I'm screwed
Discussion in 'General Tundra Discussion' started by TRD-tv, Mar 20, 2019.
  1. Mar 20, 2019 at 12:20 PM
    TRD-tv
    TRD-tv [OP] New Member
    OHIO
    2012 MGM Tundra TRD
    Is there a reason as to how come the bolts mounting my seat come out no problem but refuse to go back in....
    Theyll only go down this far until they give up. No passengers until I figure this one out I guess20190320_151421.jpg 20190320_151425.jpg
  2. Mar 20, 2019 at 12:24 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Take them back out and see if the treads are messed up.
    Black Wolf and JoshuaA like this.
  3. Mar 20, 2019 at 12:26 PM
  4. Mar 20, 2019 at 12:27 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    they appear to be okay to the naked eye. the two front bolts went in and all 4 appeared the same, i tried using different bolts in different holes tightening by hand and they appear to get hung up on similar spots.
    wonder if @Roman could get me new bolts
  5. Mar 20, 2019 at 12:51 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  6. Mar 20, 2019 at 12:52 PM
    TheBeast
    TheBeast The Beach
    wiggle them around and move seat brackets around. I use a socket wrench and after couple turns they line up fine.
    I installed the same vleds lights there too ;)
  7. Mar 20, 2019 at 1:19 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    I'm hoping this is the issue although I like to believe I tried it already. For that price I'm gonna order some new bolts as well
  8. Mar 20, 2019 at 1:21 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Maybe a bit of lube?
    MT Madman, ecm209, ColoradoTJ and 5 others like this.
  9. Mar 20, 2019 at 1:21 PM
    TheBeast
    TheBeast The Beach
    are you re-using the same bolt that came out or did you swap left and right ?
  10. Mar 20, 2019 at 1:23 PM
    15whtrd
    15whtrd Mr. Blonde
    Did you try the bolts without the seat in the place? Also did you try a little lube on the threads or never-seize?
  11. Mar 20, 2019 at 1:25 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    all of the above - i was anal to keep them in their respective corners, i have tried swapping them around however as my options are exhausting
    15whtrd likes this.
  12. Mar 20, 2019 at 1:25 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    i tried that
    Black Wolf and TheBeast like this.
  13. Mar 20, 2019 at 1:27 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    i did not try it without the seat in place. thats a good idea. and what kind of lube u got in mind? i used some white lithium grease to no avail
  14. Mar 20, 2019 at 1:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    keeping all bolts loose, tighten a bit each at time?
  15. Mar 20, 2019 at 1:28 PM
    TheBeast
    TheBeast The Beach
    yeah give it a try without seats on.
    Seantron and 15whtrd like this.
  16. Mar 20, 2019 at 1:28 PM
    Trooper2
    JR
    any kind of grease for lube
    15whtrd likes this.
  17. Mar 20, 2019 at 1:29 PM
    15whtrd
    15whtrd Mr. Blonde
    What you used should be fine. Do you have a tap you could maybe chase the threads with? I wonder if anyone knows if these are some type of locking thread. Maybe a safety screw of some sort because it’s holding the the seat in place.
    Hard to see how you could’ve ruined them just by taking them out unless they were cross threaded from the factory.
    Watt maker and TheBeast like this.
  18. Mar 20, 2019 at 1:29 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    white lithiums mater?
    15whtrd and TheBeast like this.
  19. Mar 20, 2019 at 1:30 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    thats kinda my thought. the bolts are tapered. as if its catching a thread above and a thread below a support beam
  20. Mar 20, 2019 at 1:31 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe try leaning on it a little bit to get the two metals to sandwich together.
    Smiley and TRD-tv[QUOTED][OP] like this.
  21. Mar 20, 2019 at 1:33 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    ...if only it weren't a seat bolt
  22. Mar 20, 2019 at 1:36 PM
    Omohundro
    Jody
    McMinnville TN
    My thoughts are, you’re not holding your mouth right. Make sure the front bolts are loose and keep trying.
  23. Mar 20, 2019 at 1:37 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    you sound like my dad lol im afraid of stripping the threads or damaging it further
    Darkness, NewImprovedRon and 15whtrd like this.
  24. Mar 20, 2019 at 1:39 PM
    Omohundro
    Jody
    McMinnville TN
    These tapered machines threads are tricky sometimes. How many turns are you getting before they seize?
  25. Mar 20, 2019 at 1:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe get someone to sit in the seat. I don’t know I’m just throwing shit out there now.
  26. Mar 20, 2019 at 1:41 PM
    Omohundro
    Jody
    McMinnville TN
    With the front bolts loose so you have movement in the seat tracks. It sometimes helps to turn the bolts backwards a bit. This will sometimes let you feel the bolt drop in.
    TRD-tv[OP] and 15whtrd like this.
  27. Mar 20, 2019 at 1:45 PM
    Omohundro
    Jody
    McMinnville TN
    You can also use a longer extension to help start the bolt straight, use the extension as a visual guide.
    Straight
    Crooked
    You get what I’m saying?
  28. Mar 20, 2019 at 1:48 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I removed my seats to install Katzkins with an impact driver but I hand tightened to re-install. I found they mis-thread easy. A couple of them I did mate them down without the seat to make sure they caught right all the way. They key was not to keep going if there was too much resistance at the beginning. Inspect the threads closely, maybe you do need new bolts, hopefully not.
    15whtrd and TRD-tv[OP] like this.
  29. Mar 20, 2019 at 1:49 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    yeah they sure are haha and maybe 15- 20. the photo is the best way i can think to show ya how far. they tighten up quick. u got any ideas lol
  30. Mar 20, 2019 at 1:50 PM
    Omohundro
    Jody
    McMinnville TN
    15-20 full turns?
