Raptor lining in a can
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Jimes, Feb 6, 2019.
  1. Feb 6, 2019 at 5:25 PM
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    hell ya. Started using raptor lining in a can on some parts. Did my bushwhackers and now my rigid grill. No more stainless screws. Hopefully the tape on the lenses comes off easy. First coat only. Will post when on the truck. Also painted kb voodoo rack as well21D50567-74C7-4A30-9FD7-E844438EFCEC.jpg C474D605-6F5D-4553-80BF-0B235D45BD2B.jpgBB8D0364-13C5-45FE-8415-9E7BBD377D8D.jpg BA11CF81-4D3A-4380-8BCA-12A0D55033C2.jpg
  2. Feb 6, 2019 at 5:33 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Looks great! I had to look that up...never heard of raptor lining. Looks like a great protector
  3. Feb 6, 2019 at 5:42 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Nice! Never heard of the stuff. I'll have to check it out...
  4. Feb 6, 2019 at 5:48 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Looks great!
  5. Feb 6, 2019 at 5:54 PM
    Jimes
    Thank you. It’s an easy product to use. I always use the upol #4 after a quick sanding just to make sure it sticks. Two coats and you’re good. Cans are not cheap though and buy more than you need. I used 4 cans for all the flares(3 coats on each) and grill has two coats with one can. 6AF820E0-E108-40DD-8B7E-BFDB7A8E4C85.jpg
    Pudge, Hammerhead and NewImprovedRon like this.
  6. Feb 6, 2019 at 6:06 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Would it even stick to them without scuffing the surface?
  7. Feb 6, 2019 at 6:11 PM
    Very nice.
  8. Feb 6, 2019 at 6:11 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Looks great!
  9. Feb 6, 2019 at 6:14 PM
    blizz86
    blizz86 New Member
    It’s a 2k spray so definitely better than anything you’d likely buy at your local auto store. It’s a Bedliner so it’s going to be tough - I’ve dragged concrete blocks across mine with little to no damage
    NewImprovedRon and Jimes[OP] like this.
  10. Feb 6, 2019 at 6:40 PM
    Jimes
    I used this. Scuff up the chrome a bit and two coats with the grip 4 then do the raptor lining and I think you should be good. Just follow the directions with the timing and definitely the distance when spraying the liner. Says 2-3 ft away. They are not lying.
  11. Feb 6, 2019 at 6:45 PM
    Jimes
    The grip 4 is for hard to sand areas. So in theory I guess so, but since it’s permanent why not scuff it. Since it’s not cheap at $25 a can I would scuff if you can. You could always spray something else without scuffing and just using grip 4. If using on bare metal upol suggests using Acid 8 etch primer then line it. 3DE9D1E3-5F11-41B6-AB61-F0ABA8022FEB.jpg
  12. Feb 6, 2019 at 6:46 PM
    Jimes
    Oh ya. Wear a respirator. It’s brutal strong while spraying and will also smell for several days after. Don’t say I didn’t warn you.
    blizz86 and Hammerhead like this.
  13. Feb 6, 2019 at 6:52 PM
    Bascott1
    Bascott1 New Member
    2018 White TRD sport
    Stuff is super legit. Used it on my 86 4runner crawler and it's tough. I washed mine really well then used powder comet and a scotch brite pad to scuff it up a lil bit .Highly suggest it.
    NewImprovedRon and Mountun Goat like this.
  14. Feb 6, 2019 at 9:37 PM
    Quixxzone
    Quixxzone New Member
    2013 Toyota tundra
    Lots
    20190204_163201.jpg 20190205_143655.jpg 20190204_163506.jpg I did my whole truck using raptor liner20190205_143655.jpg 20190204_163506.jpg
  15. Feb 6, 2019 at 9:43 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Looks great! I’ll be coating my truck in quicksand raptor liner also! Just finishing our horse trailer first. Glad people are starting to know about it more!
  16. Feb 6, 2019 at 9:44 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Killer!
  17. Feb 6, 2019 at 9:55 PM
    TundraMash
    TundraMash New Member
    Tyler
    '17 Black Tundra SR5 4x4
    17 inch Icon Six Speed, BFG 285/75, ReadyLift 3/2 spacer lift, Bilstein 5100s in rear, Remote lock tailgate, leather wrapped steering wheel, driver side grab handle, LED headlights, LED interior lights, plastidipped dash components and grill, factory remote start, AJT climate knobs,
    That looks awesome, similar to Kevlar I would guess? Also, you have to have an airless sprayer or something right? You didn't rattle can that whole truck did you :eek2:
  18. Feb 7, 2019 at 2:24 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Nice work :thumbsup:
  19. Feb 7, 2019 at 3:03 AM
    Jach2008
    Jach2008 New Member
    New Tripoli
    2008 dove gray tundra
    Afe cold intake,bilstein shocks,raptor lined Paint job,led rear light bar,touch screen radio,kicker speakers on the dash and Rockford 6x9in the doors,mbrp exhaust,amp research power steps
    Looks great,prep is the most important did my entire truck
    Mountun Goat likes this.
  20. Feb 7, 2019 at 3:05 AM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Looks great.
  21. Feb 7, 2019 at 4:25 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    They offer kits with a schutz gun to spray it with, or you can reduce it and spray it with a HVLP paint gun with a 2.0 tip(if you want a smoother finish). I did my 20' flat bed trailer frame and toolbox with raptor liner, the included gun, and a 30 gal air compressor. I got a little nervous about spraying it, but it turned out great. Definetly wear a respirator and coveralls or old clothes that you don't care about. You can vary the texture quite a bit depending on spraying pressure, so test spray on a piece of cardboard first, to dial in the texture you want. Just remember, prep is the key.
  22. Feb 7, 2019 at 4:50 PM
    Jimes
    All done with the grill. Last thing is to blackout the screws on the RDS in the bumper, hard to see, but they’re stainless and tiny. my method rims have goldish colored bolts and everything else was stainless bolts. I actually like the gold bolts on the rims and everything else blacked out. F67180BB-6CBC-4AB2-BAE7-EC5DF43604B1.jpg 7E203D85-6CED-4C34-B394-DD60C3201446.jpg
    J&ATundra, Markman, Jach2008 and 2 others like this.
  23. Feb 7, 2019 at 4:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    Nice job!
  24. Feb 7, 2019 at 5:03 PM
    Jimes
    Thank you.
  25. Feb 7, 2019 at 5:11 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Holds up great...
  26. Feb 7, 2019 at 5:12 PM
    Jach2008
    Jach2008 New Member
    New Tripoli
    Love it thing is bad ass,did my truck to
    baldmanbigheart likes this.
  27. Feb 8, 2019 at 5:07 AM
    Welcome from NY.
    That is BA! :thumbsup:
  28. Feb 8, 2019 at 7:22 AM
    1BadTundra
    Clinton
    Too Much to List
    April will be a year... The caps were chrome, You need to really dig them up so the liner has something to bite into. I used 80 grit on a DA and really got into it. Then clean with soap n water. That's it, then sprayed them.
  29. Feb 8, 2019 at 7:26 AM
    1BadTundra
    Clinton
    Too Much to List
  30. Feb 9, 2019 at 7:07 AM
    Rtrott01
    Rtrott01 New Member
    2017 TRDP Cement
    Ok those flares look 1000x better with that new finish and no more chrome bolts. Can someone lead me to a resource for this stuff and the tools needed to apply it? Im guessing its a TON cheaper than having a shop
    line-x it. Thanks!
