Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Dec 30, 2018 at 6:54 AM
    #121
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    @Kirkulese your truck looks great! Thanks for your recommendation
  2. Dec 30, 2018 at 7:00 AM
    #122
    Kirkulese
    Kirkulese New Member
    Kirk
    2019 sr5 trd sport
    Thanks. Here is the one I used. I just bought it again to do my 19.
    jerzeedivr likes this.
  3. Jan 1, 2019 at 11:47 AM
    #123
    1goalkeeper
    1goalkeeper New Member
    2018 1794 Tundra CrewMax 4WD Smoked Mesquite
    1.75” Rough Country Leveling Kit, Goodyear Kevlar 285x60x20
    Just want to say thanks for this forum and this thread. It gave me the confidence to install a 1.75” Rough Country Leveling Kit and Goodyear Kevlar 285 60 R20’s.
    I’ll get you a before/after pic soon, but until then, here it is with the lift and new tires.
    KCBearFan, equin and KELZ84 like this.
  4. Jan 1, 2019 at 12:22 PM
    #124
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @1goalkeeper looks great? Do you feel the difference? How much did you end up paying?
  5. Jan 1, 2019 at 12:33 PM
    #125
    1goalkeeper
    I can feel a slight difference, but the ride feels good. I was worried about going from a P to a LT tire being more stiff/rough but it’s not really noticeable. I feel a bit taller on the road, and I definitely can’t see over the hood as well. I was also worried about the larger tires making it harder to park, but no issues and no rubbing.
    The kit was only $100 from Rough Country, but the installers had some trouble getting the holes lined up, had to shave the metal a bit and had to charge me for some extra labor to install. The Kevlar tires are expensive, but I’ve got mesquite at the ranch and crappy Houston roadways to deal with. I paid a little under $2000 for the kit, tires, install and alignment labor.
    KELZ84 likes this.
  6. Jan 1, 2019 at 12:39 PM
    #126
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @1goalkeeper not bad on price. I’m from the lower Texas region the valley. Trying to figure out where to get the install at. We have several places hopefully within next couple of months get that work done.
    1goalkeeper likes this.
  7. Jan 7, 2019 at 7:11 PM
    #127
    1goalkeeper
    Here are the before and after pics:365C5341-B3E4-4683-ABDD-3F045D14E043.jpg D89BA471-F922-4817-A3E6-E880F5E51586.jpgA7B4C4C9-664D-4F64-A41D-15282812E3C4.jpgED7996A8-42D5-4727-B762-AFDF559439D1.jpg
  8. Jan 12, 2019 at 2:53 PM
    #128
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @Kirkulese did you do a 1” on the back or just the 3” in the front?
    Kirkulese likes this.
  9. Jan 12, 2019 at 4:46 PM
    #129
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    That's the same leveling kit i had put on mine. So does that size tire rub anywhere? That's the size i want to go with.
  10. Jan 13, 2019 at 8:42 AM
    #130
    Kirkulese
    Kirk
    2019 sr5 trd sport
    I just did 3” in the front. Didn’t touch the back. Just did my 2019 as well. 20x9 with +20 offset. 35x12.5 trail grapplers
  11. Jan 13, 2019 at 11:35 AM
    #131
    1goalkeeper
    It had a little rubbing up front when turning the wheel in reverse, but the installer just pushed the front mudflap in with a screw
  12. Jan 13, 2019 at 3:50 PM
    #132
    NCTundra18
    Jeff
    Candler, NC
    Could you possibly take a picture of the front tire up close from the side? I'd like to see how much room you have.
  13. Jan 13, 2019 at 5:29 PM
    #133
    Kirkulese
    Kirk
    2019 sr5 trd sport
    @KELZ84 i just did 3” in the front.
  14. Jan 13, 2019 at 7:07 PM
    #134
    1goalkeeper
    0E6F24A9-8F0F-4B3A-8176-D1B2CD8F8C24.jpg E6E80A8E-59CB-4314-AE3F-746DA4E01F28.jpg 04221C2E-E8CE-4F67-8011-192DA984DEE4.jpg FC94ABD2-0D4C-45EC-923B-DB363C143AD5.jpg 473C013C-81EF-4267-8C8E-35F30F67C548.jpg 69FE6D15-6BE0-4188-A7C2-A97D9CF04A5A.jpg 523C39CD-A32E-42DA-9E7D-3D76B7CE69BC.jpg 253D73E6-95DE-4E37-B479-99009CEDC221.jpg 82CC8623-54BE-4826-B79A-530FF810CE87.jpg
  15. Jan 13, 2019 at 7:09 PM
    #135
    NCTundra18
    Jeff
    Candler, NC
    Thanks, looks good
  16. Jan 27, 2019 at 2:15 PM
    #136
    SNO BUS
    SNO BUS Professional Moneywaster
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    That's good and all but do you guys think a 285/60/20 would work? 1.6" taller and are 0.4" wider.
