3 month old truck won’t start
Discussion in 'General Tundra Discussion' started by bmcdds, Dec 16, 2018.
  1. Dec 16, 2018 at 8:03 PM
    bmcdds
    bmcdds [OP] New Member
    CA
    2019 Barcelona Platinum
    I have 3380 miles on my 2019 Platinum. Over the last few days, it’s struggled to start and the battery light comes on. I’ve done no electrical upgrades/changes. Battery tests at 12V with everything off and 14V when the engine is running. Sounds like a classic dead battery. Plugged a charger on it on 2 amp and 6 amp and both times it said the battery was fully charged.
    I’m going to call the dealership in the AM for an appointment, but I’m wondering what could be the problem?
  2. Dec 16, 2018 at 8:16 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    Bad battery cell bro. Same thing happened to me after only a year. Battery replaced under warranty.
    OR18TRD and bmcdds[OP] like this.
  3. Dec 16, 2018 at 8:17 PM
    Warranty it then get a better one. Toyota batteries are junk.
    Patriot, xma, geno0506 and 4 others like this.
  4. Dec 16, 2018 at 8:18 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I've never had a good Toyota OEM battery on any vehicle. Even though it's free to replace under warranty you should consider buying an aftermarket AGM battery instead.
    xma, Rica25 and bmcdds[OP] like this.
  5. Dec 16, 2018 at 8:18 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    X2!
  6. Dec 16, 2018 at 8:20 PM
    bmcdds
    CA
    Thanks for the fast replies, guys.
    MotoTundra likes this.
  7. Dec 16, 2018 at 8:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    My battery was fine but after reading a bit about them going without warning I picked up an Interstate for the piece of mind.
    T-Rex266 and geno0506 like this.
  8. Dec 16, 2018 at 8:33 PM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    Check your ground from the battery to the frame. Tight and no corrosion.
    Probably is still a bad battery, but it still happens often.
    Slayer and bmcdds[OP] like this.
  9. Dec 16, 2018 at 8:35 PM
    bmcdds
    CA
    Thanks. I did check the ground. There’s no corrosion. Truck was built 1st week of September.
    Rica25 likes this.
  10. Feb 27, 2019 at 3:35 PM
    Etf007
    Etf007 New Member
    When I bought my 2016 sequoia the battery lasted couple months. I couldn’t let the truck sit more than two days without starting it. They replaced the battery with a stronger one and has been working fine these late couple years.
