joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Feb 24, 2019 at 10:29 PM
    #1381
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Like this. This is my friend’s torch.
  2. Feb 25, 2019 at 2:56 AM
    #1382
    That is definitely not @ARamirez73 .
    Rica25 likes this.
  3. Feb 25, 2019 at 8:00 AM
    #1383
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you tighten the ring attached to the skid before or after you put it on?
  4. Feb 25, 2019 at 9:28 AM
    #1384
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    yup. Literally tried every combo of install order before finally just manhandling it
  5. Feb 25, 2019 at 9:57 AM
    #1385
    n2deep
    n2deep Pavement Princess
    Damn yall need to drive better - those are some beat up Cam Tabs. I only had one side bent a little on the drivers. Or maybe I need to drive harder. LOL
  6. Feb 25, 2019 at 10:02 AM
    #1386
    n2deep
    Is the mount cracked also?
    831Tun and joonbug[OP] like this.
  7. Feb 25, 2019 at 10:07 AM
    #1387
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It's our damn terrain up here in Norcal. We're constantly sitting on boulders. I got a lot of that damage on one trail. Niagara Rim. It was pretty rough and I didn't have anyone spotting me up front. It took us 3-4 hours to go the first 1/4 mile. It was ridiculous... I can't wait to go back there.
    Black Wolf, BestGen, Sunnier and 4 others like this.
  8. Feb 25, 2019 at 10:10 AM
    #1388
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    No, it wasn't cracked, I cut that line there to try to pull it out. I welded it back together, I hope it holds.
    Inquiringone and 831Tun like this.
  9. Feb 25, 2019 at 10:48 AM
    #1389
    Sunnier
    Sunny
    San Diego, CA
    :p
  10. Feb 25, 2019 at 1:32 PM
    #1390
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Look the rose bud tip:rofl:
    joonbug[QUOTED][OP] likes this.
  11. Feb 25, 2019 at 1:41 PM
    #1391
    n2deep
    You're supposed to drive over the boulders not drag yourself over them.
  12. Feb 25, 2019 at 2:42 PM
    #1392
    geno0506
    geno0506 New Member
    Michael
    fantastic work, Joon! :cheers:
  13. Mar 4, 2019 at 8:51 AM
    #1393
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    3-19
    Camburg Billet UCAs installed. Had to drill a couple new holes to relocate the resi mounts as the new arms are way beefier. Put it on the rack and caster was way too high and couldn’t get the toe in spec. So had to remove it again and take in the heims a bit and got a 2nd alignment. Finally got some decent caster... I’m in the 5’s now and can go even higher. Alignment also straightened my steering wheel which was pointing to 10 o’clock ever since hitting a big rock in Death Valley.
    But now I’m rubbing the cab mount in reverse so it’s finally time to do a CMC. The welder is still set up in the garage so I’ll try to tackle that next weekend before our trip in a couple of weeks.
  14. Mar 4, 2019 at 11:16 AM
    #1394
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    why the camburgs over the icons? just curious?
    joonbug[QUOTED][OP] and Sunnier like this.
  15. Mar 4, 2019 at 11:24 AM
    #1395
    Sunnier
    Sunny
    San Diego, CA
    Or... why Camburgs over Total Chaos, which have heims...?
  16. Mar 4, 2019 at 11:39 AM
    #1396
    Erichudgins
    Eric
    Murfreesboro, TN
    well the icons actually have a sealed delta joint. but the perk of the icons is you can actually make all adjustments on the truck vs. removing the uca bolt every time. Hes got icon suspension, just curious as to why camburg over the icon?
  17. Mar 4, 2019 at 11:46 AM
    #1397
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It's a shame because I really like the delta joints. Just wasn't pulling enough camber nor caster with the Icons. Total Chaos doesn't have enough room for the resi hose on the 3.0's without swapping the driver and passenger side coilovers. And even then, the hose makes contact with the springs. Icon billets would've been my top choice, but my buddy @TRD15559 sold these to me at a price I couldn't refuse. Pulling the arms to adjust is a pain in the ass but luckily it only has to be done once. I'm actually very happy with these, I can already feel less jolting on small bumps.
    smslavin, 831Tun, Watt maker and 6 others like this.
  18. Mar 4, 2019 at 11:49 AM
    #1398
    Erichudgins
    Eric
    Murfreesboro, TN
    yea sorry I didn't specify the billet icons lol.. that's what I meant. and yea you cant beat a good deal. especially as hands on as you are,thats a pretty easy in and out process for you. good deal I was just curious but that makes perfect sense. and yea ive heard a lot about the caster on the tubulars... glad I didn't go that route. looks nice tho man! good find.
  19. Mar 9, 2019 at 4:29 PM
    #1399
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Can someone please stop me from starting jobs I don’t want to finish??
  20. Mar 9, 2019 at 4:32 PM
    #1400
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Throw a strip of duct tape over it. Done!
  21. Mar 9, 2019 at 5:29 PM
    #1401
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I contemplated leaving it like that until after the trip. Then I downed two energy drinks. :goingcrazy:
    Got one side done.
  22. Mar 9, 2019 at 5:33 PM
    #1402
    GodlessPro
    Matthew
    NorCal
    I need to come over and learn how to weld.
    With the threat of mud you wouldn't have wanted to leave it open.
    831Tun, Inquiringone, Sunnier and 2 others like this.
  23. Mar 9, 2019 at 5:33 PM
    #1403
    TheBeast
    TheBeast The Beach
    damn all that time and adventures and you didn't have the CMC done ? :eek2::D
  24. Mar 9, 2019 at 6:17 PM
    #1404
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It never rubbed before. :notsure: Wasn’t even close. The UCAs and the last alignment really moved my wheel back a lot. It’s still really close with the CMC. I’m going to redo my alignment before I chop the other side. If I can’t move the wheel forward, I think I need more aggressive plates.
  25. Mar 9, 2019 at 6:20 PM
    #1405
    TheBeast
    TheBeast The Beach
    :spy::spy:
  26. Mar 9, 2019 at 7:30 PM
    #1406
    n2deep
    Haha. 8 yrs and I haven't plated mine. Maybe someday
  27. Mar 9, 2019 at 7:39 PM
    #1407
    Inquiringone
    Ter
    NorCal 408
    Joon,
    Bring it over I have all the tools to complete...
    831Tun and joonbug[QUOTED][OP] like this.
  28. Mar 10, 2019 at 4:11 PM
    #1408
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    3-19
    Installed @Victory4x4 LCA skids. Really like these and they literally took 10 minutes to install. Came powdercoated too. I didn’t really get these to protect the LCAs, I got them to protect the cam tab mounts.
    The front cam tabs are completely shielded.
    And on the rear, the skid is just a bit lower than the mounts that I should just slide off rocks and avoid touching the mounts. These are perfect.
  29. Mar 10, 2019 at 4:17 PM
    #1409
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    3-19
    @Vizsla Fire Extinguisher Mount
    I really kicked myself for missing the chance to buy this when I had the chance. Well, @dcsleeper408 gave me his. Very well made and now that I know David, it’s pretty cool having something he created in my truck.
    Cemented, Black Wolf, 831Tun and 8 others like this.
  30. Mar 10, 2019 at 4:19 PM
    #1410
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    And my buddy Shane @SIXSEVENONE swung by today to give me a lifetime supply of propane. And hung out as I prepared the truck for Mojave. Thanks Shane.
