  1. Feb 6, 2019 at 7:50 AM
    #3781
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I drove the truck this morning after the LCA bushing replacement with poly bushings from Daystar and it may be too soon to report; but the nagging wheel vibration between 60-70 has finally disappeared! I had the tires balanced and road forced balanced by multiple shops, the worn OEM bushings may have been the culprit all along???
  2. Feb 6, 2019 at 8:15 AM
    #3782
    Casper421
    In the woods
    06 DC
    My truck handles like a sports car after replacing every bushing in the front end. It’s actually kind of scary how little effort I have to put into steering bigger tires than before.
  3. Feb 6, 2019 at 9:18 AM
    #3783
    trailbikerider
    trailbikerider New Member
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    NUDRAT likes this.
  4. Feb 6, 2019 at 9:55 AM
    #3784
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Those look nice.
    But The main reason switching from my Discoverer ATPs is for a more aggressive tire
    Brown Bear likes this.
  5. Feb 6, 2019 at 2:18 PM
    #3785
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah buddy. Thats the feeling I got when they rebuilt the front on the 02’. Night and day. Went from grandpa to sports mode.
    NUDRAT and Casper421[QUOTED] like this.
  6. Feb 6, 2019 at 2:41 PM
    #3786
    Fred
    Hand Protectors
    Changed the Ol’ (oil) today. Round hea we call it Ol’. Getting to finally use my Toy Filters.
    Ol’ had 2,400 miles on it and the reason for changing was this article about switching to full synthetic for the first time. Basically, the synthetic oil cleans the gunk pretty well and clogs the filter with the debris. Mechanic says to change filter at 1,500 miles due to filter clog possibility.
    http://www.agcoauto.com/content/news/p2_articleid/122
    Did notice some seepage around the oil pan gasket (factory fipg) see lowest pic. Will keep eye on things and may switch back to Syn Blend if becomes problematic on this second syn oil change.
    Driver side top of oil pan view looking down from battery zone area. Yoga performed to take picture.
  7. Feb 6, 2019 at 4:06 PM
    #3787
    Coincidentally, I saw a guy yesterday complain about seepage from this same filter. Maybe it's a problem with the filter not the synthetic???
    I have the same filter on mine since the purge 10 days ago or so. I'll take a look this weekend.
  8. Feb 6, 2019 at 4:13 PM
    #3788
    Fred
    Hand Protectors
    The removed filter was a Mobil1 and was loose(er) than when installed a few months ago. Guess it loosened a bit? It had some seepage from being loose. Not much.
    The new Toy filter had some seepage just on the drive home today and it was tight on there. Will test more tomorrow after I wiped it clean to be double sure. Tomorrows drive will tell a story about these Toy filters. Thanks for the heads up.
    The actually seepage that has my attention is around the lower oil drain pan seal below the engine. Nothing but a wipe of the rag seep and no drops on driveway in the 3-4 months since the last change.
  9. Feb 6, 2019 at 4:39 PM
    #3789
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’m pretty happy lol. I bought it sight unseen. He made it sound way worse than it was. Apparently the damage is from rolling at 70mph. But I don’t see it being that fast.. hell I’ve seen trucks roll doing 20 with way more damage
  10. Feb 6, 2019 at 4:41 PM
    #3790
    empty_lord
    05 rollover special
    I’ll probably attempt building one. Lol factory Toyota bumper is expensive. Aftermarket I’ve had back luck with.
    But first I have to get the front end sorted out before I worry about the rear
    ethan1911[QUOTED] likes this.
  11. Feb 6, 2019 at 5:33 PM
    #3791
    Casper421
    In the woods
    06 DC
    To help the front springs settle a little, I mounted up the front and oil pan skid plates today. I’ll mount the other two when I have more time.
  12. Feb 6, 2019 at 5:54 PM
    #3792
    Valler
    Valler New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    Got a set of new tires put on went from a 305 70 16 to a 285 75 16 tires, was cheaper then going with a 305 again
    Brown Bear, mtntop, ethan1911 and 5 others like this.
  13. Feb 6, 2019 at 8:34 PM
    #3793
    6ixofone
    6ixofone New Member
    Greenville, SC
    2001 sr5 ac 4.7
    What shocks and springs you have on?
  14. Feb 6, 2019 at 9:12 PM
    #3794
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Better tire size for these trucks I think. Same diameter but .75 inches skinnier.
  15. Feb 7, 2019 at 12:36 AM
    #3795
    sakana
    sakana New Member
    2002 Tundra AC Limited 4X4
    MT Classic II, Bilstein 5100, 4.88's, BAMuffler catback, 250cc 12-hole injectors, Powerstop Z36 brake kit, Hellwig helper spring and rear swaybar
    I'm doing a few minor repairs to my 2002 (a la PHM) and one of them is to replace a bad door jamb switch. But Amazon doesn't have the Wells SW1856 in stock, and the only other place I can find them right now is Autozone - but they want $61 a piece. Not going to do that. Anyone know of any other more reasonable options for door switches?
