Can’t decide (brakes)
Discussion in '2nd Gen Tundras (2007-2013)' started by Spookz01, Mar 17, 2019.
  1. Mar 17, 2019 at 3:39 PM
    Spookz01
    Spookz01 [OP] New Member
    2011 crewmax tundra
    Led interior lights
    Hello,
    I am looking at upgrading my brakes to the powerstop z36 series set but I was wondering, are the slotted rotors really worth it are just go with the oem rotors with the powerstop xtreme pads and calipers?
  2. Mar 17, 2019 at 4:15 PM
    rodneysworld
    rodneysworld New Member
    rodney
    2011 charcoal gray tundra
    series 77 K n D intake, rims and tires, KYB shocks, leveling kit, drilled slotted rotors, carbon fiber pads, interceptor tuner, flomaster catback dual exhaust, Spider halo projector headlights, Pioneer head unit, JL Audio Amps, JL Audio allaroundSpeakers
    I went with same type rotors and they are good but I think OEMs just as good
    They do look nice though!!!
  3. Mar 17, 2019 at 4:30 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    OEM Tundra brakes and rotors are junk.
    WhitexShadow likes this.
  4. Mar 17, 2019 at 4:41 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I have these rotors also. Slotted/drilled rotors don't really change braking performance under normal street driving.
    Their purpose is to help prevent brake fade during heavy use (racing and towing) by cooling the rotor and clearing hot gases from between the pad and the rotor.
    You only see any significant benefits in conditions that would overheat OEM-style pads and rotors.
    They make a huge difference when I'm towing a heavy trailer in the mountains, but there's no noticable improvment otherwise.
    csfuser and JoshuaA like this.
  5. Mar 17, 2019 at 4:54 PM
    619Tundra
    I just got my set of Power Stop Z36 Rotors and Pads front and rear. I hope they perform.
    Prostar 190 likes this.
  6. Mar 17, 2019 at 4:59 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    Personally I would look into Dimpled/Slotted rotors if you are towing, heavy payload, or lifted with larger tires. Daily Driving there isn't much need to go beyond OEM-style as mentioned before. Also don't go drilled, there is a lot of information out there related to stress fractures due to a compromise in structural integrity.
    I plan to go with EBC Yellow with an EBC Dimpled/Slotted or similar configuration different brand when I need to change.
    Few articles about drilled/dimpled/slotted rotors.
    https://ebcbrakes.com/articles/dangerous-cross-drilled-rotors/
    https://ebcbrakes.com/articles/ebc-old-brake-selector-tables/
    Edit: Also bed in new pads/rotors
    https://ebcbrakes.com/articles/bedding-in/
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=85
    https://brakeperformance.com/bedding-in-rotors.php
    Jengel451 likes this.
  7. Mar 17, 2019 at 6:25 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    I have the z36 tow break package on my Tundra and the slotted rotors.
    Great buy only had an issue of the rotors digging In to the dust covers and made a terrible grinding sound.
    Still recommend them if you tow anything supper heavy but not needed for standard towing.
    619Tundra likes this.
  8. Mar 17, 2019 at 6:29 PM
    I have the Power Stop rotors and Z36 pads and would buy them again in a heartbeat. Toyota factory rotors are known to pulsate after a while these never have.
    JoshuaA and 619Tundra like this.
  9. Mar 17, 2019 at 6:31 PM
    Oh and they look damn good also! [​IMG] [​IMG]
    Hammerdog, rons23, drhntr and 7 others like this.
  10. Mar 17, 2019 at 6:36 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    consider frozen rotors; will be installing these on the tundra as soon as factory brakes are done.
    in quotes below was a post i made about a month ago.
    "had an '05 titan with rotors that belonged on a sentra... warped... warped again... replaced with frozen rotors. they are cryogenically frozen and this is no gimmick. mixed those with some green box hawk pads. i drove the pickup like i stole it, and those rotors would NOT warp.
    currently own a '19 cm limited tundra. these are the best factory brakes i've ever had on a 1/2 ton pickup.
    when these pads go, the whole setup will be replaced with power slot frozen rotors and green box hawks."
    Yodder J likes this.
  11. Mar 18, 2019 at 1:36 AM
    WhitexShadow
    WhitexShadow New Member
    Cesar
    2017 TRD Pro (Red Dragon)
    Stock
    Yup. Already had to have the stock ones machined Brakes sqeak and of course the dealer couldn't find a problem with them. I thought the PROs came with slotted rotors but I guess I was wrong. All 3 Tundras that I've had 2011 SR5, 2014 SR5, and 2017 TRD Pro I've had the rotors warp within the first 10k. So yes. I don't favor OEM on this one thing.
  12. Mar 18, 2019 at 2:12 AM
    Chief 01
    Chief 01 New Member
    PA
    2020Tundra Pro Army green
    Stay away from drilled, go with slotted only. No experience with dimpled.
  13. Mar 18, 2019 at 2:55 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    My Mechanic assures me I'll get 100,000 miles from my junk stock brakes. Just turned 82,000 miles with 5/8" left on the pads. Unless Toyota has changed venders (HIGHLY LIKELY) I'll stay with OEM.
    chamyota and WrigglingWilly like this.
  14. Mar 18, 2019 at 5:56 PM
    Vince
    Vince New Member
    Vincent
    I got 130000 miles out of my stock pads the rotors went to crap but I do a lot of highway miles.
  15. Mar 18, 2019 at 7:23 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I would say stay solid if you plan on going in mud, the others can pack with dirt.
  16. Mar 19, 2019 at 11:01 AM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    I had some turnout in mine by 30k and truck was still bone stock. They had to machine them and wanted to road test first told them I didn’t have time during oil change and I guess the mechanic said the rotor was off enough you could see it with naked eye so they just went ahead and did it
  17. Mar 19, 2019 at 5:35 PM
    careyrob
    Carey
    Massachusetts
    That's interesting. I have a friend who owns a racing school and he recommended drilled and not slotted. He said that he's had trouble with slotted rotors cracking on race cars, but no problems with drilled rotors cracking.
  18. Mar 19, 2019 at 5:38 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Subscribed
  19. Mar 20, 2019 at 12:41 PM
    Spookz01
    2011 crewmax tundra
    Led interior lights
    I have had my tundra for about a month now. The previous owner had the stock rotors/calipers but upgraded pads. After a month I noticed a really bad pulsing when braking, so I am looking for the best bang for the buck. Right now I have the z36 pads coming in about a week (which I’ve heard are fanstastic).
    However, I am looking for long time fixture savings. Like the saying goes “if your going to do it, do it right the first time”
  20. Mar 23, 2019 at 2:40 PM
    csfuser
    csfuser New Member
    2009 Silver DC
    working on upgrading the audio..
  21. Mar 23, 2019 at 3:10 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    I'm pretty sure the Tundra uses Akebono pads. When I replaced my pads, I went to Toyota to buy another set as I'm happy with the stock brake setup.
    rons23 likes this.
  22. Mar 23, 2019 at 3:23 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @csfuser, check here, good prices and they carry the eLine products. There good, as mentioned above stay away from drilled rotors, also unless your doing some towing you dont need high end pads. My opinion of course. Hope this helps
    https://www.r1concepts.com/
    csfuser[QUOTED] likes this.
  23. Mar 24, 2019 at 10:56 AM
    csfuser
    csfuser New Member
    2009 Silver DC
    Thanks for the info.. yeah.. my mechanic iterated the same opinion to me when I had to do brakes on my last truck. You don't need drilled/slotted rotors for normal use. I DO tow occasionally, but nothing large and not anywhere mountainous.
