Can I use cruise control while towing?
Discussion in 'Towing & Hauling' started by Hybrid trailer camper, Jan 23, 2019.
  1. Jan 23, 2019 at 3:29 PM
    Hybrid trailer camper [OP] New Member
    SCOTT
    2016 tundra 5.7
    Nothing yet
    Just got a 2016 5.7 tundra crew cab (I think that is it) my trailer is about 5000lbs loaded and my question is one in tow haul mode can I use cruise control and if yes I would only use it when its on the flats for a long distance, would that be safe? Any thoughts most of all people that have done it or why I should not think about it.
  2. Jan 23, 2019 at 4:14 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    It's not recommend but I do on a flat road on a calm day. Just be on your toes
    Booradly likes this.
  3. Jan 23, 2019 at 4:37 PM
    SCOTT
    2016 tundra 5.7
    Nothing yet
  4. Jan 23, 2019 at 4:52 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I do it all the time, But I'm only pulling 3000 max.
    edit, It lives in 4th while towing..
    Adriver71x likes this.
  5. Jan 25, 2019 at 8:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Cruise control makes the trans hunt for gears more frequently i feel. I wonder if you leave it in 5th gear maybe cruise control is fine to use?
    I use CC all the time with my little cargo trailer, but a camper I’m not sure
  6. Jan 25, 2019 at 8:52 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Is it a safety issue or mechanical?
  7. Jan 25, 2019 at 8:55 AM
    15whtrd
    15whtrd Mr. Blonde
    I’d say a little bit of both. I figure it’s OK to use on the flats if you’re in the right gear and it’s not shifting all over the place. I personally don’t like as I like to feel connected when I’m hauling something.
    NewImprovedRon likes this.
  8. Jan 25, 2019 at 8:57 AM
    Jrharvey02
    Jrharvey02 New Member
    And it looks like you’ve got a double cab (dc)...not crew
  9. Jan 25, 2019 at 9:02 AM
    SCOTT
    2016 tundra 5.7
    Nothing yet
    Jrharvey02, yes I have a double cab, would that make a difference?
  10. Jan 25, 2019 at 9:09 AM
    Jrharvey02
    Not really in the context of your question, probably a lower GVWR rating as they are lighter. I use cruise control but only on the flats....
  11. Feb 28, 2019 at 2:01 AM
    bryan 4x4 tundra
    bryan 4x4 tundra New Member
    bryan
    2001tundra4x4 4.7
    FIRST GEN 01 TUNDRA WITH 4.7 PULLIN A BASS BOAT DOUBLE AXLE TRL IN THE TENN RIVER AREA HILLS AND HOLLERS . TOW HAUL OVERDRIVE OFF AND NO CC TRUCK HAS ENOUGH BUTT TO PULL IT AND THE 4WD COMES IN HANDY IF N YA NEED IT STEEP RAMPS THANKS :cool::benchpress::cool:
  12. Feb 28, 2019 at 2:11 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Short answer: no
  13. Feb 28, 2019 at 4:45 AM
    Ericsopa
    Ericsopa Old man and the sea
    Another short answer: maybe.
  14. Feb 28, 2019 at 5:00 AM
    Professional Hand Model
    Fred
    Hand Protectors
    1st Gen 2002 V8 4wd
    Towing with CC the truck starts hunting for gears and can’t find a steady place of where it wants to be.
    Without CC: She stays in OD pretty good while towing, unless there is a strong headwind or hills.
    Conclusion: No towing with CC.
  15. Feb 28, 2019 at 5:05 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gen 1 doesn’t have as strong of an overdrive gear. Supposed to tow in drive i believe
  16. Feb 28, 2019 at 5:41 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Yes, you can. But, I would do it on flat wide open areas and if you feel the tranny shifting a lot I would stop. I ran through SD with my boat on back for stretches and it was fine. I just used common sense and paid attention.
    15whtrd and Casper3 like this.
  17. Mar 1, 2019 at 9:12 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    I use it while towing my bass boat on more level areas. Going up mountains the cruise will kick off. So the answer is yes and no.
  18. Mar 2, 2019 at 9:55 AM
    SCOTT
    2016 tundra 5.7
    Nothing yet
    Thanks again for all your opinions and thoughts, I had a jeep once and although it did not have CC it had over drive and I learned the hard way don't tow in OD, but I learned that after replacing my Transmission, don't want to have to do that again. Again I was thinking only on the flats like in the middle of CA on the 5 or 99 hwy and only in dry and no wind conditions. For those that don't know in CA if you are towing you are to stay at 55 mph but you can move up to 60 once in a while but stay to the right. I try to do that!
