Front Camera (2018+)
Discussion in '2.5 Gen Tundras (2014-2021)' started by lbcdan, Feb 19, 2019.
  1. Feb 19, 2019 at 9:32 PM
    lbcdan
    lbcdan [OP] Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    I have been browsing the numerous threads regarding front camera installations (FRAC) and I cannot seem to find anybody who has installed a front camera on a 2018+ Tundra. Since 2018 is when they changed the emblem to a sensor, I cannot use the camera most have used.
    Any recommendations on cameras and mounting locations on a 2018+? I have a Pioneer headunit so interfacing to the radio is not a problem. Just need help with cameras and mounting location.
  2. Feb 19, 2019 at 9:41 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I originally mounted my front cam in the lower grille area, but didn't like how low it ended up being (red), so I fab'd an L bracket and used 3M tape to hang it below the TSS-P (green). I don't have a pic of the new mount, but I can get one in the morning if needed.
    Here's the camera I used:
    NOAUKA Waterproof IP68 Night Vision 170 Degree Car Rear View/Reversing/Reverse Camera Universal Color CMOS Imaging Chip Backup Parking HD Front View Camera https://www.amazon.com/dp/B06XNM7GNS/ref=cm_sw_r_cp_api_i_3HoBCbKJWSMNM
    BLONGTX and WAtundra4x4 like this.
  3. Feb 19, 2019 at 9:43 PM
    lbcdan
    Daniel
    Long Beach, CA
    Thanks for the reply. That looks really clean and low profile. The only problem is that I have a 30" light bar going there this weekend. I have been on the fence about mounting a license plate front camera since I am in CA and already have 2 screw holes in the front bumper.
  4. Feb 20, 2019 at 7:25 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    After you mount the 30" bar behind the grille, please post a pic or PM it to me. I'm on the fence about mounting one behind the honeycomb and contemplating getting an earlier SR5 grille / insert with the horizontal bars instead.
  5. Feb 20, 2019 at 7:52 AM
    lbcdan
    Daniel
    Long Beach, CA
    Sorry, i might have worded that poorly. I am mounting mine in the bumper. I am using Rough Countrys Tundra kit.
  6. Feb 20, 2019 at 4:00 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here's where I ended up mounting it. The viewing angle is better on the head unit than with it mounted on the lower grille.
    00h2itr, CementGen3, hooter and 6 others like this.
  7. Feb 20, 2019 at 7:47 PM
    lbcdan
    Daniel
    Long Beach, CA
    Oh dang. I like that a lot! I think that is how i am going to do it as well. Any tips or tricks on the install?
  8. Feb 20, 2019 at 8:14 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The third (and hopefully now final) time I redid it, I routed the cable wrapped in wireloom along the TSS wires, mounting the 4 pin plug for the camera with the TSS disconnect at the top of the grill. Same with the other end of the cable, just zip tied the loom along the large wire loom bundle in front of the radiator. For the mount, just make sure the L bracket fits in the indention of the honeycomb and use a spacer if you need it to fit the camera body over the lip. I didn't take pics as I was putting it together, but if I end up taking the grille off any time soon I'll snap one.
  9. Feb 20, 2019 at 9:26 PM
    Manventurer
    Manventurer New Member
    Josh
    Nashville, TN
    2019 Tundra Limited
    3”/1” lift, 18”x9” replica Pro wheels, 35x12.50r18 Ridge Grapplers, Tint, Chrome Delete.
    Do you all use the company “anytime backup camera” to hook these front cameras up or do you have a different company you use?
  10. Feb 20, 2019 at 9:44 PM
    lbcdan
    Daniel
    Long Beach, CA
    I believe what you are referring to is for stock head units. I have a pioneer so I should be able to interface directly with the Pioneer Headunit without an issue.
  11. Feb 20, 2019 at 9:44 PM
    Manventurer
    Josh
    Nashville, TN
    2019 Tundra Limited
    ahhh, got it
  12. Feb 20, 2019 at 9:55 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Did you interface with a stock head unit or do you have an aftermarket one?
  13. Feb 21, 2019 at 5:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Aftermarket. Was going to go the FRAC harness route, but decided to put that money towards a full replacement instead.
  14. Feb 21, 2019 at 7:22 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    How's the quality of view you get from the front camera, same as what we see from the back-up cam? I've got a 2019 and agree this is something that's badly needed.
  15. Feb 21, 2019 at 7:26 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Very nice. Can you snap a pic of the view on the head unit?
  16. Feb 21, 2019 at 7:28 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I believe @azTony has a front camera on an 18 honeycomb grill also
    I haven't found a good place on the limited/1794 grill due to how thin the slats are
  17. Feb 21, 2019 at 9:46 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here you go:
    View from windshield for reference:
    Sleeper16plat, Sas and Cement[QUOTED] like this.
  18. Feb 21, 2019 at 9:47 AM
    Cement
    Cement ...
    Sweet thanks!
  19. Jul 30, 2019 at 6:29 PM
    Sbrakeville
    Sbrakeville Go Hawkeyes
    Scott
    Plano,TX
    2018 Tundra TRD sport
    How did you secure the L bracket to the grill? Did you have to glue it?
  20. Jul 30, 2019 at 7:15 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I used some 3M tape. Seems to be holding for now, but gets a little soft when it heats up, especially in 115 degree heat right now... I need to come up with a better solution soon.
  21. Jul 30, 2019 at 10:35 PM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    Thanks For all the info. I'll soon add camera also. My question is about your pioneer. Do you like it compared to the oem and did you retain all the stock functions or if not, what did you lose. I have the taco tunes system and sounds great, but I know the head unit is our weak part of this truck. So im thinking of changing out the unit but dint know which one to buy
  22. Jul 31, 2019 at 4:13 AM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    I just installed a new Kenwood unit. Works with their dashcam and I installed a front cam in the grill too.
    https://www.tundras.com/threads/wir...-sr-loooooooooooooong-bed.49622/#post-1306217
    Boots[QUOTED] likes this.
  23. Oct 4, 2019 at 3:42 PM
    Samurai
    Samurai 2018 tundra crew max sr5
    Very nice. Can you snap a pic of the Back grill ?
  24. Oct 4, 2019 at 4:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  25. Oct 4, 2019 at 5:18 PM
    Samurai
    Thanks for all the info
  26. Apr 18, 2021 at 10:41 AM
    beanders
    beanders New Member
    I was able to get a picture of the back of the grill via screen grab watching someone on YouTube. I have mine mounted using a Screen Door Panel Clip from ACE Hardware. I had to cut the end off with a hacksaw (pink scribble on the picture), but it grabs the grille from behind real well. I was also able to install it without removing my grille, as my arms are skinny. I popped the square access panel off on the top right side of the grille. A couple M8 1.25 nuts (one with a flange to make it thicker and one without), a screen door clip and a drill bit to make the slot on the screen door clip just a little wider.
    Soundguy12 likes this.
  27. Apr 18, 2021 at 11:02 AM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    What camera did you use for this?
  28. Apr 18, 2021 at 3:44 PM
    beanders
    beanders New Member
  29. Mar 6, 2025 at 6:12 PM
    Mosey
    Mosey New Member
    2018 Tundra Crewmax
    Natika camera, Mounted horizontally rather than vertically. Drilled a single 5/16 inch hole, filed down the plastic lip on the back side of the grill, and tightened the restraining nut. Snipped the appropriate wires per the directions for the correct view on the Head Unit. Wiring harness is run on the drivers side around the battery and fuse box and through the rubber grommet in the firewall on that side. Power is drawn from an 'Add-A-Tap' on the DRL fuse in the box under the hood.
