  1. Apr 1, 2019 at 3:12 PM
    #5551
    Professional Hand Model
    Fred
    Hand Protectors
    Adjusted rear brakes and installed new dust rubber plugs shields where others forgot to reinstall. Adjustments on the star adjuster is easy using a flat head screw driver. The star only adjusts one way. You will hear it click. I did one click and can feel a small improvement in braking.
    NUDRAT and 00TundraZ like this.
  2. Apr 1, 2019 at 3:16 PM
    #5552
    Fred
    Hand Protectors
    6 new cowl clips installed.
  3. Apr 1, 2019 at 3:21 PM
    #5553
    Fred
    Hand Protectors
    Brutal.
    Safelite guy said he sees this alot on our 1st Gens. Whats your plan?
    lsaami[QUOTED] likes this.
  4. Apr 1, 2019 at 3:27 PM
    #5554
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I dunno. I kinda hate to bail on this truck because it has a brand new frame and I have so little into it, but I don’t know that there’s much to be done with something like this. Fixing is only temporary, and a cab swap is not worth it.
  5. Apr 1, 2019 at 3:57 PM
    #5555
    Fred
    Hand Protectors
    Ospho, Bondo, and POR15 the crap out of it and re-install that visor (repainted prior to install). Use some Fuze in those holes and caulk the window gasket. Its not hard work and who cares what it looks like under the visor.
  6. Apr 1, 2019 at 4:19 PM
    #5556
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Sometimes it’s the little things. Very nice!
  7. Apr 1, 2019 at 4:20 PM
    #5557
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Is it just the roof skin? Maybe a good one from a junk yard?! Just trying to think of anything to save a good 1st gen! Or even a cut out and patch weld in. That looks fairly flat... just throwing out ideas!
  8. Apr 1, 2019 at 4:26 PM
    #5558
    Fred
    Hand Protectors
    Yes it is. Thank you. After pulling the cowl off about 4 different times 3 of the 6 base clips broke just from dry brittle aging. Should be good to go now and hope to not ever have to pull this cowl off again.
  9. Apr 1, 2019 at 4:38 PM
    #5559
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    A competent body shop should be able to pull the window and repair the rust. My guy charged me 500 bucks to pull the front and rear glass to repair the rust over the top of my fathers 02 Tacoma. And it’s rust was just slightly better than yours
    Darkness likes this.
  10. Apr 1, 2019 at 5:31 PM
    #5560
    Dpy
    Dpy New Member
    Talked to seat cover company and they are sending correct seat bottom. Suppose to be making it and shipping tomorrow , meanwhile got rear brake pads installed . Got email today my driveshaft disconnect was shipped today and my new front calipers, rotors and pads are shipped and shocks are probably going out tomorrow so somewhere between wed and saturday I might be busy.
    NUDRAT likes this.
  11. Apr 1, 2019 at 7:01 PM
    #5561
    ry3737
    ry3737 New Member
    2003 Tundra V6
    N/A
    The paint is faded bad. No clear cut whatsoever.
  12. Apr 1, 2019 at 7:20 PM
    #5562
    lsaami
    lsaami Let ‘er buck
    Minnesota
    It’s possible. It’s just a huge pain. I’m trying to do all of the work myself, and $500 for that little repair would really blow my budget. Heck, I only paid $1100 for the whole truck!
    And I have about $3400 worth of stuff to do to it yet...
    00TundraZ[QUOTED] likes this.
  13. Apr 1, 2019 at 8:45 PM
    #5563
    Sunnier
    Sunny
    San Diego, CA
    Glad for the update on the car seat cover. Keep us posted.
  14. Apr 1, 2019 at 8:56 PM
    #5564
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Guess you're about to get good (enough) at body work.
    I'll suggest you drop the headliner so you can see what's what & hopefully see if it's just the skin, or structure.
    Suddenly I don't want a visor anymore.
    lsaami[QUOTED] and Sunnier like this.
  15. Apr 1, 2019 at 9:02 PM
    #5565
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I did the top ones today, filled the tank & went to work. drip, drip, drip.
    Didn't realize there were two more further down - those better match my leak pattern. Gotta get two more clamps & a better back to reach down there. Thanks for the pic & arrows - BIG help.
