  1. Feb 7, 2019 at 8:58 AM
    #3811
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not the same but I've had the Zerex Asian in mine for 2 years with no ill effects.
  2. Feb 7, 2019 at 9:04 AM
    #3812
    Good to know. Any idea how many gallons I should buy? Manual states total capacity is 12.3 qts. I can't imagine I'll get that much out with a drain and fill(after I replace radiator)..
  3. Feb 7, 2019 at 9:42 AM
    #3813
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I would get 2 Gallons just to be safe and have a spare up on the shelf, I would imagine you would get a little over a gallon out of the radiator.
  4. Feb 7, 2019 at 10:08 AM
    #3814
    Outbound
    Aaron
    Northern Alberta
    Retreat, reassess and re-engage is often a good strategy. Sun Tzu said: The general who advances without coveting fame and retreats without fearing disgrace is the jewel of the kingdom.
  5. Feb 7, 2019 at 10:23 AM
    #3815
    You guys are cracking me up.
    @Professional Hand Model , you better document this job well. We're not letting you off easy with just a few pictures. Sticky Status is your destiny. :cheers:
  6. Feb 7, 2019 at 10:28 AM
    #3816
    I picked up a can of white plasti dip today. I'm going to see how I like the entire strip white. If I did the entire thing black it would be too much. The chrome is too beat up to try and do "new" black over foggy chrome. I'll post a few pics this weekend. I'll be dipping the wheels black too.
    03tundra likes this.
  7. Feb 7, 2019 at 10:29 AM
    #3817
    Festerw
    Festerw New Member
    04 Tundra DC
    When my mechanic did the timing belt I bought 2 gallons of coolant and 2 gallons of distilled water. When all was finished I got a 1/2 gallon of pre-mixed back.
  8. Feb 7, 2019 at 10:37 AM
    #3818
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I bought a new flood jack and channel locks to install my front superbumps today
    Finito.
    If I had an impact I'd tackle the rear ones, but I'll hold off for now
    Debating on removing the front sway bar
  9. Feb 7, 2019 at 11:11 AM
    #3819
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Buying new tools is fun!! You may only use it once a year but if the tool saves ya hours of work, it is worth it. I left my sway bar off my truck after the LCA bushing replacement to see what it is like and so far it isn't too bad. The ride is less stiff, I am gonna run off road with it and see if it makes a big difference in articulation. If it dramatically improves the the ride I will leave it off. I mainly use my truck off road while hunting and fishing.
  10. Feb 7, 2019 at 11:14 AM
    #3820
    How easy are these to install? Do you have to remove anything to make room?
  11. Feb 7, 2019 at 11:20 AM
    #3821
    Casper421
    In the woods
    06 DC
    Have you talked with Brian about a front winch bumper by chance?
  12. Feb 7, 2019 at 11:50 AM
    #3822
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    Not yet, I only mentioned that I was interested in a rear bumper. I can talk to him and see what he thinks though.
    Casper421[QUOTED] likes this.
  13. Feb 7, 2019 at 12:05 PM
    #3823
    Casper421
    In the woods
    06 DC
    :thumbsup:
    He’s been killing it for the 2nd/3rd gens. I’d like to see more 1st gen love.
  14. Feb 7, 2019 at 12:36 PM
    #3824
    Fred
    Hand Protectors
    It takes a lot of fluid to flush and fill. Its a bigger job than it looks doing these flush n’ fills which is what you want done. Then you have to figure on having a large pan to catch it and then take it up to recycle.
  15. Feb 7, 2019 at 12:39 PM
    #3825
    trailbikerider
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    While I agree with you, the amount of buyers for 1st gen parts (especially us with double cabs that were only made for 3 years) is WAY less than 2nd and 3rd gen Tundras. To be honest I'm surprised they're even considering building any 1st gen stuff.
    Regardless, I sent him a message. We'll see what he says.
  16. Feb 7, 2019 at 12:41 PM
    #3826
    Fred
    Hand Protectors
    Prepare for top heaviness feeling going around corners. My sway links rusted off and the truck took corners like a grandpa. I was doing old man 3 point turns making a simple merge and turn right. Drove it like that for 2 years until the recent front end work. Drives much better with the links connected, unless you are offroading full time.
