Installing puddle lights on factory SR5 mirrors
Discussion in 'Lighting' started by panicman, Apr 21, 2019.
  1. Apr 21, 2019 at 8:41 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I searched and couldn’t find a thread that covers this helpful and inexpensive mod. I have an SR5 with heated mirrors but no puddle lights.
    @VTYOTA has a GREAT tutorial thread on installing VLED universal puddle lights to a set of tow mirrors that includes product links and very good install tips:
    https://www.tundras.com/threads/diy-tow-mirror-puddle-lights.42359/
    This one is specifically about fitting the lights to a factory mirror.
    Once removed, the mirror has a couple of items that make install easier.
    Near the hinge joint of the mirror, there is an access panel that snaps out using a small flat blade. In the middle of the mirror bottom there is a positioning mark for the puddle light.
    You’ll need to remove the mirror from the housing. There is a YouTube video, but you just angle the mirror as if looking down at the ground; the top of the mirror will be projecting out of the housing, the bottom of the mirror will be recessed in to the housing as far as possible. Using a wide plastic trim tool, get under the mirror and lever it up while holding the housing stationary. It’ll take several tries, but it will eventually pop up. I marked one defroster terminal and the corresponding wire with a sharpie. Then unplug the defrost wire. Set the mirror aside so it’s safe. At this point, I wiped the whole mirror housing clean with microfiber and cleaner. Now, pop the bottom access cover off.
    Turn the housing over and with a lamp, look into the housing where the wires for the defrost wires head. You’ll want to run your wire along the defrost wires. At this point, I used steel wire and electrical tape to fish the new wire through the housing. It was not hard.
    As you bring the wire out of the mirror mount, you’ll see the defrost wires emerging from a grommet. Using some needle nose pliers, pull that grommet out. Pop a small hole in that grommet and run your wire through. Then press the grommet back in.
    Time for the commitment- the 1.5” hole needed to mount the VLED puddle light.
    Drill a small pilot hole in the center of the positioning mark (the cast circle) on the bottom of the mirror. Follow that with a 1.5” hole saw. Sand and debur.
    Use the alcohol wipe to really clean around this new hole. Remove the 3M tape backing and mount the light.
    Replace the mirror in the reverse of removal; plug the defrost wires back in, line the clips on the housing mount up with the receiver castings on the back of the mirror, and then use the wide plastic trim tool to lever the mirror down. You’ll feel it click into place. Your mirror should be ready to reinstall.
    VTYOTA’s tutorial does a great job describing how to route the wires so I won’t recreate it. The VLEDS are quite bright, and the positioning mark on the factory mirror takes the guesswork out of the install. Hope this helps!
  2. Apr 21, 2019 at 8:50 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Nice write up. Going to have to put this on my list of mods to do this summer.
  3. Apr 22, 2019 at 5:06 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Looks great! Good job!
  4. Apr 22, 2019 at 6:19 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
  5. Apr 22, 2019 at 6:27 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Good write up! @T-Rex266 maybe a new DIY thread?
    NewImprovedRon and T-Rex266 like this.
  6. Apr 22, 2019 at 7:59 AM
    badblue22
    badblue22 New Member
    Anthong
    2018 trd
    @panicman do you happen to have link to Vtyota that shows the wire running?
    @1UPPER thanks for sharing this with me
    1UPPER likes this.
  7. Apr 22, 2019 at 8:09 AM
    panicman
    Eric
    Here’s the link again:
    Step 17 in his procedural starts the routing of the wire.
    It looks complicated, but really it just requires some patience. The first side took me 2 hours, the second side took me about :40 total, plus soldering on some extension wire to make it all the way to the drivers footwell.
    I had no idea the door panels came off so easy....
  8. Apr 22, 2019 at 8:14 AM
    panicman
    Eric
    I’d also like to recommend Posi taps, as used by VTYOTA. The duo t-taps that VLEDS sends may work, but they feel cheap and temporary. I have them on the truck, but I ordered Posi taps and will be replacing them.
    NewImprovedRon, 1UPPER and VTYOTA like this.
  9. Apr 22, 2019 at 1:32 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I'm curious if I can just use the tap I already did to wire up my truck beds? I think if so, it's pretty easy for me.
