So my real name isn't Mooseknuckles. its Knuckles, i just added the moose part
Discussion in 'New Member Introductions' started by Mooseknuckles, Apr 16, 2019.
  1. Apr 16, 2019 at 12:45 PM
    Mooseknuckles
    Mooseknuckles [OP] New Member
    Randy
    Hello guys,
    I'm Randy,
    Retired AF, living in Kansas, drive a 2008 Tundra extra cab limited.
    Great to have a place like this to help out us shade trees. looking forward to reading posts and picking brains.
  2. Apr 16, 2019 at 12:46 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hi and welcome from SoCal!!!
  3. Apr 16, 2019 at 12:47 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Welcome to the forum Randy!
    I'm sure you meant retired Air Force, but I read it in my head as retired "As Fu*&"!
    Let's see your Tundra!
  4. Apr 16, 2019 at 12:48 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA.....;)
  5. Apr 16, 2019 at 12:52 PM
    Welcome from Colorado.
  6. Apr 16, 2019 at 12:57 PM
    Welcome from Texas, thank you for your service
  7. Apr 16, 2019 at 1:04 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon! Thanks for serving!
    Pinay likes this.
  8. Apr 16, 2019 at 1:04 PM
    Tempest
    Tempest You feel lucky??!!
    2015 Limited TRD
    Welcome from AZ!! :tumbleweed:
    jewsNbrews and Pinay like this.
  9. Apr 16, 2019 at 1:05 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  10. Apr 16, 2019 at 1:05 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  11. Apr 16, 2019 at 2:03 PM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    Welcome from SE Ohio.
  12. Apr 16, 2019 at 2:04 PM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Welcome from Tx!
  13. Apr 16, 2019 at 2:14 PM
    15whtrd
    15whtrd Mr. Blonde
    Mooseknuckles and cameltoes should never retire.
    Welcome from SoCal!
  14. Apr 16, 2019 at 2:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    15whtrd likes this.
  15. Apr 16, 2019 at 2:28 PM
    Mooseknuckles
    Randy
    Quick rundown on my Tundra. 2008 5.7 Limited with 206K miles. Believe it or not I replaced my serpentine belt @ just over 190K. Starter, AC pump, Lower ball joints, secondary air pump went out so i used the bypass kit last year and its worked fine ever since. Installed a cheep Rancho leveling kit, I'm sure that's what caused my lower ball joints to wear. replaced level kit with Bilstein 5100s adjustable shocks. work great and still have the lift i wanted. I'm about to replace the radiator, hoses, thermostat, and cap in a few days. Also noticed a looseness in the steering wheel. the rack and pinion has some movement side to side. Planning on replacing them with the Energy Suspension polyurethane bushings. figured I'd do the rad and bushings at the same time. any advise will be greatly appreciated.
    jewsNbrews, 15whtrd and Trooper2 like this.
  16. Apr 16, 2019 at 2:30 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Welcome! Are these your cousins?
  17. Apr 16, 2019 at 3:05 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  18. Apr 16, 2019 at 3:57 PM
    Sunnier
    Sunny
    San Diego, CA
    Welcome from SoCal!
  19. Apr 16, 2019 at 4:00 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Welcome from San Diego
  20. Apr 16, 2019 at 4:11 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  21. Apr 16, 2019 at 4:27 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Welcome from NE Pa
  22. Apr 16, 2019 at 4:28 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  23. Apr 16, 2019 at 4:28 PM
    Red Fox
    Red Fox New Member
    Kacie
    2016 Radient Red SR
    Welcome from TX!
  24. Apr 16, 2019 at 10:21 PM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  25. Apr 16, 2019 at 11:07 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    It's real hard not to like a dude named Mooseknuckles! Welcome!
    My wife is ex AF and son is CG.
  26. Apr 16, 2019 at 11:19 PM
    NoRcptn
    NorCal
    2017 Platinum
    Either way its a good spot to be. Welcome.
  27. Apr 17, 2019 at 2:45 AM
    Welcome from Ohio. Nothing wrong with a little moose knuckle! :D
    jewsNbrews likes this.
  28. Apr 19, 2019 at 9:07 AM
    Mooseknuckles
    Randy
    I could use some advice on replacing the rack and pinion bushings on my 2008 Tundra.
    While driving, I felt some play in the steering wheel allowing the vehicle to wander slightly side to side. After a quick inspection I found that when turning the steering wheel back and forth the unit its self moved side to side 1/4 inch or so in each direction. From what Iv'e been able to find on google the O.E.M bushings are a softer rubber then say, a polyurethane bushing. Defective bushings? I don't know. I plan on replacing them with Energy Suspension polyurethane bushings ASAP. I've also found some posts saying that they can be removed/replacing on the vehicle without pulling the entire unit out, Is this true? Any advice would be hugely appreciated .
    Thnx.
    Sorry for the double post, thought i might have better luck here. 8)
  29. Apr 19, 2019 at 9:14 AM
    15whtrd
    15whtrd Mr. Blonde
    https://www.tundras.com/threads/the...rack-thread-with-solutions.33539/#post-835171
  30. Apr 19, 2019 at 9:40 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome from Washington