  17. Jan 27, 2019 at 3:25 PM
    #137
    1goalkeeper
    Scroll up and look at my posts - I did the 285 60 R20’s (with a 1.75” leveling kit on the front). I don’t think they would fit without the leveling kit.
  18. Jan 27, 2019 at 8:19 PM
    #138
    SNO BUS
    Washington
    Pardon my ignorance. Thanks for this. Do you think a 1" leveling kit would suffice?
  19. Jan 28, 2019 at 8:19 AM
    #139
    1goalkeeper
    I didn't do the install myself, but the tire shop who installed mine said they were rubbing even with the 1.75" leveling kit, and that they had to screw the mud flaps in a little tighter to prevent the rub. So I suspect a 1" lieveli g kit will have more rubbing
  20. Feb 9, 2019 at 9:11 AM
    #140
    Turk980
    Turk980 Freedom Isn't Free
    2019 Tundra Limited TRD Double cab
    Leveling kit, tires and wheels, fender flairs, nerf bar steps, flow master dual exhaust, spray in bed liner, rear airbags
    305/55/R20 B.F Goodrich All terrain on my 2019. 2.5" leveling kit, Dropstars wheels, 10', -19 offset Some trimming and some fender liner changed, no problems other wise
  21. Feb 22, 2019 at 6:17 AM
    #141
    chadinark
    chadinark New Member
    Sorry if this has been answered above but I looked pretty thoroughly and not seeing much about the other effects of changing tire sizes.
    Im wanting to go from 275 / 55/ 20 to 275 / 60 / 20 and while I have no concerns about the fit, I’m worried about it throwing off my shifting/ ratios etc because my trans is probably already on its last leg so I don’t want to do *anything* to upset it in any way... and those speedo recalibrators are like $200 so that’s not a great solution either.
    Thoughts? Is this slight difference enough to damage my trans if I don’t do a recalibration? I’m not concerned about the speedo or odo being a few miles off (I’m at 226k miles so that’s the least of my worries) but I am concerned about the trans getting incorrect info
  22. Feb 22, 2019 at 6:41 AM
    #142
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    why kind of recalibration are you talking about that affects the transmission? the speedometer recalibraters only affect what the speedometer shows and has nothing to do with the transmission. if your transmission is that bad, you will be better off fixing it than spending the money on a new set of tires :)
    however, your speedometer will be more accurate with 275/60/20's. I went from 275/55/20 to 295/55/20 and now my speedometer is dead-on. (verified with GPS).
  23. Feb 22, 2019 at 7:00 AM
    #143
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @Netmonkey so you have any photos of your truck with the tires? Did you have to remove any mud flaps ect?
  24. Feb 22, 2019 at 7:03 AM
    #144
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Please don’t listen to the guy telling you to run a $50 spacer lift in your $40,000 truck.
    zcarpenter92, ricsha and shellshock like this.
  25. Feb 22, 2019 at 7:05 AM
    #145
    Netmonkey
    Georgetown, TX
    I only had to remove the front spat. 295/55/20 on 20x9 +50mm offset.
  26. Feb 22, 2019 at 2:22 PM
    #146
    chadinark
    Pardon my ignorance but I thought the speedo somehow affected the trans shifting or something but I guess I’m way off base. So forget speedo but I know I’ve read where changing tires can definitely affect trans operation, no?
    It’s not that my trans is terrible it’s just that with over 200k on it I’m leery of doing anything that might have the slightest negative effect on it!
  27. Feb 22, 2019 at 3:07 PM
    #147
    Netmonkey
    Georgetown, TX
    yeah, the speedometer calibrators connect to the instrument cluster and change the reading of the speedometer only. they do nothing for the transmission. larger and heavier tires do take more power to turn and can affect your gearing, but it doesn't change the operation of the transmission. larger and heavier tires can put more strain on the driveline, but you are only talking about going to a 275/60/20, so it is not that bad. usually, if you stay under a 35 inch tire, you dont have to worry too much about the power loss and the strain on the driveline. its once you get into the 37 inch tires and above that people tend to regear.
  28. Feb 22, 2019 at 4:49 PM
    #148
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That doesn't make any sense.
    You run 10 cent valve stem caps on your $40,000 truck.
    Hammy68 likes this.
  29. Feb 22, 2019 at 5:28 PM
    #149
    Rubberdown
    Rubberdown Spilling my guts here.
    Every spacer lift is basically the same thing. I bought my first one used for 25 bucks off Craigslist and ran it for 100000 miles with no issues. What’s the problem.
    Silverghost, equin and Boerseun like this.
  30. Feb 22, 2019 at 7:47 PM
    #150
    chadinark
    Sir thank you so much! That’s good to know
    Netmonkey[QUOTED] likes this.