  17. Feb 7, 2019 at 12:55 PM
    #3827
    Fred
    Hand Protectors
    Sun came back out and shined on me while tackling the fuel injector that was ‘stuck’. Was able to disconnect it doing finger yoga with some el cheapo pliers. Have piece of mind now. Will tackle the pulsator thingy next.
    @bmf4069
    Does your pulsator look like this? To remove you unscrew the top screw and it releases the entire assembly? Or, is there another nut under that cap? The exploded Toy diagrams are not detailed enough.
    Anyone else familiar?
    Filthyphil, Darkness and Sunnier like this.
  18. Feb 7, 2019 at 1:37 PM
    #3828
    Fred
    Hand Protectors
    Figured out there is a nut under the pulsator. Looks to be 22mm. Tight getting leverage without removing all the hoses. Trying to minimize removal of so much stuff.
    hammeron and Darkness like this.
  19. Feb 7, 2019 at 2:04 PM
    #3829
    Valler
    Valler New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    Yes cheaper, but now i have to figure out whats making the steering wheel shake when im going between 60mph and 70mph, alreadyvjad it aligned this past weekend. Any idea of where i should start
  20. Feb 7, 2019 at 2:29 PM
    #3830
    Fred
    Hand Protectors
    Might be out of round tires. Had that problem years ago with Dunflops and Firestones until I switched to Michelins. Could also be a balance issue with tire weights.
    Sunnier likes this.
  21. Feb 7, 2019 at 2:37 PM
    #3831
    Fred
    Hand Protectors
    Tomorrows attack plan.
    Filthyphil, NUDRAT, mtntop and 2 others like this.
  22. Feb 7, 2019 at 2:48 PM
    #3832
    @Professional Hand Model only loosen the 22mm nut. The fuel line is in between the two washers and the pulsator sits on top. What are you about to do?
    Sunnier likes this.
  23. Feb 7, 2019 at 3:10 PM
    #3833
    Sunnier
    Sunny
    San Diego, CA
    I'm pretty sure it's @BestGen that swears by Aisin. I'll get it.
    Yeah, please save these pics and include them with others you take while in progress; this deserves a dedicated thread so the rest of us can find it. :thumbsup:
  24. Feb 7, 2019 at 3:12 PM
    #3834
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Kinda personal don't ya think?
    Filthyphil, the red, bmf4069 and 3 others like this.
  25. Feb 7, 2019 at 3:47 PM
    #3835
    Fred
    Hand Protectors
    Now that you ask, it sounds very personal!
    Darkness[QUOTED] likes this.
  26. Feb 7, 2019 at 3:54 PM
    #3836
    Fred
    Hand Protectors
    Removing the fuel rails to install some upgraded 12 hole fuel injectors. Does the pulsator completely come off and out of the top of fuel rail?
    Looks like it does and will make the job way simpler. Trying to keep it simple and not have to cut the fuel line feeding the pulsator.
  27. Feb 7, 2019 at 5:13 PM
    #3837
    Valler
    Valler New Member
    Ramon
    Thanks, ill just tell the tire shop Saturday to see of the can check the balance on them again
  28. Feb 7, 2019 at 5:44 PM
    #3838
    Yeah, it removes completely. If you're undoing all that, it's only 6 bolts and 4 nuts to pull the whole thing off. Well, and remove the TB and a few misc pieces.
  29. Feb 7, 2019 at 5:51 PM
    #3839
    Fred
    Hand Protectors
    I believe it can be done even with the throttle body intact. The banjo nuts (removal) on either side of the throttle body might make for a clean removal of the rail without removal of the TB.
    Researching the pulsator, the screw on top is an adjustment calibration screw that controls a diaphram which controls fuel pulse abnormalities. I’ll be leaving that alone for now.
  30. Feb 7, 2019 at 7:12 PM
    #3840
    trailbikerider
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    His answer: "Yeah, if we have time"
    So I guess we better hope I pick a good week to drop the truck off :cool:
    Sunnier likes this.
