Why can’t the Tundra get along with aftermarket wheels?
Discussion in 'Wheels & Tires' started by kralc8954, Mar 4, 2019.
  1. Mar 4, 2019 at 6:02 PM
    kralc8954
    kralc8954 [OP] New Member
    ‘19 CrewMax SR5 4x4
    KMC XD128/Toyo AT Open Country/Westin Protraxx 4
    I have read post after post on this forum and all over the internet about steering wheel vibration with aftermarket rims on Tundras. Some people seem to have found a solution through Road Force Balancing but many tried it without success. Hub centric rings and extended thread lugs are other fixes I’ve seen mentioned.
    I went from stock steel wheels to 18” KMC XD128 Machetes (hub centric) with Toyo AT Open Country 275/65 and still have the vibration after road force, alignment, replacing a bad tire, and using extended thread lugs torqued to 97 ft/lbs. It’s not unbearable but still quite noticeable. I plan to have another road force done at my 5,000 mile service.
    My question is this, has anyone figured out a cause of the vibration with aftermarket wheels? Is it simply the change in offset/backspacing the Tundra doesn’t like?
    cook2kill and Haymaker88 like this.
  2. Mar 4, 2019 at 6:13 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
  3. Mar 4, 2019 at 6:38 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
  4. Mar 4, 2019 at 7:08 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    @SCSPerformance are hub centric to tundra ... Check them out a lot of guys run them on here and they look great. ... Scs rays 10
    geno0506 likes this.
  5. Mar 4, 2019 at 7:16 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’ve been running aftermarket wheels and offroad tires from day one. I’ve got 70k miles and I have never had steering wheel vibrations or shaking. Sounds like you may have bad tires or unbalanced tires. Hopefully you can find out what the problem is.
  6. Mar 5, 2019 at 7:27 PM
    Haymaker88
    Haymaker88 New Member
    TN
    2018 Tundra Limited Crewmax 4x4 QS
    3” lift, black wheels, 33” BFG KO2, Black letter overlay. Color match fender flares. Predator running boards.
    Amen brother. Put on some Moto Metal wheels and BFG KO2’s and have been through the works... ground force shows a tire is a potential issue. Was able to get BFG to give me a warranty credit and now considering Nitto Ridge Grappler as guy at tire store says he’s had good luck with them. I’m praying the new tires work better because the vibration in my back and passenger seat are making me hate my truck.
  7. Mar 5, 2019 at 7:28 PM
    geno0506
    geno0506 New Member
    Michael
    joonbug and Faht Nocker[QUOTED] like this.
  8. Mar 5, 2019 at 7:54 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    why hate the truck? i would be hating anything aftermarket that was installed before i took it out on the truck. i would put my stock wheels back on and start there. perhaps you have a bad wheel or bad wheel and tire combo. i would definitely undo every add on 1 at a time til the problem goes away.
    NewImprovedRon, gosolo and 1UPPER like this.
  9. Mar 5, 2019 at 7:57 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
  10. Mar 6, 2019 at 6:39 PM
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    Have had aftermarket rims on and zero issues...
    Haymaker88 likes this.
  11. Mar 6, 2019 at 7:42 PM
    Haymaker88
    TN
    You’re right, I love the truck but the experience with this issue has hampered my new vehicle experience. Everything was installed by Toyota and they’ve failed to be able to help me so lots of frustration there. Tire store is helping and we are going to start replacing tires under warranty. Will be putting original tires and wheels on as well to confirm tire issue. I spend a lot of time on the road so the vibrating is getting on my nerves and like I said, Toyota has been no help.
    ardnutoz[QUOTED] likes this.
  12. Mar 6, 2019 at 7:51 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. Has absolutely nothing to do with the truck. It’s your crappy wheels, tires, or your tire shop can’t do a proper balancing.
  13. Mar 7, 2019 at 4:03 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    good choice going back to a known starting point and working from there.
    wheels and tires can be defective it's just nobody looks there first.
    I recently poop canned a brand new nose tire for an out of round condition and a brand new main gear tire for a egg shaped bulge in the sidewall. that's over 1k dollars in 2 aircraft tires that never made it to the hangar floor much less a runway. the tires were warrantied and new installed. unfortunately tire shops dont do thorough inspections of what they received and installed. quick production and smoke breaks tend to be the norm.
    it happens... it just sucks when it happens to us. good luck and let us know what you discover along the way.
  14. Mar 7, 2019 at 4:10 AM
    TundraDude4x4
    TundraDude4x4 New Member
    2010 Pyrite Mica V8 4x4 DC
    I’m gonna be buying the Ridge Grapplers fairly soon as well
    Haymaker88[QUOTED] likes this.
  15. Mar 7, 2019 at 4:45 AM
    timsp8
    NY
    I just got the same wheels - XD 128, and have nitto ridge grapplers. So far after a few hundred miles it’s good. No vibrations or anything.
  16. Mar 7, 2019 at 8:14 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    No problems here...
  17. Mar 7, 2019 at 8:46 PM
    kralc8954
    ‘19 CrewMax SR5 4x4
    Maybe I just got a bad balance job done. I guess I could try one more road force at a different shop.
  18. Mar 7, 2019 at 8:51 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I’ve dealt with this too on my 4Runner. Hub-centric wheels are the only solution unless you know a machinist who can make you some stainless steel spacer rings. The nylon/plastic just don’t work.
  19. Mar 7, 2019 at 10:21 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Google “Chevy shake” and feel better about yourself.
    Newm likes this.
  20. Mar 8, 2019 at 6:39 AM
    niscur38
    niscur38 New Member
    Only thing I hate is the short ass wheel studs!
  21. Mar 8, 2019 at 11:18 AM
    kralc8954
    ‘19 CrewMax SR5 4x4
    Mine are hub centric.
  22. Mar 12, 2019 at 11:44 AM
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    When these types of issues happen, it's generally the tires especially when you're dealing with heavy AT and MT tires. They just take more effort to balance from what I've noticed. If the wheel is ever in question, have the tech dismount the tire and spin balance the wheel along on the machine. An out of round wheel will show itself right away. If the wheel looks true and straight then it falls back on the tires being bad. Even straight from the factory it can be bad right off the bat.
    The centerbore of the wheel should be 110.1mm to be considered hubcentric.
    15whtrd and Erichudgins like this.
  23. Mar 12, 2019 at 12:23 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    18 inch fuel wheels and 275/70/18 Nitto Ridge Grapplers on the truck now for almost 17k miles....zero issues and zero wheel shake/vibrations. I'd agree with others that you either possibly have a bad wheel/tire.