  16. Feb 7, 2019 at 12:45 AM
    #3796
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    right on. I like the AT tread with an MT sidewall myself.
  17. Feb 7, 2019 at 5:11 AM
    #3797
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Try www.aliexpress.com ? If they sell on Amazon, they probably also sell on Ali.
  18. Feb 7, 2019 at 6:02 AM
    #3798
    Valler
    Valler New Member
    Ramon
    It has kyb gas a just on all 4s with a spacer in front, want to change them it came with them when i bought the truck
  19. Feb 7, 2019 at 6:04 AM
    #3799
    Valler
    Valler New Member
    Ramon
    Yeah i like the 285s much smoother ride, i felt like the 305s where to heavy for the truck it wouldnt take off quick now with the 285s it takes off much quicker
  20. Feb 7, 2019 at 6:08 AM
    #3800
    Fred
    Hand Protectors
    285/75/r16 is purrfect! You just upgraded by going smaller. Cheaper than a re-gear!
    Sunnier and Valler[QUOTED] like this.
  21. Feb 7, 2019 at 6:11 AM
    #3801
    03tundra
    03tundra New Member
    2003 white tundra
    Wheels & tires
    Anyone looking for cheap tires good news the new Rubicons use 285/70/17 that means bfg take offs for dirt cheap saw 5 take offs on craigslist for $500 Facebook market place has been a good place to find stuff also
    Darkness and speedtre like this.
  22. Feb 7, 2019 at 6:33 AM
    #3802
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Check with your dealer
    https://www.toyotapartsdeal.com/oem...dra&Year=2002&Submodel=&Filter=()&Location=pd:,
  23. Feb 7, 2019 at 6:38 AM
    #3803
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've thought about that a lot. Shame that BFG stopped producing that tire in mass and only produces it in Jeep sizes. Curious what weight rating they have.
  24. Feb 7, 2019 at 6:42 AM
    #3804
    03tundra
    03tundra New Member
    2003 white tundra
    Wheels & tires
    All the ones I have seen so far are the E load not LT version I think the e load weighs about 4-5lbs more per tire
    Darkness[QUOTED] likes this.
  25. Feb 7, 2019 at 6:44 AM
    #3805
    mtntop
    mtntop New Member
    Did ya check with @Roman at Toyota of Cool Springs?
  26. Feb 7, 2019 at 7:49 AM
    #3806
    trailbikerider
    Blake
    Kalamazoo, MI
    2006 Tundra DC SR5
    NUDRAT, Sunnier and Eugene406 like this.
  27. Feb 7, 2019 at 8:27 AM
    #3807
    Been doing research on Toyota coolant today. I just don't believe that the average Valvoline, Meineke, Pep Boys etc stock genuine Toyota coolant. I have to assume there are millions of Toyota vehicles operating fine with other brands of coolant.
    Found the spec sheet for Aisin's coolant. Confirmed it's Ethylene-Glycol just like the manual says we can run. I'm convinced it's the same formula as Toyota's for half the price. Hell, Aisin designed it specifically for Toyota vehicles and they are affiliated(or owned?) by Toyota.
    Both have Ethylene and Diethylene Glycol.
  28. Feb 7, 2019 at 8:33 AM
    #3808
    mtntop
    mtntop New Member
    I use a Zerex pink coolant from NAPA which is designed for Toyota's and have never had an issue.
  29. Feb 7, 2019 at 8:35 AM
    #3809
    Fred
    Hand Protectors
    Well boyz. I took the day off because I can’t stand my boss (I’m a self employed semi retired hand model). Decided to tackle 12 hole fuel injector upgrade job.
    Que: Bob Marleys ‘Sun is Shining’ lyrics...
    Sun was shining, my happy feet were moving.
    Started to unbutton the driver side and the battle level with the injector rail was richter at every step. Tried multiple attack points. Nothing is easy about this job. Finally retreated when the 3rd of 4 injector clips wouldn’t detach. Tried patiently and thats when the loose bowels kicked in. Cold sweats followed. The clouds moved in. So, I buttoned everything back up and test drove the truck to test for leaks and everything runs like normal. So close yet so far away as I was 90% there on the driver side.
    We’ll consider this a tactical retreat for now. Defenses were probed. New strategies in development.
    NUDRAT, Sunnier, hammeron and 2 others like this.
  30. Feb 7, 2019 at 8:39 AM
    #3810
    Fred
    Hand Protectors
    Key word ‘equivalent’. My mechanics, when they replaced the 02’ radiator, used ‘equivalent’ yellow stuff. They specialize in Toyota/Nissan.
