  1. Mar 17, 2019 at 10:58 AM
    #5071
  2. Mar 17, 2019 at 11:00 AM
    #5072
    Ya I just named the only Canadian beer I knew. It must be the Bud Light of Canada. :)
    As for your question. I'm not the pro, but I'd probably wait until the end to try touch up. I have a feeling you'd just wax it off if you tried it before. That would probably be a good question for the "ask the detailer" thread. I never have good luck when trying to touch up my paint. It never lasts.
  3. Mar 17, 2019 at 11:00 AM
    #5073
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I think at that cost I'd rather either keep it on or remove it forever lol
  4. Mar 17, 2019 at 11:02 AM
    #5074
    because_wumbo-truck
    Jon
    Houston, Texas
    Kinda dig the light bar. More pics?
    NUDRAT likes this.
  5. Mar 17, 2019 at 12:18 PM
    #5075
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    After 60 miles hot as the atf gets o_O.. Still might put a external trans cooler do to rad and transmission lines and current problems with milkshake.
  6. Mar 17, 2019 at 12:44 PM
    #5076
    So you DID figure out how to get Trans Temp with the scangauge? Did you already explain how and I missed it? I know it was being debated recently.
    I'm not familiar with the Scangauge. What else can it be used for on our trucks?
  7. Mar 17, 2019 at 12:44 PM
    #5077
    Outbound
    Aaron
    Northern Alberta
    Molson is vaguely beer flavored water. Lol.
    I'll post in the detailer thread when the time comes.
    Todat I pulled off the winter tires, and did a quick inspection. Going to grease all the nipples when the ground dries out more. I also confirmed that I have the LSD.
    I did discover my driver side rear shock boot is torn already. Pissed me off, I only put these shocks on last year. Looks like a clean cut so either the mechanic sliced it for some reason during install or it just separated. Not sure if I can replace it without fully removing the shock. Really dont want to do that.
    Anywho, here she is back in her natural, filthy form.
  8. Mar 17, 2019 at 2:23 PM
    #5078
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Outbound the boot isn't doing much for you anyhow. You would have to remove the shock to replace it, but their use is debatable.
    One school of thought says they protect the shafts from dust, rocks and debris. Another school says they trap moisture and cause deterioration. All of the high end Fox/Icon/King/Etc do not use boots.
    the red, Sunnier, bmf4069 and 4 others like this.
  9. Mar 17, 2019 at 2:24 PM
    #5079
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Have you verified CK / Standard wiring?
    https://gtrlighting.com/blog/do-i-have-ck-or-standard-wiring/
  10. Mar 17, 2019 at 2:31 PM
    #5080
    I follow a guy on IG that has 37's on this first gen. It's some crazy cool long travel build. 35's look so awesome on our trucks.
    because_wumbo-truck likes this.
  11. Mar 17, 2019 at 2:36 PM
    #5081
    Outbound
    Aaron
    Northern Alberta
    Good to know, thanks! I'll leave it alone then. :)
  12. Mar 17, 2019 at 2:38 PM
    #5082
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Wouldn't this be patch it or remove it? Seems a tear will be worst of both gathering & holding road debris & water.
  13. Mar 17, 2019 at 2:42 PM
    #5083
    Outbound
    Aaron
    Northern Alberta
    We'll see I guess. I'll keep an eye on it. The boot is basically two pieces now, that fit together snugly. It's almost as if somone took a razor blade and cut around the circumference of the boot.
  14. Mar 17, 2019 at 3:06 PM
    #5084
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Who'd you cut off? :eek2:
    http://www.patchrubber.com/tire_repair/15044_sec.html
    or some such.
    Outbound[QUOTED] likes this.
  15. Mar 17, 2019 at 3:08 PM
    #5085
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So after extensive ducking around, double cab sunvisors will not fit reg cabs without extensive work. So. Now I’m stuck with 80 dollars in sun visors. Oh well. The more you know, lol
    Oh I have my tilt steering column now though
    because_wumbo-truck and NUDRAT like this.
  16. Mar 17, 2019 at 3:14 PM
    #5086
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I also had an unsuccessful repair day. Pulled the TB off my Honda to clean the IACV but it is not coming clean. Have to order a new one and wait now, but on the bright side I found that my TB was missing a gasket.
    o_O how the hell???
