XM Tuner
Discussion in 'Audio & Video' started by vidman, Sep 25, 2016.
  1. Sep 25, 2016 at 1:26 PM
    vidman
    vidman [OP] New Member
    Rick
    Massachusetts
    Do we have a seperate XM tuner in our trucks or is it part of the factory radio. i would like to swap out the XM antenna but do not want to pull the whole truck apart to find out where the tuner is..Need some help with this. Thanks
  2. Sep 25, 2016 at 1:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    XM tuner is in the factory head unit. The antenna plugs into the back of it so it sounds like your swap is plausible.
  3. Sep 26, 2016 at 5:25 PM
    FLTrucks
    FLTrucks New Member
    The XM tuner is actually attached to the bottom of the radio. The XM wire antenna runs from the roof down the A-pillar on passenger side.
    Wynnded likes this.
