OME DAKAR Leaf Springs HELP!!!
Discussion in 'Towing & Hauling' started by The Juice, Feb 28, 2018.
  1. Feb 28, 2018 at 12:54 PM
    The Juice
    The Juice [OP] THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    Hey guys! I posted the following in another thread but I want to get as much advice from as many people as possible! I need to replace my Leaf springs (they are mushy...blown). I am looking at OME Dakar's....someone else said they didn't last. Anyone out there with personal experience with them? Anything else I should be considering in the same price range? Approx 500-600$ ?????
    -----Does anyone have information on OME Dakar Leaf packs? Toytec has them for 500$ for the set. I tow a 7000lb Travel Trailer. This will only be my second season towing it. I bought a used 2013 Tundra. Who ever used it before obviously towed with it and the OEM leaf springs go flat to inverted slightly without the airbags being inflated. I only want the airbags to augment the load not carry it! Am I wrong for thinking this? This is my third Tundra. I've had various suspension set ups. I'm going to go with the Bilstein 6112's up front at top setting or 2nd to highest setting (They ride amazing.) For the rear on my last build I just did an add-a-leaf from toytec on the rear with toytec shackles set at 1" (OME nitro shocks on the rear).
    -----The rear end on this build is important to me now that I will be towing with my family 3-4 weekends a month! PRECIOUS CARGO. So I am thinking OME Dakar springs on the rear/ OME nitro shocks rear/ and a Coach builder Shackle/ Either 1" or 2"....... Any recommendations? Any gaps I'm missing? I have a CrewMax with hard topper/ and when we tow I've got the bed jammed with wood/ water/ fuel/ generators....500-800 lbs easy.....ADVICE from ANY of you guys with real experience is MUCH appreciated !!!:mudding::plane:
    Coachbuilder1
  2. Feb 28, 2018 at 12:54 PM
    TheBeast
    TheBeast The Beach
  3. Feb 28, 2018 at 1:55 PM
    Have you talked to ToyTec? Tell them what your use is.
    The Juice[OP] likes this.
  4. Feb 28, 2018 at 2:09 PM
    They are open now!!
  5. Feb 28, 2018 at 3:29 PM
    The Juice
    COLORADO NATIVE
    I'm hoping for anyone out there who may be running the OME Dakar's to comment on how they are holding up!! How much weight you load on them towing and or bed load?!:pccoffee:
    pbcolt and dcsleeper408 like this.
  6. Mar 8, 2018 at 9:26 AM
    pbcolt
    pbcolt New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    Bump, I have the same question.
  7. Mar 8, 2018 at 9:31 AM
    Grumpy Uncle
    Pat
    CO
    I had them on my 2010 Tacoma, my oldest son drives it now. They have about 56k on them and no sagging. The heaviest load I had on them (in the bed) was about 600lbs (laminate flooring) and it did really well. Would I buy them again? In a heart beat! When I recover from my latest purchase I will be buying Old Man Emu for my Tundra.
  8. Mar 9, 2018 at 7:24 AM
    The Juice
    COLORADO NATIVE
    Thank you for your response sir!
    :thumbsup:
  9. Mar 9, 2018 at 9:30 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I put them on mine last spring and IMO wish I didn’t spend the money on them. Not happy they have flattened out already and actually the pass side has reversed arched a bit I post the pic look behind the axel you can see it I like the way it rides and I tow a 6x12 enclosed trailer. And weighs about 4000 loaded up and it doesn’t sag much but just not happy with the flattening issue 762EAF4D-D6B3-4890-A6D5-19BEC559C743.jpg
  10. Mar 9, 2018 at 9:53 AM
    The Juice
    COLORADO NATIVE
    THIS is The kind of INFO I NEED! Thank you! I may be looking into Some Deevers (sp?) !!!
  11. Mar 9, 2018 at 10:04 AM
    pbcolt
    pbcolt New Member
    San Diego
    Thanks for chiming in, I'm also considering Dakars. I'm confused. You like the way it rides, it doesn't sag with a load, but you still wish you didn't spend the money on them? Why does the leafs being flat matter?
  12. Mar 9, 2018 at 10:06 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have 6 to 8k miles on mine. i tow an enclosed snowmobile trailer with sleds (6,000 lbs) and several other smaller trailers. i have airbags also. mine are fine still look like they did the day i put them on. still ride good.
    Black Wolf and The Juice[OP] like this.
  13. Mar 9, 2018 at 10:06 AM
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
    Have you considered icon rxt? @Wheelerjr32 Has them for 749 and with forum discount should be less than 7 with free shipping. Only downside is they don't have them in stock yet as am still waiting for mine.
