Bed Rust
Discussion in '1st Gen Tundras (2000-2006)' started by Jrobinson42, Feb 12, 2019.
  1. Feb 12, 2019 at 9:27 AM
    Jrobinson42
    Jrobinson42 [OP] New Member
    Jarrod
    2006 Tundra
    Has anyone had issues with their bed rusting/bubbling? I have a 2006 and the rust is in line with the bed bracing.
    Mnorris1206 likes this.
  2. Feb 12, 2019 at 3:58 PM
    bmf4069 Captain wtf
    Is it coming up from underneath?
  3. Feb 12, 2019 at 4:04 PM
    Mnorris1206
    08 tundra
    Yep on my 08 .dealing with it now .
  4. Feb 12, 2019 at 4:19 PM
    Jrobinson42
    Jarrod
    2006 Tundra
    Mine isn’t that bad yet. But yes @bmf4069 its blistering up and flaking away the paint away. The way it looks it’s coming from around the bed support because they are spaced out like the bed support should be.
  5. Feb 12, 2019 at 4:22 PM
    Mnorris1206
    08 tundra
    That was after grinding it down. This was before grinding on it .
    NUDRAT and Black Wolf like this.
  6. Feb 12, 2019 at 4:48 PM
    bmf4069 Captain wtf
    I would take a look underneath at your frame. It may be coming from there.
    Black Wolf and NewImprovedRon like this.
  7. Feb 12, 2019 at 5:00 PM
    Yep....^^^^
  8. Feb 12, 2019 at 5:09 PM
    Jrobinson42
    Jarrod
    2006 Tundra
    Didn’t Toyota have a recall on their frames or was it only for Tacoma’s?
  9. Feb 12, 2019 at 5:14 PM
    Jrobinson42
    Jarrod
    2006 Tundra
  10. Feb 12, 2019 at 5:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    White paint is more severely effected. The metallic colors have more coats, plus a very nice primer base.
    Get some Ospho to neutralize the rust. If its bad, cut it out and weld or flex adhesive a new piece in place.
  11. Feb 12, 2019 at 5:25 PM
    Mnorris1206
    08 tundra
    Hate to tell you this but that is defiantly worse under the paint. you could try to save it but like my body guy said better off not to chance it .Cut it out and put new. He also said to remove the bed and put upside down and sand blast the hole underside then coat it. Then get line-x in the bed after. Mine is defiantly from the bed rails .Water gets in between And gets traped their.
  12. Feb 12, 2019 at 5:31 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I have actual rust holes in the bed of my 00. it happens.
  13. Feb 12, 2019 at 5:40 PM
    Jrobinson42
    Jarrod
    2006 Tundra
    @Mnorris1206 yeah I had a body shop look at it. He was going to cut the spots out and replace it then I planned on getting a spray on bed liner. I was hoping Toyota had a recall on that haha. It doesn’t help living in Illinois either.
  14. Feb 12, 2019 at 5:45 PM
    Mnorris1206
    08 tundra
    Indiana is horrible for salt on the roads a lot of buddies wont even drive their trucks in the winter any more. Sad part is I dont mine much at all. And still have thos issue .But save your receipts is what I have been told they may someday have a recall and of they do they may give you a refund. Lol we will see how that goes .
  15. Feb 12, 2019 at 5:55 PM
    Jrobinson42
    Jarrod
    2006 Tundra
    Yeah that’s the bad thing is it’s my everyday vehicle lol. I will keep my receipts then and cross the fingers. I appreciate all the feedback fellas!
