Bilstein 5100s...Top or Middle setting?
Discussion in 'Suspension' started by ToyotaTundraMike, Apr 10, 2016.
  1. Apr 10, 2016 at 3:45 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    I think the middle is 1.8" and the top is 2.2".
    Getting my shocks put on this week and wondering which setting I should go with on the front shocks. Also getting the 275/70/18 Cooper ST Maxx tires put on this week. Any difference in ride quality between the two settings? Thoughts or recommendations? I tow my boat quite a bit, and don't plan on adding anything in the back. Definitely don't want the nose-up look.
    Anyone have pics of truck on middle setting?
  2. Apr 10, 2016 at 5:36 PM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2023 ICE CAP SR5 CREWMAX
    Been thinking of the same thing, would definitely like to see some pics. after you have it done. Personally I think the top setting is just too much without doing something to the rear.
  3. Apr 10, 2016 at 8:00 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think the middle setting is closer to 1.5" of lift. I had these on my Taco and set at the top. The ride was pretty firm with the spring compressed and eventually replaced the spring with a longer OME and set the clip back to stock position. Wished I had done that to begin with.
    I tow often as well including a boat and if you don't want a bro lean then I wouldn't do the top position. I would recommend an AAL or bigger shackles in the rear for towing though. It really does make a difference and you don't sag when towing.
    SouthBoundSteve likes this.
  4. Apr 11, 2016 at 6:44 AM
    ToyotaTundraMike
    2015 Tundra
    Thanks, may look into the shackles. My boat and 4wheeler trailer are the only things that I tow, and they don't weigh very much, but I def don't want the lean.
    Nobody has gone with the middle setting? For those of you with Bilstein's on the top setting, do you have a bad lean while towing?
  5. Apr 12, 2016 at 6:44 AM
    ToyotaTundraMike
    2015 Tundra
    Well according to the specs on toytec website the middle setting is 1.57" and the top is 2.28"
    Decisions decisions....
    I'm thinking the 1.57" may be enough lift in the front for my taste (specially since im only going with 33's). Should give it a more level look without having the lean while towing the boat. Would love to see a picture of someone on middle setting.
  6. Sep 27, 2016 at 2:36 PM
    harrisdoggy
    harrisdoggy New Member
    Josh
    2016 Toyota Tundra CrewMax SR5
    @ToyotaTundraMike - what did you end up doing then? Trying to decide the same thing. Would like as close to level as possible, but don't want anything where the front is too high. Do you have any pics? How is the ride at the top versus middle?
  7. Sep 27, 2016 at 3:12 PM
    ToyotaTundraMike
    2015 Tundra
    No regrets here @ middle setting. Check the link in my sig and theres some pics in my build thread. A perfect level is 2". Middle setting is about 1.7" so there is still a slight rake whereas the top setting is about 2.2" or so which looks more level but may give you the nose up look while towing.
    jewsNbrews and harrisdoggy like this.
  8. Sep 27, 2016 at 3:28 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Airbags in the rear to prevent squat. Done.
  9. Sep 27, 2016 at 3:42 PM
    harrisdoggy
    Josh
    @ToyotaTundraMike - thanks for the info. Truck looks great! No issues with 275/70r18 tires rubbing with middle setting?
    ToyotaTundraMike[OP] likes this.
  10. Sep 27, 2016 at 6:31 PM
    ToyotaTundraMike
    2015 Tundra
    Thanks! No issues at all!
    ATV25 and harrisdoggy[QUOTED] like this.
  11. Sep 28, 2016 at 6:17 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    while i don't run 5100's i do have 6112's which are bigger and heavier in every way. they are set up on the 3rd setting which is likely very similar to what you'd get on the top setting with 5100's and the result is almost a perfect level with no changes to the rear at all.
    harrisdoggy[QUOTED] likes this.
  12. Sep 28, 2016 at 6:23 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I have the 5100's on top setting and when I initially installed them with no lift in rear, the front looked way too high but measured very close to perfectly level. Like @Law323 has mentioned before, these trucks are funny. They need at least 0.5" lift in rear to look level.
