DIY: Footwell LED install
Discussion in 'Lighting' started by csuviper, May 19, 2015.
  1. May 19, 2015 at 10:31 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Footwell LED lighting (front and rear)
    Parts needed
    1. Cut strips of 6 LEDs per footwell from the LED roll.
    3. Solder the black and red wires the the first small LED strip that will be placed under the drivers side footwell.
    4. Pull off the backing and stick the first LED strip where you would like under the drivers side footwell.
    5. Measure and cut the red and black wires to proper length reaching from the LED strip to the existing location of the drivers footwell light. Run the wires carefully to keep them tucked up and hidden nicely.
    6. Splice the red and black wires from the first LED strip into the wires from the existing light in the drivers footwell. Light blue is positive and the light brown is negative. I popped out the existing footwell light because the color would not match the new ones.
    7. I installed all of the remaining lights in series with the first one. That means that I soldered the next LED light strip (passenger footwell) onto the end of the first LED light strip. Then the next one, passenger rear to the passenger front and so on. Repeat steps 4 and 5 running from strip to strip. Run the wires under the carpet, and up the rear supports of the front seats for a clean install.
    8. The last step is to make sure all of the wires are hidden for a clean install. With them being tied into the existing drivers side footwell light, they turn on when the door is opened and turn off a few seconds after the door is closed.
  2. May 19, 2015 at 10:31 AM
    Nicely done!
    J5LTDPRO likes this.
  3. May 19, 2015 at 10:32 AM
    csuviper
    Broomfield, CO
    outdoorlife3 likes this.
  4. May 19, 2015 at 1:36 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I really like that. I've been thinking about doing red in front And back.
  5. May 19, 2015 at 2:13 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    My tundra has them... go for it you will love it.
    TruckyTruck[QUOTED] likes this.
  6. Nov 26, 2015 at 4:06 AM
    PolarbearTRD
    PolarbearTRD New Member
    Newton Nh
    2015 white crewmax TRD
    Carbon fiber wrap trim interior. Carbon fiber pillars, yitamotor 6000k led headlights. Rigid industries 50" led light bar,
    Can you show or explain how you tied these in to the footwell light? Thanks looks good,
  7. Nov 26, 2015 at 10:04 AM
    csuviper
    Broomfield, CO
    Of course. Let me take a pic
    nlaroy and PolarbearTRD like this.
  8. Nov 26, 2015 at 10:10 AM
    PolarbearTRD
    Newton Nh
    Thank you
  9. Nov 26, 2015 at 11:00 AM
    csuviper
    Broomfield, CO
    I popped out the light and connector and tapped into the wires.
    bulldog93 and (deleted member) like this.
  10. Jun 6, 2016 at 7:56 PM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    How do u run wires to back seats? What gauge wire? All off that small lil light drivers side foot well?
  11. Jun 6, 2016 at 9:16 PM
    csuviper
    Broomfield, CO
    Ran the wires under the carpet, and up the rear supports of the front seats. All of them are tied into the one small little light on the drivers side. I don't remember exactly what guage i had but i believe it was around 18 gauge.
    nlaroy likes this.
  12. Jun 6, 2016 at 9:49 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks great! I guess I know what I'm doing this weekend!
    Tex-Tun likes this.
  13. Jun 15, 2016 at 8:03 AM
    outdoorlife3
    outdoorlife3 New Member
    michael
    2016 Toyota tundra
  14. Jun 15, 2016 at 11:47 AM
    csuviper
    Broomfield, CO
  15. Jun 22, 2016 at 7:30 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    My question as well, for the pre assembled kit.
  16. Jun 22, 2016 at 10:15 PM
    csuviper
    Broomfield, CO
    4000k is white
    5000K should have a very slight tint of blue
    6000k should have a little more blue
    Not sure if i have 5000k or 6000k.
    geno0506 likes this.
  17. Aug 25, 2016 at 12:05 PM
    lee427
    lee427 New Member
    What footwell light?
  18. Aug 25, 2016 at 12:27 PM
    kemosabee
    kemosabee New Member
    James
    Pagosa Springs
    07 Tundra
    I like, i also have 2 extra rolls of led lights... weekend project!
  19. Sep 19, 2016 at 12:13 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    very nice!
  20. Sep 29, 2016 at 8:02 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Anyone ever just replace the existing bulb with a small LED? probably a lot less light-but a cheap option?
    Tex-Tun likes this.
  21. Sep 29, 2016 at 10:56 AM
    kemosabee
    James
    Pagosa Springs
    07 Tundra
    A strip of LEDs runs pretty damn cheap too though..
  22. Sep 29, 2016 at 11:22 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Tex-Tun likes this.
  23. Sep 29, 2016 at 11:26 AM
    csuviper
    Broomfield, CO
    Exactly. Its only a really small bulb that is on the drivers side only.
    What i have done is added small strips to each footwell front and back. Love the added light.
    I would put this mod at a total of around $30-$40.
    bulldog93 and Beesta like this.
  24. Sep 29, 2016 at 11:33 AM
    14tundra
    WI
    I don't want to jack this thread but as long as we are talking LED, anyone know the 2014+ license plate LED blub size/part number?
  25. Sep 29, 2016 at 11:35 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Tex-Tun and Beesta like this.
  26. Sep 29, 2016 at 11:37 AM
    csuviper
    Broomfield, CO
    HUTCHJ and NewImprovedRon like this.
  27. Sep 29, 2016 at 12:08 PM
    kemosabee
    James
    Pagosa Springs
    07 Tundra
    Must be some expensive LEDs! Last LED strip I bought off Amazon was a 16.4ft for $9. Free shipping and I already had double sided taped if needed.
  28. Sep 29, 2016 at 1:10 PM
    csuviper
    Broomfield, CO
    bulldog93 and Yoda the Tundra like this.
  29. Sep 29, 2016 at 1:29 PM
    csuviper
    Broomfield, CO
    Ok i went through the first post and updated with the parts list and also updated the steps to wiring this all up.
    BravoDeltaRomeo and Sunnier like this.
  30. Nov 2, 2016 at 6:51 PM
    TheBeast
    TheBeast The Beach
    is there a fuse specific to the footwell light ? my LED strip just stopped working. Other interior lights are OK.
