looking to buy a tundra TRD Pro
Discussion in '2.5 Gen Tundras (2014-2021)' started by toyotafan87, Apr 18, 2019.
  1. Apr 18, 2019 at 9:19 PM
    toyotafan87
    toyotafan87 [OP] New Member
    Gerardo
    Hi fellas, i am new to the forum but i been lurking around for a few months and lots of great feedback as well as knowledgable people in here.
    as the title says i am currently looking to buy a used 2015 tundra try pro crew max with 81k miles on it, this trucks are hard to come by or to even find them for sale as well as expensive lol. my questions are is there anything i should look for? any worries with this many miles? anything else you guys can think of let me know
    thanks in advance
  2. Apr 18, 2019 at 9:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Take a look for the Cam tower leak. At that mileage your factory powertrain warranty will be up.
    Migraine and YsoSeRiouS! like this.
  3. Apr 18, 2019 at 9:27 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    All I can say is get what you want. If your gonna spend the money no regrets. Basically don’t settle. Get the color you want so there no what “if”
    Hol Milk and Watt maker like this.
  4. Apr 18, 2019 at 9:46 PM
    toyotafan87
    Gerardo
    what's the easiest or how do you check for that? thanks
  5. Apr 18, 2019 at 9:48 PM
    toyotafan87
    Gerardo
    i am limited on how much i can spend unfortunately plus i have to take into consideration the amount of gas this things drink ahahaha
    all trd pro colors are nice so i don't mind any of them to be honest
  6. Apr 19, 2019 at 9:50 AM
    hkspwrsche
    hkspwrsche Old guy with lots of car toys
    Harold
    Richmond, VA
    2014 Tundra limited TRD CrewMax
    Working on it
    It’ll look like a valve cover leak but it’s actually more expensive by several thousand. Look at the edges of the valve cover area for oil leaks. Under the valve cover is the system that holds the overhead cams known as the cam tower. You can see it from the wheel well area easier than just under hood.
  7. Apr 19, 2019 at 10:11 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I would also look at new vs used if you are financing. Sometimes it just makes sense to buy new.
    YsoSeRiouS! likes this.
  8. Apr 19, 2019 at 10:25 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    RELEASE THE TICKLE BEES!!
    Set war rocket Giygas to attack mode.
    TXRailRoadBandit73 likes this.
  9. Apr 19, 2019 at 10:28 AM
    hagrid[QUOTED] likes this.
  10. Apr 19, 2019 at 12:41 PM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    View for leaks from the wheelhouse or front wheel liner area.
  11. Apr 19, 2019 at 12:51 PM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    make sure alignment is ok, chances are its rusted up and siezed