  14. Mar 9, 2018 at 10:35 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I have had them on now for 3 years.. they are just starting to go. I have towed with them a 7ft wide 8 ft high by 16ft long enclosed trailer. the leafs add some hight like 2-2.5" i will say all things considered these leafs are great, they dont keep up with my LT front now, but do a damn good job all things considered. not sure what else you have questions on feel free to PM me. Also i run very hard on my truck with about 4-600lbs of bed weight i have ads 2.5 triple bypasses and they manage the load great. I also had air bags with day star cradles and they worked great for heavier loads.
  15. Mar 9, 2018 at 10:37 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I should mention yes mine have flattened out now, but that was 3 years and 75k miles and very hard wheeling ... worth the $ imo if you are trying to save a few bucks..
  16. Mar 9, 2018 at 10:45 AM
    The Juice
    COLORADO NATIVE
    DAMN!! That is a great price! I will look into those! Any reviews on Tundras for these?
    dcsleeper408 and papasmurf like this.
  17. Mar 9, 2018 at 10:48 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Id do that if thats in your price range, those are nice leafs
    dcsleeper408 likes this.
  18. Mar 9, 2018 at 10:52 AM
    The Juice
    COLORADO NATIVE
    papasmurf likes this.
  19. Mar 9, 2018 at 10:56 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    The Juice[QUOTED][OP] likes this.
  20. Mar 9, 2018 at 11:27 AM
    six7zero
    six7zero New Member
    15 SR5 Crewmax
    Mention you are a tundras.com member for additional discount.
  21. Mar 9, 2018 at 1:06 PM
    Theyfzman
    Pa
    08 TRD
    To answer question pbcolt the idea of aftermarket leaf packs is to give you a bit of lift without blocks or shackles and when they lose that arch “flatten” then you loose the whole reason you bought them in the first place and now my truck is sitting a bit uneven because of it. That’s why I’m not happy they shouldn’t loose there arch in less than a year for $500 +
    The Juice[OP] and pbcolt like this.
  22. Mar 9, 2018 at 1:34 PM
    Hmmmm.................................:mudding:
    TheBeast likes this.
  23. Mar 9, 2018 at 2:41 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    I agree
    Gosh, reading some of these treads on leaf packs, almost makes me want to just get a $85 add a leaf set like i had on my Tacoma. if it flattens in 3 or 4 years, throw it in the trash and replace it with another.
    I had that on my tacoma, and never had a issue and towed and hauled way more weight than i should have on a number of occasions.
  24. Mar 9, 2018 at 2:55 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I had OME sprinhs on my tacoma with no issues,if you load out heavy or tow then airbags to help would be smart as well.the ICON springs look great but who know how they will do over time since there still new....just my .02 worth
  25. Mar 9, 2018 at 2:56 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I am using the RXT multirate leaf pack at 3rd option. Holding up well with about 450lbs on.
    joonbug, Black Wolf and The Juice[OP] like this.
  26. Apr 16, 2019 at 11:04 PM
    Mr. Cade
    Mr. Cade New Member
    2014 Crewmax Platinum
    Can anyone offer an update on how their leaf packs are holding up?
    I just ordered the OME Dakar and this thread is making me want to return them. :facepalm:
  27. Apr 17, 2019 at 7:05 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Mine held up for a long time of hard wheeling, towing, etc... don’t worry about it
    joonbug and Black Wolf like this.
  28. Apr 17, 2019 at 7:26 AM
    I plan on getting the DAKARS to complement my OME coilovers/rear shocks. I mainly plod around on old mining roads. I figured if they held up for you with kind of wheeling you do then I'm not going to worry about them. :thumbsup:
    papasmurf[QUOTED] likes this.
  29. Apr 17, 2019 at 7:38 AM
    pbcolt
    pbcolt New Member
    San Diego
    Mine have been on for 6 +/- months now, about half of the time with a RCI bed rack and RTT mounted. I think they are great. Certainly rides better with a little weight on them, but that's normal for leaf springs. I was worried based on other reviews they would have settled a bunch by now (I was actually counting on it), but so far they have not.
  30. Apr 17, 2019 at 9:08 AM
    Mr. Cade
    Mr. Cade New Member
    Thanks, big brotha
    I'll post up pics and thoughts when I get mine on.
    Thanks.
    I have an extra large camper shell with a prinsu rack and a bedslide so I'm hoping those things weigh it down just right. If it's still too stiff, I'll probably just buy more gear
    Also if it rides a little soft, I'll probably just buy more gear.
    BigTaco, Willy224, Black Wolf and 2 others like this.
