P&P Engineering rock slider group buy
Discussion in 'Deals & Group Buys' started by mac11, Jan 25, 2019.
Thread Status:
Not open for further replies.
  1. Apr 8, 2019 at 3:55 PM
    #421
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Ok thanks. Sorry for all the confusion. I’d be willing to help you sell them locally if that helps:cheers:
  2. Apr 8, 2019 at 4:20 PM
    #422
    mac11
    mac11 [OP] New Member
    Warsaw, Indiana
    It's my fault. I wrote it down wrong. We'll get it fixed. Let me get in touch with the person who wanted those steps before making any decisions.
    jmevis[QUOTED] likes this.
  3. Apr 8, 2019 at 5:22 PM
    #423
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Got mine today and to say I'm happy would be a understatement....
    I'm ecstatic!
    They arrived 100% perfect.
    I broke the end 2x4 when I was loading it in my truck. But absolutely NO DAMAGE!
    Looking at a picture does no justice. In person these are RIDICULOUSLY SICK!!!
    Can't wait to get them on the truck. Such a well done job @mac11
    Thanks for killing it with a badass product for a badass price!!!
    :cheers:
  4. Apr 9, 2019 at 12:55 PM
    #424
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    That washer with ring I used is about as thick as the backing plate with the ring welded to it. But yes, it doesn't have the same surface area as the backing plate. I'm not going to worry about it, it is only one out of four. Anyways, thanks for the concern, I'm sure you're right and it is a bit less sturdy.
  5. Apr 9, 2019 at 4:20 PM
    #425
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    So I installed my sliders today and came across similar line obstruction. I was in no hurry to get these done so I took my time. My sliders are lined which makes it a little more difficult to get the backplate collar to fully insert into the slider holes that have liner in them. When I saw the lines that you had trouble with I thought it wouldn't fit either and I'd have to come up with a similar remedy. But again, just patience, and careful massaging of the lines, sliders, and backplates, and eventually it all lined up perfect. It was tight but it does work. I left everything loose, then tightened bit by bit until they fit. I also added pieces of sticky rubber foam wherever the lines contacted the backplates and all is happy. So, you probably can get yours to fit with the backplate too, I'm theorizing.
    IMG_20190409_124522~2.jpg IMG_20190409_115526~2.jpg IMG_20190409_144443~2.jpg IMG_20190409_150455~2.jpg IMG_20190409_150254~2.jpg IMG_20190409_150338~2.jpg
    Overall it was very easy to install these, I just used 2 jackstands and an atv stand and drove up on ramps. I also took the ebrake bracket off and flipped it upside down and it adjusted very nicely from there.
    @mac11
    I am very impressed with the craftsmanship and quality of these sliders. They don't budge a millimeter when I step on them or jack up the truck with them ...no problem! Absolutely Awesome.
    Thanks again!
    Jmz
  6. Apr 10, 2019 at 8:49 AM
    #426
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Great, thanks for the info! On my truck, there wasn't any room behind the lines to slide the backing plate behind them. Did you bend them?
    Toyotoholic[QUOTED] likes this.
  7. Apr 10, 2019 at 8:58 AM
    #427
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Yes, very carefully. But they will move enough to get you where you need to be. Again when I first looked at it, I thought it would never fit.
    TundraPro2019[QUOTED] likes this.
  8. Apr 10, 2019 at 4:43 PM
    #428
    mac11
    Warsaw, Indiana
    Sorry I've been slacking on the updates for round 2. Been really burning it at both ends lately. Trying to keep on top of the production aspect of this and prepare to Argent a couple events in May as a vendor. Come see us at jamboree in Texas for the Toyota side with our 3rd Gen tacoma or in Moab for for the Nissan side with our V8 swapped xterra.
    We have the coated sliders ready to ship off to powder. We'll be working on finishing up the last of the bar sliders tomorrow and Friday and Monday of necessary. I hope to get the first of the bare steel sliders out the door Friday depending on how we do tomorrow.
    There were a few that orders skids with their sliders. Most of those are cut and will get bent next week after we wrap the sliders. Bare steel & aluminum skids should start shipping by the next week and coated skids will go off to powder at that time.
  9. Apr 11, 2019 at 4:41 AM
    #429
    mac11
    Warsaw, Indiana
    We should be shipping a backing plate that looks like this to fit just that spot. If they're not being packed I'll send them out to anyone who didn't get one.
    If you Turn those bolts around so the heads are inside the frame they shouldn't touch the brake lines at all.
  10. Apr 11, 2019 at 5:30 AM
    #430
    Keisuketak
    Keisuketak New Member
    Santa Cruz, ca
    2016 CM 4x4
    @mac11 i didn’t get one of those plates
    mac11[OP] likes this.
  11. Apr 11, 2019 at 5:36 AM
    #431
    mac11
    Warsaw, Indiana
    @SG TRD Pictures below of the liner pictures via Toyotoholic. Thanks for those Pics.
