Why the obsession with 35's?
Discussion in 'Wheels & Tires' started by tundracap, Feb 21, 2019.
  1. Feb 21, 2019 at 8:14 PM
    tundracap
    tundracap [OP] New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    I get it for some uses, but the down sides have been noted here in a number of threads.
    So why the 35 obsession?
    Asking for a friend.
  2. Feb 21, 2019 at 8:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I couldn't tell ya
    SWIPE and TXRailRoadBandit73 like this.
  3. Feb 21, 2019 at 8:18 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Proportionate to the big truck in my opinion. Just depends on what youre willing to sacrafice for looks.
  4. Feb 21, 2019 at 8:20 PM
    Rica25
    Ricardo
    Tulare
    Looks is so bad ass
  5. Feb 21, 2019 at 8:21 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Because it is the size of tire that starts to look like a bigger class of tire. You can tell from across the street when a truck has 35x12s
  6. Feb 21, 2019 at 8:25 PM
    I wouldn't know either. I like 40's.....
    Now to answer your question:
    -Clearance and off-road performance. Looks pretty killer as well.
  7. Feb 21, 2019 at 8:26 PM
    HappyGilmore
    Trent
    Lakewood CA
    OP, I assume youre asking about 35 inch tire specifically since thats the size you wrote. Are you against oversize tires all together, or do you have a preferred size you think is best?
  8. Feb 21, 2019 at 8:33 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Pffft... 37s are the new 35s. :anonymous:
  9. Feb 21, 2019 at 8:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is true.
    I remember when 33x12.5 on 15x10 wheels was cool.
  10. Feb 21, 2019 at 8:40 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I like little tires to compensate for my huge...
    ...ego.:D
  11. Feb 21, 2019 at 8:46 PM
    tundracap
    NC
    No, nothing against 35's or larger tires at all. It really depends on your individual use case. Mainly a curiosity.
    That, and thinking about what I will do when I have to replace the factory install tires when the time comes.
  12. Feb 21, 2019 at 8:48 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    95% are mall crawlers. It’s because it looks cool. To do it right requires a lift, gears, wheels and tires.
  13. Feb 21, 2019 at 9:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The reason everyone has 35’s is because that’s what fits with very little work. If 37’s fit that easy, everyone would have 37’s.
    eccracer104, NHPig, don3032 and 21 others like this.
  14. Feb 21, 2019 at 9:19 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    I could definitely be fine and probably better off with small tires but I cant stand the look of the stock size tires, it just doesn't look right.
    Homar23, stewtopia, Boerseun and 3 others like this.
  15. Feb 21, 2019 at 9:19 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    The bigger tire the better when ur off-roading But if u drive s street queen that doesn’t like to get scratched u go 20” rims on 35 so it looks cool.
  16. Feb 21, 2019 at 9:21 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m going to go 33‘s
  17. Feb 21, 2019 at 9:24 PM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Because they can’t fit 37s?
  18. Feb 21, 2019 at 10:36 PM
    brettski7
    brettski7 New Member
    Brett
    Clearance, looks cool, minimal work to fit, and don’t need to regear.
    Rica25 and VoodooTRDPro like this.
  19. Feb 22, 2019 at 5:46 AM
    VoodooTRDPro
    VoodooTRDPro New Member
    2019 Tundra TRD Pro Voodoo Blue
  20. Feb 22, 2019 at 6:06 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    We need to justify our CMC’s
    :sawzall:
  21. Feb 22, 2019 at 6:08 AM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    OP, you should downsize and go with the smallest setup you can find. Maybe you'll start a new trend :anonymous:
  22. Feb 22, 2019 at 6:09 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    holy shit. unicorn sighting.
  23. Feb 22, 2019 at 6:10 AM
    Eclipsed & Floating
    Voluptuous Whitey
    :anonymous:
  24. Feb 22, 2019 at 6:25 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    35’s provide more ground clearance or any size bigger than stock, that is the only way to lift the diffs higher from the ground a “lift” kit won’t do that. Bigger tires put more pounds per square inch to the ground, increasing traction.
    Rica25 and equin like this.
  25. Feb 22, 2019 at 6:26 AM
    KevinK
    Tundras to Sedona
    Google Hawaiian truck style
  26. Feb 22, 2019 at 6:28 AM
    KevinK
    Tundras to Sedona
  27. Feb 22, 2019 at 6:29 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    35'S.............SHHH, why 37's! :cool: because anything else would be uncivilized....
    Eclipsed & Floating likes this.
  28. Feb 22, 2019 at 7:07 AM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    I had 33's on my 2012 Tundra, then on 2016 I have 35's and Im loving it. Kinda gives me a little "birds eye view" ahead.;)
    toyofan87 likes this.
  29. Feb 22, 2019 at 7:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Cause can't skip leg day.
  30. Feb 22, 2019 at 7:33 AM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Copy Cats, following others is the trend, What size fits blah blah etc.
    tttrdpro likes this.