    The middle setting will look just right if you don't want to lift the rear at all. Just my opinion...
    ATV25, Law323, harrisdoggy and 2 others like this.
  13. Sep 28, 2016 at 6:50 AM
    PlatinumPro
    even though my measuring tape tells me i'm higher in the back end but very close to level i still find i'm tilting my head. they appear to sit cali-style without a little rake.
    harrisdoggy likes this.
  14. Apr 18, 2018 at 8:52 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Installed 5100s yesterday. Seems higher in front.
  15. Apr 18, 2018 at 8:57 AM
    ToyotaTundraMike
    2015 Tundra
    Did you read this thread at all? Lol..
    757TUNDRA and JoshuaA like this.
  16. Apr 18, 2018 at 9:08 AM
    e30cabrio
    I did how was your response helpful?
  17. Apr 18, 2018 at 9:10 AM
    ToyotaTundraMike
    2015 Tundra
    You seemed a little surprised it was nose high after install but literally every post in this thread said the same that it would be lol. Just curious if you happened to read here before the install and that was what you were actually going for or if you saw this thread afterwards.
    757TUNDRA likes this.
  18. Apr 18, 2018 at 9:13 AM
    e30cabrio
    My truck has 170k & was ready for shocks (although still felt fine) I bought & installed the appropriate 5100s and it seemed nose high so searched 2010 Tundra front end high after 5100 install & found this thread.
  19. Apr 18, 2018 at 9:16 AM
    ToyotaTundraMike
    2015 Tundra
    Ahh. Well that’s unfortunate that you didn’t find that info beforehand but there are things you can do if it bothers you that it’s nose high a little. Coach builder makes a .6 inch shackle that slightly lifts the rear. That may be an option for ya. Personally don’t think it’s that noticeable until you have to tow something though
  20. Apr 18, 2018 at 4:56 PM
    e30cabrio
    Thanks.
  21. Apr 20, 2018 at 8:50 PM
    Odb1987
    Odb1987 New Member
    My local 4 wheel parts said they had a lot of complaints at top setting about the ride being rough. They recommend middle setting. I had them remove a 3/1 spacer lift and install 5100’s at middle setting. Nothing in the rear. Very happy with the results.
    ATV25, clarkritchie and 757TUNDRA like this.
  22. Apr 20, 2018 at 11:05 PM
    HOTDAM
    HOTDAM Feeling Dangerous
    2013 Crewmax 4x4
    Same here. Middle with stock rear. Rides and looks great to me.
    ATV25 likes this.
  23. Apr 20, 2018 at 11:25 PM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    Middle setting for me too...
    ATV25 likes this.
  24. Apr 21, 2018 at 9:36 AM
    e30cabrio
    I took pictures & measurements for Coachbuilder (great guy btw) 39" is where the front sits & where I'd like the back to be.
    First pic is where it sits, second is lifted to 39" by my jack at the hitch.
  25. Apr 21, 2018 at 9:53 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Middle setting here and she sits level..
    ATV25, Abos, rv740 and 1 other person like this.
  26. May 30, 2018 at 6:34 PM
    Crewmax34
    Crewmax34 New Member
    What size tire are you running on the middle setting and do you have aftermarket wheels.
  27. May 30, 2018 at 8:38 PM
    saybng
    Gary
    Ventura CA
    Who are you asking?
    jewsNbrews likes this.
  28. Jun 6, 2018 at 6:07 PM
    Crewmax34
    Saybng what size tire are you able to run on the middle 5100 setting.
  29. Jun 7, 2018 at 9:22 AM
    saybng
    Gary
    Ventura CA
    275.65.20
    Raxman80 likes this.
  30. May 29, 2019 at 12:50 PM
    the mailman
    the mailman New Member
    2014 Tundra Gun Metal Gray
    Just starting
    I'm thinking of going with the 5100 at the middle setting with one coachbuilder shim on driver side to eliminate the 1/2 inch lean