  12. Apr 11, 2019 at 9:42 AM
    #432
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I thought about that but didn't want to see the nuts on the outside of the frame. Like I said, with a little patience, everything worked out perfectly. That new plate would make it a breeze!
    mac11[QUOTED][OP] likes this.
  13. Apr 11, 2019 at 9:50 AM
    #433
    mac11
    Warsaw, Indiana
    will get one sent out to you.
    Keisuketak[QUOTED] likes this.
  14. Apr 11, 2019 at 10:00 AM
    #434
    AYANG0003
    AYANG0003 New Member
    woohoo does that mean i should see mine shortly
  15. Apr 12, 2019 at 8:14 AM
    #435
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    stoked to get mine! Any ETA updates on the lined ones? Same as powder?
  16. Apr 12, 2019 at 9:37 AM
    #436
    mac11
    Warsaw, Indiana
    Same as power plus a week or so to line them after powder.
    jmevis and cantle[QUOTED] like this.
  17. Apr 15, 2019 at 2:10 PM
    #437
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Can you ship me one please?
  18. Apr 16, 2019 at 9:31 AM
    #438
    mac11
    Warsaw, Indiana
    will do
  19. Apr 16, 2019 at 9:38 AM
    #439
    Aj_sat
    Aj_sat New Member
    2015 Tundra
    Balanced paid for my round two order. Can’t wait!
  20. Apr 16, 2019 at 12:11 PM
    #440
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
    On a 2010 dc. The pic makes them look more like they are painted. You can easily tell it’s lined in person.
    Kiddnapped Tundra likes this.
  21. Apr 16, 2019 at 4:42 PM
    #441
    SG TRD
    SG TRD New Member
    Thank you for the pics. does the flared out part extend to the rear wheel alowing one to access the bed?
  22. Apr 16, 2019 at 5:46 PM
    #442
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Yes- I asked same??? Before I ordered mine
    Works great to reach into bed
    Pull the trigger- u won’t be disappointed !!
  23. Apr 17, 2019 at 7:56 PM
    #443
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    [/QUOTE]
    Hey Mac,
    I paid my balance and wondering if you saw it on your end.
    jmevis likes this.
  24. Apr 18, 2019 at 6:06 AM
    #444
    mac11
    Warsaw, Indiana
    Yep I have you on the spreadsheet I'm keeping offline. I've gotta put in some administrative time over the next couple nights and I'll get the list in the first thread updated.
  25. Apr 19, 2019 at 7:51 AM
    #445
    Aj_sat
    Aj_sat New Member
    2015 Tundra
    Is there any updates for round 2?
  26. Apr 20, 2019 at 8:40 PM
    #446
    deedubb
    deedubb New Member
    2018 Tundra SR5
    @mac11 - I’m starting to get a little anxious/irritated about how long it’s taking me to get my sliders. I’m sure you are working on them as fast as you can, but a little bit more communication would be appreciated. An ETA would be better.
    Background for others reading. My first set was ordered January 30th. I received my set on March 21st but would not accept them because they were so badly damaged in shipping. Mac took care of return shipping and promised me another set from the current in progress batch and said he would get them to me ASAP. It’s now April 20th and nothing still. I get it, shit happens. I’m getting a little uneasy and impatient
  27. Apr 20, 2019 at 8:50 PM
    #447
    cantle
    cantle New Member
    Durango, CO
    Yea an update on ETA would be great. Patiently waiting here too....
  28. Apr 22, 2019 at 6:01 AM
    #448
    mac11
    Warsaw, Indiana
    Powder coat and raptor are at powder. Been there over a week. Shouldn't be long til they come back. But we outsource powder. It's not an in house process so I have zero control over their workload and timeline. I'm in the middle of packing up bare steels now and they will go out today and tomorrow.
    Theres no reason to be uneasy. We are working on them and as fast as we can. You have a set in this batch. You made the choice to reject them and have them sent back. I understand why you did it. I don't blame you. But If time was an issue you should have accepted them, noted the damage and we would have fixed the powder on your end. Shipping them back to be reworked on my end puts them into the middle of my massive workload. I can't get them to you any faster without stopping production on 20 other sets and pissing off 20 other people. I'm currently working 14hrs day, 7days/week thats about as much as I can do. To say I haven't communicated enough after page 15 and hundreds of PM's and emails kind of eats at me with the amount of revenue and time we've given up to this group buy.
  29. Apr 22, 2019 at 6:03 AM
    #449
    mac11
    Warsaw, Indiana
    Bare steels getting packed this morning
  30. Apr 22, 2019 at 1:07 PM
    #450
    lonelydriver
    lonelydriver New Member
    Thanks Mac11, appreciate all the work, and hopefully getting this much of your product out, will bring you good exposure, awareness, and sales to your brand and make this group buy a definite win win for all of us.
Thread Status:
