135k Maintenance
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Acrotalus, Feb 18, 2019.
  1. Feb 18, 2019 at 12:43 PM
    Acrotalus
    Acrotalus [OP] New Member
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    Hey guys, I’m hit or miss on getting traction in the forums but I was curious as to what you all would recommend for servicing and maintenance.
    I bought the truck, 2016 TRD Pro, in March with 69k miles on it and today it has 135,365 miles.
    My driving consists of long highway stretches to bumpy, rutted our lease roads in the oilfield. Very little stop-and-go city driving. I’m either going 75 on pavement or 25 off.
    I intend on building this rig into a beast and want to make sure before I invest in more upgrades (Lift, Gears, etc.) I take care of the primary things.
    Since I’ve had it, I’ve only got routine oil changes every 5k, tire rotations and one alignment. I haven’t had a need for anything other than that.
    One thing I do know I am going to get done is a front end inspection. Any other suggestions?
  2. Feb 18, 2019 at 12:50 PM
    marlin39a
    marlin39a I’m a dumbass.
    Spark plus, and serpentine belt. I would be doing frequent air filter changes out there.
    Watt maker likes this.
  3. Feb 18, 2019 at 12:51 PM
    TheBeast
    TheBeast The Beach
    maybe spark plugs with that many miles. how are the brakes and transmission flush maybe
  4. Feb 18, 2019 at 12:53 PM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    I just had my rear diff fluid change last 50K miles done in the dealer. My rear break pads is the next. I always have my tire rotated every 5K and of course oil change.
  5. Feb 18, 2019 at 1:04 PM
    Acrotalus
    Brakes are good, just squeaky at times which I attribute to all the moon dust out here.
    Transmission flush is something I considered but someone told me “at this point it would do more harm than good”.. which not sure what that meant
  6. Feb 18, 2019 at 1:05 PM
    Acrotalus
    I do air filter changes @ oil change , forgot to mention that
  7. Feb 18, 2019 at 1:11 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    I just changed the spark plugs in a guys 2014 Tundra 5.7L with 150k miles yesterday and I was surprised how good they looked for the mileage. You could see the carbon building up on the grounds of the plugs 2hixh could eventually cause the truck to run leaner due to not getting optimal spark but they looked good. Replaced them with Bosch iridium plugs.
  8. Feb 18, 2019 at 1:29 PM
    Acrotalus
    Awesome, I’ll definitely swap plugs man. Appreciate the post.
  9. Feb 19, 2019 at 4:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Highway miles are easier on an engine so your 5k oil change interval is good.
    Reccos:
    1) Turkey baste refresh your PS, and brake fluids at regular intervals. Easy DIY.
    2) Drain and fill your transmision fluid. Easy as doing oil change.
    3) As others mention, drain and fill all your diffs and transfer case.
    4) Keep your airfilter clean/changed.
    5) New Plugs.
  10. Feb 20, 2019 at 1:21 PM
    farmer307
    farmer307 New Member
    Leo
    2017 white Toyota Tundra SR5 4x4 crewmax
    Front/rear replacement ranch hand bumpers. Custom hand crafted headache rack with bed rails
    I’d like to know what wheels you have? They are sick!
  11. Feb 20, 2019 at 1:41 PM
    Acrotalus
    Black rhino Arsenal’s
    18x9.5
    farmer307[QUOTED] likes this.
  12. Feb 21, 2019 at 8:12 AM
    2015TundraCrewXP
    2015TundraCrewXP New Member
    Charles
    SC
    2015 Black Tundra Crew Max XP
    20" blacks wheels, trd pro grille, color matched fender flares and handles, steel rear bumper, black leather, bakflip cover, spyder led headlights
    Wheelsa are great looking
  13. Feb 21, 2019 at 9:51 AM
    farmer307
    Leo
    I appreciate it want to replace my 20in factory rims with something different. What tires are those also? AT?
  14. Mar 8, 2019 at 2:26 PM
    farmer307
    Leo
    Well after doing some research and waiting forever finally did a thing to my truck
    20 black rhino armory wheels
    AC032A1C-83FB-4153-827C-933A467F5C9F.jpg D6A35C94-4F0F-405E-A275-21A44A21C706.jpg F0CDA014-72E1-4E72-8488-3101E95DB9D5.jpg ADC504DA-C1C2-4A76-9A68-B31C376315D1.jpg 4CB80BF8-D85B-445D-9CCF-E9A1EF7543E8.jpg 106DB564-26F5-4DF0-A4A8-BFE76CC94F80.jpg
  15. Jun 11, 2019 at 9:23 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Those look purty beefy :muscleflexing: did they kill you gas mpg bad?
  16. Jun 11, 2019 at 10:03 PM
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    I have 137,000 and flushed my transmission fluid along with reg. Oil changes but, one day about 2 months ago one of my back brakes started grinding without warning so I had to replace them in a hurry. It left gold dust stuck on one of my rims and its been a pain to get off. I probably should change the spark plugs as well. But, it runs and idles great.
  17. Jun 11, 2019 at 10:14 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  18. Jun 12, 2019 at 3:30 AM
    farmer307
    Leo
    No not really I’m still getting 9-10 in the city and about 12-14 on the highway
    Big J[QUOTED] likes this.
  19. Jun 23, 2019 at 2:51 PM
    915tundra
    915tundra New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
    I really like your Pro, very tough looking! Can you please post a couple of pics from different angles to see your bumpers? I'm wanting to upgrade to the fab fours premium rear, and fr the front full grille guard model you have. love the protection it offers.
