  1. Mar 31, 2019 at 8:07 PM
    #991
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looking good Mike. That's a lot of work to do alone. I did mine a could years back. Give that pressure treated lumber a few months to dry out and get some stain on it. I highly recommend Armstrong Clark stain. And get their restore a deck kit too. Comes with a cleaner and a wood brightener, it's like an oil based stain, goes on super easy (I actually used a car wash brush and stained my large deck in an hour or so). The cleaner and brightener make the stain go on more even and gets it to the right ph for staining. I got more than I needed, went with 5 gallons, so I could do 2 coats and have enough to stain again a few years later. I'll be buying their restore a deck kit again and another coat of stain this spring. It's well worth the money and I don't think you'll find a better stain. I went with a two tone look on my deck and like how it came out.
  2. Apr 1, 2019 at 3:04 AM
    #992
    Mnorris1206
    08 tundra
    That looks really nice !
    Pudge[QUOTED] likes this.
  3. Apr 1, 2019 at 3:42 AM
    #993
    Looks great!
    Lambeau[QUOTED] likes this.
  4. Apr 4, 2019 at 7:26 AM
    #994
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
  5. Apr 5, 2019 at 5:42 AM
    #995
    Notachickmagnet
    Notachickmagnet New Member
  6. Apr 5, 2019 at 5:52 AM
    #996
    Mnorris1206
    08 tundra
    What are you up to ! And nice boots !
  7. Apr 5, 2019 at 5:53 AM
    #997
    Notachickmagnet
    I took some old steps out, and thanks !!
    Mnorris1206[QUOTED] likes this.
  8. Apr 5, 2019 at 5:54 AM
    #998
    Mnorris1206
    08 tundra
    Nice running a Jack hammer is the best part of my job. Although customers are not happy about leaks under their slab home.
  9. Apr 5, 2019 at 5:56 AM
    #999
    Notachickmagnet
    It wasnt bad, alot different than the one I ran for a short time years ago!
    These steps were brutal, probably put in a a few years after the house was built in 1920
  10. Apr 5, 2019 at 5:57 AM
    #1000
    Mnorris1206
    08 tundra
    Nice you putting the same back or ? Some type of deck or ? Lol
  11. Apr 5, 2019 at 6:01 AM
    #1001
    Notachickmagnet
    Taking a door out, so the steps had to go! Expanding my kitchen into back porch by about 10'x20' gonna be a slow process !
  12. Apr 5, 2019 at 6:12 AM
    #1002
    koditten
    Kirk
    Midland of the Mitten
    Built a gas fire place this last couple months.IMG_20190118_185329.jpg IMG_20190219_105717.jpg
  13. Apr 5, 2019 at 7:46 PM
    #1003
    Rhernandez09
    Rhernandez09 New Member
    Roy
    2018 Black Tundra TSS
  14. Apr 6, 2019 at 12:36 PM
    #1004
    warlord192
    warlord192 Get off my lawn !!
    New Orleans
    2014 Silver Sky metallic Tundra Double Cab
    Not the same without the lacy socks :dancingbacon:
  15. Apr 6, 2019 at 12:38 PM
    #1005
    Notachickmagnet
    Ha!! There is lace there just covered in cement dust :rofl:
    Prostar 190 likes this.
  16. Apr 6, 2019 at 12:40 PM
    #1006
    warlord192
    New Orleans
    guess you haven't done laundry yet.
  17. Apr 6, 2019 at 12:40 PM
    #1007
    Notachickmagnet
    Lol they started out clean!!!:rofl:
  18. Apr 6, 2019 at 12:41 PM
    #1008
    warlord192
    New Orleans
  19. Apr 6, 2019 at 2:58 PM
    #1009
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Not sure this is an improvement other than it is a better one than the replaced failed disposal.
    So much fun, well not really.:frusty:
  20. Apr 6, 2019 at 3:06 PM
    #1010
    Got to have at least one plumber joke....
  21. Apr 6, 2019 at 3:14 PM
    #1011
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    LOL
    Good one
  22. Apr 6, 2019 at 4:12 PM
    #1012
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Stripped my deck. New sealer coming tomorrow.
  23. Apr 6, 2019 at 4:16 PM
    #1013
    Pudge
    CT
    Looks good. What are you putting on it?
  24. Apr 6, 2019 at 4:23 PM
    #1014
    Mnorris1206
    08 tundra
    This may blow your mind as a plumber I have installed them new flange and all in 15 min lol I have been timed.
  25. Apr 6, 2019 at 4:24 PM
    #1015
    Mnorris1206
    08 tundra
    I love the cable and rail I have had thoughts to do that instead of spindles
  26. Apr 6, 2019 at 4:36 PM
    #1016
    JMB
    Chesapeake, VA
    This. I know it's not the "best" but it has good reviews and it's oil based. If it totally sucks I can strip the whole deck it 3 hours, plus some sanding if I get careless with the pressure washer :facepalm::anonymous:.
    Prostar 190 and Pudge[QUOTED] like this.
  27. Apr 6, 2019 at 4:38 PM
    #1017
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    It took longer to connect the electrical then anything.
    Some DA used a 90o sealtite connector to the KO. (i'm an electrician, wasnt me)
    they should have just used a standard romex connector or a straight sealtite connector
  28. Apr 6, 2019 at 4:40 PM
    #1018
    JMB
    Chesapeake, VA
    I didn't want rails at all. The deck isn't that high. My wife insisted on rails down the side and stairs. We kind of stumbled on those while looking at spindles. They give a nice open appearance while still having the rails. They ain't cheap though.
  29. Apr 6, 2019 at 4:40 PM
    #1019
    Pudge
    CT
    Oil based is definitely the way to go. I went with Armstrong Clark a few years ago and highly recommend their products. I am due for washing and recoat this summer. I'll powerwash, let it dry a few days and put on another coat. Its held up great and best part was, for the most part I could apply with a carwash brush which really helped speed along the process.
    NewImprovedRon and JMB[QUOTED] like this.
  30. Apr 6, 2019 at 4:51 PM
    #1020
    Mnorris1206
    08 tundra
    For sure I like it.
    JMB[QUOTED] likes this.
