TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Mar 27, 2024 at 4:40 AM
    #631
    dark_knight_sig
    dark_knight_sig New Member
    2023 Toyota Tundra SR5
  2. Mar 27, 2024 at 5:15 AM
    #632
    Goobax
    Goobax New Member
    I don’t believe so but it really doesn’t matter what kit or adapters you use as you can make the wiring as straightforward (or complicated) as you like. The easiest solution is to tap into the tail lights for the rear and the running lights for the front.
    The instructions for R are attached and the video I used as a reference is below. Be advised that on my truck, the front wires I needed to tap were the middle and solid color wire, not the outers like he did so make sure you have a tester. For the rear lights, I used a 7pin dual output trailer harness from diode dynamics.
    https://youtu.be/gsL99_euN0U?si=h1bLAsa6wcLA7qqb
  3. Mar 27, 2024 at 5:25 AM
    #633
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    You can’t tap into the running lights of the headlights if you have premium headlights. I’m wiring mine to a 7 pin to 4 pin harness. Super simple. If you want them on all the time when the truck is in you could also run an add a fuse to the fuse box.
  4. Mar 27, 2024 at 10:54 PM
    #634
    Rafael707B
    Rafael707B New Member
    Rafael
    2023 Toyota Tundra Platinum
    Stock
    How did you wire yours? I have a platinum and want to do the same thing. Do you have pictures of your truck? Thanks for any help
  5. Mar 28, 2024 at 5:36 AM
    #635
    Ipaddick
    Ipaddick New Member
    Canada
    I haven’t installed mine yet, still waiting for the flares. But after a bunch of research, I am wiring them all the a 7pin to 4pin harness. This way no oem wiring is tapped/damaged. I am using deutsch y connectors, and connectors so everything looks oem, and on one harness.
  6. Mar 29, 2024 at 5:09 PM
    #636
    chunkytundra
    chunkytundra New Member
    Trying to order them but no one has them. I guess there is a back order of 200+ in the nation with no eta.
  7. Mar 31, 2024 at 5:39 AM
    #637
    Chad365
    Chad365 New Member
    GA
    2023 HV MGM 1794 TRD OR 4x4
    Chrome delete and more to come WIP …. Lol
    You can wire them to the fuse box in the front , eng igr 1 for passenger side and eng igr 2,3,4 I think you have choice (7.5 fuse) on driver side
    They will stay on whenever your truck is on , kinda like how marker lights should be .
    If you order the wiring harness from rave off road it was the easiest for me to do , I did have buy an extra fuse tap from the local auto part store , as I did not want to run the driver side wiring all the way to the passenger side to tap into.
    I am still waiting on rear fenders but the rear wiring is all plug and play. So will be fairly simple
  8. Apr 27, 2024 at 5:56 AM
    #638
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    Thanks to all that contributed to this subject. I read all the pages that started since 2022.
    Great mods.
    I would suggest to everyone that is having fun modifying their truck, to Start thinking LONG TERM
    Meaning you will be adding a lot of things to your truck and in no time your truck wiring it will look like a wiring hornets mess.
    Add a light controller with a fuse box . I know this from having my Jeep for 9 years.
    This will help you organize your wiring and make it easy.
    Lots of options out there. Some are cheap , some very expensive. They all work great and do their job.
    Good luck to everyone having fun
    CV60 likes this.
  9. Apr 29, 2024 at 12:21 PM
    #639
    CV60
    CV60 New Member
    ’24 Tundra 1794 Lunar Rock
    Taikowaza - Do you think this will impact service, with the technician seeing the modification? thx
    Taikowaza likes this.
  10. Apr 29, 2024 at 7:17 PM
    #640
    Taikowaza
    Taikowaza New Member
    I have had my wired marker lights installed for months and have had service and recalls performed during that time with no issues.
    CV60[QUOTED] likes this.
  11. Apr 29, 2024 at 7:37 PM
    #641
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Same here. No issues.
    CV60 likes this.
  12. Apr 29, 2024 at 8:13 PM
    #642
    CV60
    CV60 New Member
    thank you
  13. May 9, 2024 at 9:07 AM
    #643
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    Tonneau cover
    Vivid wrap has some camo that looks really awesome. Im wondering if there are other flares out there that are very similar and I can just wrap them to the camo that I want. Some with marker lights already in them would even be better.
  14. May 30, 2024 at 6:00 AM
    #644
    Ipaddick
    Ipaddick New Member
    Canada
    What wires in the flat four do you is?
  15. May 30, 2024 at 7:45 PM
    #645
    Ipaddick
    Ipaddick New Member
    Canada
    Which wires are used in the flat four?
