Husky Liner X-Act Contour for 2019 (2nd row full coverage)?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pigglet222, Jan 15, 2019.
  1. Jan 15, 2019 at 3:54 PM
    Pigglet222
    Pigglet222 [OP] New Member
  2. Jan 15, 2019 at 4:36 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    There has been no change between the 2018 & 2019 Tundra so the X-Act Contour's should work fine. To confirm, I compared the part number for the Weather Beaters for the 2018 and 2019 and they are the same.
    I have the X-Act Contour full coverage in my 2016 and have no complaints.
    hma153 likes this.
  3. Jan 16, 2019 at 5:34 AM
    nodak67
    nodak67 New Member
    JR
    on the 2nd row, make sure you decide which version you want. 1 version doesnt cover under the seats and 1 version does when the seats are folded up.
    also as stated above no difference between 2018 and 2019 floor plan layout on the CM.
  4. Jan 16, 2019 at 6:34 AM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I ended up going Husky in the front and weathertech in the back. Kind of like a floor matt mullet.
    7B8AA600-5A58-4E09-BCB1-B262123BDE5D.jpg 0138D1FE-2EE8-4543-A617-D18EC41B3DF0.jpg
    gkelm and Sunnier like this.
  5. Jan 16, 2019 at 6:38 AM
    twintundra2016
    twintundra2016 New Member
    Chad D
    New Brunswick, Canada
    2013 Tundra SR5 5.7L
    i bought max liners for mine off of Amazon, the reviews said fitment was not good, but can't complain, plus I find them easier to clean then weather techs!!
  6. Jan 30, 2019 at 7:14 PM
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    What do you like better about each brand? I had weather tech liners in my last truck, no complaints. Trying to decide on what to order this time around. Is there more coverage in the front with husky and the rear with weather tech?
  7. Jan 30, 2019 at 7:19 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    I have the X-Act Contour full coverage in my 2019 - all good so far
  8. Jan 30, 2019 at 7:19 PM
    ProtoJ
    ProtoJ New Member
    For the rear, weathertechs go all the way under the rear seat as you can see. The husky only does the floor area. For the front, the huskies are a little denser and fit tighter to the door sills and don’t seem to warp like the more rigid weathertechs. Also, I have the split bench front seat and husky made a center front matt to match.
  9. Jan 31, 2019 at 6:55 AM
    nodak67
    nodak67 New Member
    JR
    actually husky makes 2 versions for the back seat area. floor coverage only and under seat coverage. i have the 2018 husky that cover under the seats and the front, x-act contour for both sets.
    Pigglet222[OP] and Boerseun like this.
  10. Feb 1, 2019 at 8:28 AM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
  11. Feb 1, 2019 at 8:29 AM
    Navi
    Navi New Member
    that’s a good price too you’re getting..
  12. Feb 2, 2019 at 6:26 AM
    arkhomer
    arkhomer New Member
    Tyler
    2024 Limited
    I've owned 3 or 4 sets of weathertechs, no complaints. I was dead set on husky x act fit but called my local dealership and they sell techs front and rears for $180. Backs need a heat gun taken too them but otherwise fit nicely. May have to do some trimming in rear near under seat vents
  13. Feb 4, 2019 at 8:12 PM
    nodak67
    nodak67 New Member
    JR
    biggest issue i have had with all weathertechs in the 4runner, tacoma, highlander, rav4 was that the WT always were too stiff and would never conform correctly even thru a summer heat.
    this time around went with the husky x-act contours on the tundra and never had a fitment issue since they are more pliable than the WT.