    As discussed here, because for 2018 the wiring color is different! It's the pink one.
    https://www.tundras.com/threads/2018-cargo-light-wire.21253/
  10. Apr 22, 2019 at 6:08 PM
    panicman
    Eric
    I am confident you could, you’d just need to decide where to ground.If you do it, post a pic- it would be a good update, as the wire now is not brown as in the linked thread.
  11. Apr 22, 2019 at 7:12 PM
    dhurley
    dhurley New Member
    Doug
    CO
    2015 Toyota Tundra SR 4.6L DC
    ARE topper, window tint, winch
    Great job!
  12. Apr 23, 2019 at 7:27 PM
    panicman
    Eric
    A02848D0-C2B7-4F74-83D7-4D5018386F2B.jpg The cargo light wire is pink in my 2018, but there are 4 pink wires that appear identical. I used a posi tap to locate mine, and routed my power wire under the driver door sill. CB53B5ED-A698-477F-BDE9-9D57559F7C6D.jpg
  13. May 29, 2019 at 9:28 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Sub’d I need to do this. So the lights will dim when turning on and off?
    Now if I can only find a way to get the blinking turn signal arrow on my side mirror glass
  14. May 29, 2019 at 9:34 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    The puddle lights will work like your interior/cargo lights. On when unlocking, door opened, switching on cargo light. Off when locking, closing the door, switching off cargo lights.
  15. May 29, 2019 at 10:09 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Great job!
  16. Jun 14, 2019 at 4:11 PM
    Berdine
    Frank
    Binghamton, NY
    Just did this mod on my 2016, same wire to tap. But No, the lights don't dim. They come straight on and off. I'll be testing more in the dark.
  17. Jul 6, 2019 at 6:28 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    ReginalPierre likes this.
  18. Jul 8, 2019 at 4:43 AM
    marietteachrist
    marietteachrist New Member
    Mariette
    What type of puddle lights you want.
  19. Jul 8, 2019 at 7:44 AM
    TheBeast
    TheBeast The Beach
    looks great ! nice write up OP !
  20. Jul 24, 2019 at 9:16 PM
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    Great info in write up. Made install a breeze.
  21. Aug 15, 2019 at 10:15 AM
    JOZ20
    JOZ20 New Member
    Jose
    2012 crew max SR5
    Thanks @panicman for the write up. Well done.
  22. Aug 29, 2019 at 3:44 AM
    Viliamu808
    Viliamu808 New Member
    Will this work for a 2019?
  23. Aug 29, 2019 at 1:59 PM
    Berdine
    Frank
    Binghamton, NY
    It should
  24. Aug 29, 2019 at 2:05 PM
    Viliamu808
    I emailed the guys at vleds and they said nothing for the 2019..but I think it should work..just don't like to waste money..and headache of sending back things..imma busy man..haha..not really
  25. Aug 29, 2019 at 2:10 PM
    Berdine
    Frank
    Binghamton, NY
    The main thing is finding the right wire. On my 2016, the wire color was different, but in the same spot as I followed a different how to on here. The wire was behind the switch panel. Works perfectly
    texasrho83 and Viliamu808 like this.
  26. Aug 30, 2019 at 9:15 AM
    panicman
    Eric
    Should work fine if they haven’t changed the mirror/housing.
    You’ll really like having puddle lights.
    Berdine likes this.
  27. Aug 30, 2019 at 11:33 AM
    Viliamu808
    Cool..thanks guys
  28. Aug 30, 2019 at 11:57 AM
    Fozzy360
    Fozzy360 New Member
    Hunter
    Virginia
    2010 Tundra Crewmax Limited
    Stock
    Next mod ✅
    Trentimus and Berdine like this.
  29. Aug 31, 2019 at 10:46 AM
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    I still have some rock lights to install, however, it looks like putting in some puddle lights is a more practical mod
  30. Aug 31, 2019 at 11:53 AM
    panicman
    Eric
    The other practical function that hasn’t been spoken of is that tapping into the bed light wire also now allows you to manually turn on the puddle lights using the dash switch.
    ....not that you’d want to drive around that way, but hey...
    NewImprovedRon likes this.
