Deep dive into the 285 70r18 setup (need experienced help)
Discussion in 'Wheels & Tires' started by Blindf8th, Mar 22, 2019.
  1. Mar 22, 2019 at 10:06 PM
    Blindf8th
    Blindf8th [OP] New Member
    Hello,
    Been trying to nail a few things down for a while now and need help. In short here is the question and here is where I'd appreciate a little knowledge transfer.
    Backstory:
    Recently bought the Fox 2.0 coil overs for my 2018 Tundra Platinum 4x4. My goal was to give it a performance jump behind the wheel to eliminate some sway, bounce, and rolling the default suspension has and the Fox 2.0 setup fit the bill. This provided a 2" lift in front while the 2.0's in the rear provided no height gain. This gave me essentially what the TRD Pro trucks have by default (2" level). Now that the template has been set I started going down the path of what wheel\tire combo I wanted and believe I have decided on the following based on hours upon hours of research to make sure I get exactly what I'm going for.
    Method Roost 5.75 back space & +18 offset
    285/70r18 (Nitto Ridge Grapplers)
    The Confusion:
    Choosing this tire size was not that hard. Seems to be the perfect balance for me personally between the 275/70r18 & 295/70r18 so many people run. Doing any research its not to hard to find that the 295/70r18 size is the max size for the stock TRD Pro without having to do much else outside of removing the small front mud flaps and maybe just a tad plastic trimming (maybe). The wheel choice (back space and offset) along with the tires play a major role in fit. So fast forward to now. I've been trying to wrap my head around the following as I track down anyone online with the same wheel specs (or close to it) that I purchased having the 2" level setup. I have found a few, but here is the underlying issue I have...
    ________________
    My initial inspiration came from this thread where TRD15559 chimed in with his initial setup (stock TRD Pro with 295/70r18 wrapped in Nitto Trail Grapplers MTs). So based on this setup if he ran the exact same wheel that I'll be running and he experienced a little rubbing against the bumper and removed the small mud flaps then going to a smaller tire (285/70r18) should not be an issue you would think.
    https://www.tundratalk.net/forums/tundra-trd-pro/439057-pro-pictures-47.html
    ________________
    So lets check another build shall we. Now this guy (Matte Tundra) ran the 295/70r18 with very little issues also, but like TRD15559 he had a little rub as well and thus he trimmed a little bit too. He is running the Method Mesh wheel which like the Roost has the 5.75 back space & +18 offset.
    https://www.tundras.com/threads/295-70-18-ridge-grappler-and-method-wheels-on-my-pro.10507/
    ________________
    Here is where it gets interesting. This guy (Teflondon100) was the Tundra Limited with TRD package and is actually running what I would like to 285/70r18 on Nittor RGs (with the icon 2" level in front only). However he is on the base TRD wheel that is a +60mm offset which = 2.3622". In order to get the stance he wanted all he had to add was some wheel spacers (Spidertrax 1 1/4). So this is not a like for like, but it definitely proves that its no issue as he only removed his small front mud flaps.
    https://www.tundras.com/threads/official-tundra-wheel-and-tire-setups-pics-and-info.95/page-45
    ________________
    Almost there hang with me here. The last example is this guy (Marty McFly) also runs the 285/70r18 setup with no issues.
    https://www.tundras.com/threads/285-70-r18-2016-stormtrooper-tundra-trd-pro.8065/
    ________________
    Now here is where I do not understand as this guy has a Platinum like me and experienced TONS of issues trying to get his wheels and tires to work and his Raceline Shift wheels are 5.7 back space & +18 offset (wrapped in Nitto Exo Grapplers). He also has a 3" lift in the front! The Method Roost wheels are almost identical (5.75 back space & +18 offset), but he had so much trimming and shaving it makes zero sense.
    https://www.tundras.com/threads/new-wheels-and-tires.14797/
    ________________
    So the novel of examples above leads me to believe that the inside wheel well area for the different Tundra offerings is different between the TRD Pro, Limited TRD, & Platinum series trucks. Its hard from me to believe that this last example has so many issues ultimately having to put on wheel spacers with a +18 offset while TRD15559 and others are running a wheel\tire combo that is over half an inch taller (.6") and almost have an inch wider (.4") with less issues. The +60mm offset guys you would think have less issues and their setup pulls the wheel\tire combo in even closer. What am I missing here?