    Does it make sense that if the original clamps aren't enough, that it suggests the hose is saturated & I should replace the hoses?
    TX-TRD1stGEN likes this.
  16. Apr 2, 2019 at 4:17 AM
    #5566
    bmf4069 Captain wtf
    Time to make the first targa top tundra!
  17. Apr 2, 2019 at 7:10 AM
    #5567
    Fred
    Hand Protectors
    The clamps have stopped the slow drip which, in my case, was making its way down to the metal lines above the axle. I only did 3 new clamps. Did not do the one next to the pump.
    I think the old clamps had formed a maze pattern on the hose which the fluid then followed. The hoses should be fine in your case. Make sure to wipe the excess fluid off from all areas a few times as it really stays around and if you don’t will make you think you still have a leak.
    NUDRAT[QUOTED] likes this.
  18. Apr 2, 2019 at 9:08 AM
    #5568
    See my thread about this. Our trucks never had a clearcoat from the factory. These were single stage paint jobs. I actually thought the same thing. What you're seeing is oxidation that can be fixed. Don't waste money on a paint job.
  19. Apr 2, 2019 at 10:07 AM
    #5569
    Fred
    Hand Protectors
    Slathered up all fuses inside the cab and the one under the hood with some electrical grease. Remember, back in the fall I pulled all of them and sanded off the corrosion with sanding cloth. Even the interior fuses had a dark glaze about them and they never see weather?
    Anyways, got around to greasing them with Noalox.
  20. Apr 2, 2019 at 10:13 AM
    #5570
    Casper421
    In the woods
    06 DC
    Or you could’ve just bought 220 fuses for $12 and saved $6 and time.
  21. Apr 2, 2019 at 10:18 AM
    #5571
    Fred
    Hand Protectors
    This just arrived. A freshie to replace the existing with 45k miles on it. Cost $14.
    Sunnier and 00TundraZ like this.
  22. Apr 2, 2019 at 10:24 AM
    #5572
    Fred
    Hand Protectors
    Yeah I coulda, but because I already had the grease I did not. Took me about 10 minutes tops at zero cost. These are all the original fuses and probably will outlast the useful life of the truck unless I do 3rd Gen owner electrical hack work. Hoot!
    The Big Gurl from Brasil pic was for informational purposes. Good stuff to have around for home and auto!
  23. Apr 2, 2019 at 11:15 AM
    #5573
    empty_lord
    05 rollover special
    Anyone happen to know the part number for the wire clamps on the driver side timing cover?
  24. Apr 2, 2019 at 12:06 PM
    #5574
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    :sawzall::welder::itllbuffout:
    ethan1911, NUDRAT, Sunnier and 5 others like this.
  25. Apr 2, 2019 at 12:19 PM
    #5575
    Casper421
    In the woods
    06 DC
    There is no such thing as a 3rd gen tundra. It hasn’t come out yet.
    Sunnier, Darkness and speedtre like this.
  26. Apr 2, 2019 at 12:27 PM
    #5576
    Fred
    Hand Protectors
  27. Apr 2, 2019 at 12:30 PM
    #5577
    Casper421
    In the woods
    06 DC
  28. Apr 2, 2019 at 12:35 PM
    #5578
    Fred
    Hand Protectors
    Got the new rad cap on. Tested the old vs. the new by squeeze (of the spring) and there is a difference. Both feel like they have about the same pressure, but the old one wobbles more on the spring.
    Coulda took it to a shop for testing, but the cost of the test far outweights the $14 cost of a new cap.
    A quick 20 mile trip and the cap looks good.
  29. Apr 2, 2019 at 12:37 PM
    #5579
    speedtre
    speedtre New Member
    Inland Northwest
    I agree there is no third gen Tundra. Changing the dash and redoing a few body panels does not a new model make....same drive train, same transmission, same frame etc etc. When has any Toyota Truck that was an actual new generation kept the the drive train, transmission and frame all the same from the previous generation?
  30. Apr 2, 2019 at 12:40 PM
    #5580
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Ah, I get it now. Toyota calls it gen 3, but in fact with the parts that matter it is still a gen 2. I was staying out of it until someone who knew more chimed in :bowdown:
