Synthetic oil instead of the OEM recommendation?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marnan, Mar 23, 2019.
  1. Mar 23, 2019 at 10:42 AM
    Marnan
    Marnan [OP] New Member
    2017 tundra sr5
    Any opinions on using synthetic engine oil instead of the OEM recommendation
  2. Mar 23, 2019 at 10:50 AM
    15whtrd
    15whtrd Mr. Blonde
    OEM recommened oil is synthetic. Actually pretty sure it’s rebranded M1.
    Rocko9999, 757TUNDRA, Buildn and 8 others like this.
  3. Mar 23, 2019 at 10:51 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    You could change the poll and pick out a few top brands to see which is preferred? Just a thought.
    Tundra_361 and 15whtrd like this.
  4. Mar 23, 2019 at 10:52 AM
    15whtrd
    15whtrd Mr. Blonde
    0-20 any brand is sufficient. If you want the best, Amsoil is a great choice.
    jsteph89, Js18tundra, Hbjeff and 2 others like this.
  5. Mar 23, 2019 at 10:53 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You can only get the OEM recommended viscosity in 100% synthetic, a full synthetic, or a synthetic blend. Are you asking if we prefer 100% synthetic to a full synthetic?
  6. Mar 23, 2019 at 11:38 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You came to the wrong internet if you want opinions on engine oil.
    Everyone here uses the same exact brand/grade and we all hold PhD's in tribology.
  7. Mar 23, 2019 at 12:00 PM
    marlin39a
    marlin39a I’m a dumbass.
    This pole does not make sense.
    Sas, Ericsopa, UTTundra and 3 others like this.
  8. Mar 23, 2019 at 12:04 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    As others said,
    OE = synthetic
    Marnan[OP], Ericsopa and 15whtrd like this.
  9. Mar 23, 2019 at 12:05 PM
    JohnLakeman
    It doesn't even make sense as a "poll" either. :D
  10. Mar 23, 2019 at 2:37 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Said a stripper, never.
  11. Mar 23, 2019 at 2:42 PM
  12. Mar 23, 2019 at 2:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If a man is all alone in the deepest forest, is he still wrong?
    Patriot, tenntundra, Hbjeff and 2 others like this.
  13. Mar 23, 2019 at 3:05 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Nice. New acct and drops an oil thread.
    Elk hunter would be proud!
    Btw. The answer is Coconut Oil.
    dandailey, JohnLakeman and hagrid like this.
  14. Mar 23, 2019 at 3:57 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Was that “tribology” or “ garbology.”
  15. Mar 23, 2019 at 4:50 PM
    SG TRD
    SG TRD New Member
    When is a MAN wrong!! If a man in the forest speaks and nobody hears it, does he still makes a noise??
  16. Mar 23, 2019 at 4:52 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Name of your first porn film.
  17. Mar 23, 2019 at 4:55 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Is there a difference between full synthetic and 100% synthetic?
    What is Mobil 1?
    Thanks.
  18. Mar 23, 2019 at 4:56 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    this thread is as special as a left handed screwdriver
  19. Mar 23, 2019 at 4:56 PM
    JohnLakeman
    What's a "porn" film? o_O
  20. Mar 23, 2019 at 5:06 PM
    JohnLakeman
    Yup. Mobil 1 is full synthetic. Look on oil containers, they will ALL say explicitly that the product is either "100% synthetic", "full synthetic" or a synthetic blend, or of course, conventional.
    The only 100% synthetic motor oils (Poly Alpha Olefins) are Amsoil, Royal Purple, and one or two others. Back in the day, I think Mobil 1 was actually 100% synthetic, but no longer. THAT explains why those brands are more expensive, but in general, you would need a much more severe operating environment to actually see any benefit from using "100% synthetic" over "full synthetic" motor oil, or even conventional motor oil for that matter. There, I've said it; that's my story and I'm sticking to it. :D
  21. Mar 23, 2019 at 6:03 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Hummm... The angle of the danger still needs to be in direct proportion to the mass for it to be fully effective... :facepalm:
  22. Mar 23, 2019 at 8:27 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That’s what she said.
  23. Mar 23, 2019 at 8:52 PM
    Ericsopa
    Ericsopa Old man and the sea
    Yeah, but in this case fully synthetic mass is less effective...:anonymous:
  24. Mar 23, 2019 at 8:52 PM
    Therin7
    Therin7 New Member
    West Tennessee
    2014 Tundra Platinum
    Everyone knows TOYOTA BRAND oil is made using only the finest dinosaurs!
  25. Mar 23, 2019 at 8:57 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Maybe that's why the poll has check boxes instead of radio buttons. There's more than one answer here.
  26. Mar 23, 2019 at 9:04 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Swear by it.......
  27. Mar 23, 2019 at 9:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Been performing for so long now I cannot remember
  28. Mar 23, 2019 at 9:11 PM
    Trooper2
    JR
    "The Amnesiac Stud Muffin" LOL
    gosolo[QUOTED] likes this.
  29. Mar 23, 2019 at 9:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Retired not retarded!
    Black Wolf likes this.
  30. Mar 23, 2019 at 9:15 PM
    Trooper2
    JR
    In Dale Gribble's voice............
    15whtrd and gosolo[QUOTED] like this.