    Thanks for any light anyone may shed on my research and hopefully educate me on something I may have missed. If you break the examples down and do the math to me it just doesn't seem to add up. My goal is to have my Fox 2.0 coil over setup and run the Method Roost on Nitto RGs with only needing to remove the small front mud flaps. Seems like it should be doable, but there are so many variables\discrepancies I have come across that have me very unsure with what I may actually run into. Not to mention the re-stocking fees should they be problematic and I not want to do extensive trimming.
    Any thoughts or input you have would be greatly appreciated.
    Thanks,
    Blind
    equin likes this.
  2. Mar 22, 2019 at 10:17 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    I run 295/70-18 on stock TRD Pro 18x8 rims. No rubbing lock to lock and haven’t removed any flaps...
    Watt maker and Rica25 like this.
  3. Mar 22, 2019 at 10:23 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @Blindf8th, I see ya did some research. All Tundras are not the same, so you could luck out and have no trimming or you might have to remove the small flaps. I am on the 6112's up front@ max 2 3/4" although it's probably settled down to 2.5". I'm running 295/70/18 Ridge Grapplers with slight rub on passenger front @ full lock. I am running 1 1/4" Spider Trak spacers. It's not enough for me to even remove it. With your choice of 285/70/18 and a +18 offset you should be fine with no rubbing or trimming.
    Marty McFly likes this.
  4. Mar 22, 2019 at 10:31 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Your alignment will have a lot to do on what needs trimmed and what won’t.
    conlons26, Omohundro, equin and 2 others like this.
  5. Mar 22, 2019 at 11:57 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    I got 285/65/18 Roosts on a stock suspension with mild rubbing at full lock. i took off my flaps fixed 95%
  6. Mar 23, 2019 at 4:56 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    I had the same offset wheel and tire size with 5100's on the top setting making around 2.5 inches of lift. I had to take off the mud flaps and pushed the fender liner up some. I still rubbed a slight bit on the fender liner in the rear just in reverse on an incline at full lock. You should be good to go. I really enjoyed the look of mine. I miss that truck IMG_2874.jpg
    TundraDude18 and parker44 like this.
  7. Mar 23, 2019 at 4:44 PM
    Blindf8th
    Thank you everyone for the input as this has been very frustrating as the alignment tech just adds to the success\failure which i did not know. Along with every tundra being slightly different just makes it all the more challenging it seems. Already have the install set for next Thursday, but maybe ill drop to the 285 65r18s just to be a little safe (dunno). Will post my findings either way to pass it forward :)
    Blind
  8. Mar 23, 2019 at 4:59 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    What @xtyfighterx said. It’s all about the offset and alignment.
    Rica25, GodlessPro and TheBeast like this.
  9. Mar 23, 2019 at 5:06 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just looked at the last example. Looks like Renlo had issues with his wheel rubbing the calipers. You won’t have that problem with Methods. And because of that, he added 1.25” wheel spacers, which basically makes it a -13 offset. That’s why he had so much rubbing.
    GodlessPro and Watt maker like this.
  10. Mar 23, 2019 at 5:56 PM
    Blindf8th
    Very interesting joonbug and great info! That has been one of the hangups for me as I just see the bs & offset specs and assume its just simple math, but wheel manufacturers design around those specs can be wildly different. Thank you for that sir.
    joonbug likes this.
  11. Mar 23, 2019 at 6:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You really shouldn’t have a problem with the Methods and RG 285’s. At most, you’ll remove the mud flaps, bend in your skid plate corners, and trim a little on the liners. You can also get bumper spacers instead of trimming the liner.
    Casper3, Rica25 and GodlessPro like this.
  12. Mar 23, 2019 at 6:28 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I have 285/70/18 RGs on +0 offset, 3" front lift with UCA, so I run 4.4/4.0 caster. I did CMC but not 100% sure I needed to with 285s. Definitely needed to trim the front liners. I could see the front bumper ends being an issue on stock UCA and low offset wheels if you can't get enough caster. But too much caster and you'll be hitting the cab mount.