    As far as my first gen, considered getting nice floor mats.
    NUDRAT likes this.
  17. Mar 17, 2019 at 3:20 PM
    #5087
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I learned this lesson once with sedan v. convertible sun visors. :-(
  18. Mar 17, 2019 at 3:34 PM
    #5088
    Outbound
    Aaron
    Northern Alberta
    NUDRAT[QUOTED] and Darkness like this.
  19. Mar 17, 2019 at 3:51 PM
    #5089
    empty_lord
    05 rollover special
    I was too hopeful should of known better. Lol. At least I have a column. And bonus was I got the wheel with spiral cable and everything to mod into my tacoma
    NUDRAT[QUOTED] and lsaami like this.
  20. Mar 17, 2019 at 4:21 PM
    #5090
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Had a good Tundra day! Replaced the PCV valve and grommet, greased my u-joints, and topped off my diff. (Axle seal leak). The diff was actually pressurized when I pulled the fill plug out. Ugh.
    Nasty!
    Also, I took another pic next to my dad’s truck. We’re both running 265/75/16 tires, I have a 2” lift, and he has a 1” lift.
    I measured the height, and my truck sits 2 whole inches higher. Doesn’t make any sense, especially since my truck has a broken leaf spring, and his has brand new springs and shocks.
  21. Mar 17, 2019 at 5:03 PM
    #5091
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    But Dad has the weight of the cap on his ride.
    (& apparently a sense of humor judging by the plate - LOL)
    Clogged up diff breather? Time to change & if so time to change front & trans breathers too...?
  22. Mar 17, 2019 at 5:23 PM
    #5092
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah buddy. That PCV is nasty. Time for a new one. And lets work on your cuticles too before the next shoot.
  23. Mar 17, 2019 at 5:44 PM
    #5093
    Mike Tread lightly.
    south carolina
    works just fine with the scangauge thanks to @Darkness :thumbsup: post 4884 . Used for temps to ign advance, clear codes on the go there is a list online you can program into the unit.. Only thing i dont like is what the ultragauge has that is preset alarms example engine temp over preset temp it goes off and so on.. I have it in my tacoma works perfect.. If i had to choose between the two its up in the air. They both are good. Refresh rates on both are good.
    Both will not replace say my snap on verus d 10 i have but all and all man they are worth it and a good investment.
  24. Mar 17, 2019 at 5:58 PM
    #5094
    lsaami
    lsaami Let ‘er buck
    Minnesota
    The front and trans breathers are fine surprisingly. I actually just looked at those and fluid was leaking from them because the dealership didn’t clip them back in when they did the frame replacement, and they were just dangling by the motor mount.
  25. Mar 17, 2019 at 6:12 PM
    #5095
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    I would really love to do that, but it's my daily so 37s aren't practical haha
  26. Mar 17, 2019 at 6:56 PM
    #5096
    Mike Tread lightly.
    south carolina
    if you have a stepside like mine dont lift it.... i saw one with 3 inch lift... I hate to sound this way but it was F@#4 ugly.
    Darkness likes this.
  27. Mar 17, 2019 at 7:08 PM
    #5097
    Casper421
    In the woods
    06 DC
    Haha. Not a fan?
  28. Mar 17, 2019 at 7:19 PM
    #5098
    Mike Tread lightly.
    south carolina
    :facepalm:
    edit i need to add this :rant: add this one i know i will make someone mad. :crapstorm:
  29. Mar 17, 2019 at 7:56 PM
    #5099
    Casper421
    In the woods
    06 DC
    Let me try this one:
  30. Mar 17, 2019 at 8:31 PM
    #5100
    because_wumbo-truck
    Jon
    Houston, Texas
    I used to hate the stepside but it's really grown on me. Like a dog that's so ugly it's kinda cute lol. If I were to buy one I think I'd want it to be a 2wd manual 4.0L v6 model w/ stepside. I'd lower it, supercharge it, do a side exit exhaust (like a lightning) and call it a day.
    To me, when it comes to lowered trucks it's all about uniqueness. I love seeing rare minitrucks like VW, Luv, Courier, Mitsubishi, Datson, etc
    bmf4069 and Darkness like this.
