truck and my setup.
    ytank1 likes this.
  12. Oct 29, 2016 at 9:41 PM
    #612
    ytank1
    ytank1 New Member
    MD
    Thanks for the info. And I didn't even think about what you said. I guess I have to look for beefier tires because I don't like the look of the huge gap around the wheel. Thanks again and Ill post some pics as soon as I get the truck looking right!
  13. Oct 29, 2016 at 9:42 PM
    #613
    ytank1
    ytank1 New Member
    MD
    Nice color and set up!
  14. Oct 29, 2016 at 9:42 PM
    #614
    Royalpeeps
    Chad
    Thanks.
  15. Oct 30, 2016 at 8:46 PM
    #615
    Phlonx
    Phlonx New Member
    White 2012 Tundra Limited RWD
    Have been following this thread a while now, thank you guys for all the great info! Almost done dialing in my setup. Can I get a few final opinions?
    2012 Tundra 2WD
    3/1 level kit
    20x9 Fuel Assault wheels
    295/60/20 Terra Grappler G2's
    Can I make it work with 1 offset? If that's questionable, can I make it work with 20 offset? These wheels are available in 1, 20, and -18.
    I rather not have to trim or remove anything at all, but minor plastic-only work may be OK.
    Thanks!
  16. Oct 30, 2016 at 9:20 PM
    #616
    Waterboyz
    Waterboyz New Member
    Fredericksburg VA
    2006 Silver Tundra X-SP Double Cab 2WD 18" Wheels
    OK, just got here. Yes, I already did the "New Member" thing.
    My apologies if this has been answered. If so, please post the linkee.
    2006 2WD just bought it with 110,000 miles.
    The factory placard states:
    P245/70R16
    The X-SP placard states:
    P275/55R18
    Currently on the front:
    P265/65R18
    Currently on the rear:
    P265/60R18
    Currently on the spare:
    P245/70R16
    Rim is 18x9?
    Wonder if the 'puter got updated for the 18's?
    HoleeSheet am I confused.
    I need tires.
    Thinking I would get some Winter tires now and in the Spring get some Summer tires. I can find some tire/rim for sale on Craig's List. But I have no idea of interchangeability.
    Do I get some beater rims for Winter and keep the current rims for Summer? First time living this far North (Fredericksburg VA).
    What to do about the 16" spare?
    Suggestions?
    Opinions?
    Thoughts?
    Ideas?
  17. Oct 31, 2016 at 8:37 AM
    #617
    ytank1
    ytank1 New Member
    MD
    How much should I expect to trim with the 285s or 295 ?
  18. Oct 31, 2016 at 8:39 AM
    #618
    ytank1
    ytank1 New Member
    MD
    anyone with a set up of 3/2 level kit, 20x9 275/65/20 that can post some pics for reference before I go and pull the trigger on the mod please
  19. Oct 31, 2016 at 6:22 PM
    #619
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    There's not much of a difference between the stock tire diameter and what you have now. Personally, I would just go with an all-terrain rated by the Rubber Manufacturer's Association for severe snow use like the Falken A/T or BFG A/T and only have one set of wheels and tires. The spare tire is probably not safe to use anymore, throw it out. I believe in having a matching spare and doing five tire rotations.
    TheBeast likes this.
  20. Nov 6, 2016 at 9:14 PM
    #620
    polox40
    polox40 New Member
    2016 DC Limited
    LineX Toyota black running boards
  21. Nov 20, 2016 at 8:16 AM
    #621
    mccooj
    mccooj New Member
    2/0 leveling kit, 305/55R20's on BBS wheels
    I came across this thread researching tire sizes for my 2013. I've been running 305/55R20 Nitto Terra Grappler AT's on BBS wheels, 2" leveling kit (zero lift in back) with no spacers, no trimming, no rub. I've had them on for 50k miles and am about to replace them, not sure wether to go with this same size or a 295/60R20. I just thought I should post my setup in case others want to run this size but like me, don't want to run a lift.
  22. Nov 21, 2016 at 7:38 AM
    #622
    mraymyers1967
    mraymyers1967 New Member
    michael
    2017 Tundra TRD PRO cement
    20x9 0mm offset XD 820 Wheels 295/55/20 Nitto Ridge Grappler 2 coach builder shims per side in front 1" ready lift rear block
  23. Nov 29, 2016 at 5:35 PM
    #623
    tbillbro
    tbillbro New Member
    Brigantine NJ
    2015 Tundra 4x4 SR5 DBL CAB 5.7L V8
    Going with a similar set up. I was wondering about rubbing issues with that tire size and backspacing?
  24. Nov 30, 2016 at 7:54 PM
    #624
    Jstar
    Jstar New Member
    2013 Tundra TSS
    3/1 leveling kit and MasterCraft MXT 35x12.50x20
    My wife's truck....3/1 lift with MasterCraft 35x12.50x20
    Had to remove front mud flaps and shave a little. No rubbing at all now.
    DalTee, Sixpack and zcarpenter92 like this.
  25. Dec 3, 2016 at 11:11 AM
    #625
    guscrew
    guscrew New Member
    Grant
    2004 Tundra
    Leveling Kit, Bilsteins, Level 8 MK6 wheels, BFG tires
    I needed new tires anyway so I thought I'd go ahead and do the Level 8 MK6 wheel with BFG tires, leveling kit and Bilstein shocks front and rear. Really enjoying the setup, and it sure changed the look of the truck!
    allenk808, odom117, Crafty and 5 others like this.
  26. Dec 4, 2016 at 6:22 PM
    #626
    tbillbro
    tbillbro New Member
    Brigantine NJ
    What
    What is your wheel backspacing?
  27. Dec 4, 2016 at 6:32 PM
    #627
    computeruser6
    Dirk
    Escondido
    Got some new LT285/75R18 Nitto Exo Grapplers to replace the BFG A/Ts. No rubbing with stock wheels and Fox 2.0 coilovers set at 2.5" of lift in the front.
  28. Dec 10, 2016 at 9:07 PM
    #628
    509Tundra
    509Tundra New Member
    2014 Toyota Tundra Platinum
    Weather Tech Mats, Light Bar in front Bumper, Bedliner, Tri-fold, 3-1" Low Range Off-Road leveling kit, MB 352 Wheels, 295/70/18 Cooper ST MAXX tires, shorty antenna...
    Low Range Off-Road 3-1 leveling Kit
    Cooper ST MAXX 295/70/18
    MB 352 wheels 18x9 et25
    Watt maker, Voyagermike and T-Rex266 like this.
  29. Dec 12, 2016 at 8:31 PM
    #629
    Mcknasty
    Mcknasty New Member
    2004 Tundra DC
    Hey y'all, new here and had some questions. Has anyone removed the stock fender flares? They make my tires look tiny but I'm concerned about the holes in the fender wall. Should be installing a 3" lift soon and trying to fit some 33" tires under there. IMG_0321.jpgIMG_0438.jpg
  30. Dec 17, 2016 at 8:19 PM
    #630
    R41mag
    R41mag New Member
    Lots of great information on this page. I've been researching until my eyes bleed....here's my question.
    I have a 2014 tundra crewmax limited, with a 3 inch lift. I want to keep my stock wheels (20 inch with 60mm offset). Will 295/65r20s fit without rubbing? Or, what tire size can I use without rubbing?