  13. Mar 23, 2019 at 7:57 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    5100's on middle setting with 2 shims for 2.5" total and 5100's on rear with Toyotec shackle set at 1" lift. SCS Sr8's +25 with Nitto Ridge Grappler's 285/70r18
    I had slight rubbing in reverse at full lock backing to the right on the front plastics behind the bumper. Loosened the 4 bolts along the underside of the bumper on each side and pushed the plastic in while tightening the 4 bolts. No more rubbing.
    A lot of if it will fit will have to do with your alignment #'s.
  14. Mar 24, 2019 at 3:55 PM
    Blindf8th
    Very nice jwl019! Thank you for the pic and info sir. Greatly appreciated as I work through the decision making process :)
    jwl019 likes this.
  15. Mar 24, 2019 at 4:29 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    1143355B-E58C-4451-A733-DEB6B4485B07.jpg I have 285 70 18 RG. Toytech Boss 3/1 level. SCS Ray10’s and no rub. Hurt MPG but love the look and feel and performance.
    Good luck. D
    parker44 likes this.
  16. Mar 24, 2019 at 6:38 PM
    Blindf8th
    Heya Dabutcher. Nice side shot and great info! Any other pics that show full side view for comparison? Much appreciated if you do not, worries otherwise :)
    Also, how have you enjoyed your RGs?
  17. Mar 24, 2019 at 6:42 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
  18. Mar 24, 2019 at 6:53 PM
    Blindf8th
    For the folks on here with the 285 70r18 setup (or even 295 70r18) do any of you have a full size spare under the carriage?
  19. Mar 24, 2019 at 7:44 PM
    Blindf8th
  20. Mar 24, 2019 at 8:08 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    Nope, I don’t think 295s would fit, it’s just for emergencies so stock size is fine.
  21. Mar 24, 2019 at 8:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. Both fit fine. Even 35’s. You may have to remove the tire guides to get the 295 to sit completely flush.
  22. Mar 24, 2019 at 8:28 PM
    Blindf8th
    So you could use a 275 55r20 with 3 285 70r18s? That just sounds like it would not even work even for an emergency. Wow!
  23. Mar 24, 2019 at 8:49 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    285/70/18 stock pro suspension, mounted on stock pro wheels and no rub. I put spidertrax spacers and got rub on the front bumper I had to take a heat gun to the front wheel wells a wee bit. You are correct every truck is different. If your bumpers aren't square that could effect your rub as well. Give it a go and work through it as it comes. The size your going with will be very manageable. If you tried stuffing a 37 in there then we would have to bust the torch and sawzall out haha
  24. Mar 24, 2019 at 8:55 PM
    War_Wagon312
    Rich
    Stock horse
  25. Mar 24, 2019 at 9:55 PM
    Blindf8th
    Great picture War_Wagon312. Not to many side shots of this tire\wheel combo. Was initially concerned with the wheels hitting the fender rolling over bumps etc, but that looks like it has decent clearance. Ever have any trouble? Thanks again!
    Rica25 likes this.
  26. Mar 25, 2019 at 5:05 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    OP, I wouldn't drop down to a 285/65/18. Once you start adding a lift to these trucks, that size can look very small. I think Nitto nailed it with the 285/70/18 Ridge Grappler. You are still close to the same size of 295/70/18, but saving almost 10 lbs per tire. The weight on these tires is huge. Based on their website, those 285's are only about 1 lb heavier than my 275/70/18.
    Tundra234 and PermaFrostTRD like this.
  27. Mar 25, 2019 at 6:02 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    285/70r18's RG on SCS Ray 10's +25 offset, Bilstein 6112's @ 1.9" setting with driverside CB shim and CB +3 shackles in rear. Trimmed skid plate, fender liner and removed small frt mud flap.20190325_084848.jpg
    equin likes this.
  28. Mar 25, 2019 at 7:05 AM
    War_Wagon312
    Rich
    Stock horse
    No sir the only time I rub is at full lock in reverse and it is a slight rub.
  29. Mar 25, 2019 at 10:00 AM
    Dabutcher
    D
    Twin Cities
    Side view I promised you Good luck DFAFA24C2-4958-45E2-8085-5AD0C34E861A.jpg
  30. Mar 25, 2019 at 4:58 PM
    Blindf8th
    Casper3 thank you so much. Quick question... How much lift in inches does the driver side shim (assuming to eliminate the slight lean compared with the passenger side) get you? Also, does the +3 shackles mean 3 inches? If not what is that height?
    Thanks a mill!
