Shark fin leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Waltmg, Mar 24, 2024.
  1. Mar 24, 2024 at 7:07 PM
    Waltmg
    Waltmg [OP] New Member
    2021 white sr5 double cab 4x4
    De-badged + lumber rack Toyo at3 on stock steels no caps.
    Hey guys and gals, Walt here, I'm new. I had a leak in my 21 tundra double cab at the rear of the headliner dead center. I tried the replacement of the CHMSL gasket . Still leaked It turns out it was the shark fin leaking. I used some threes bond around the small rubber seal in the center. I'll wait and see if it leaks anymore.
    bulldog93 likes this.
  2. Mar 24, 2024 at 7:40 PM
    Welcome from NY.
    Wouldn't that be covered under the warranty? Hopefully it us and they also replace the headliner. :fingerscrossed:
  3. Mar 24, 2024 at 7:56 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Welcome from the desert.
    I agree, warranty and have the headliner looked into also.
  4. Apr 30, 2024 at 9:30 AM
    FiveO Enduro
    FiveO Enduro New Member
    Buffalo, NY
    2020 Army Green Pro
    Any luck on this? I just replaced my third brake light gasket , ordered an evil off-road third brake light - just to find out it was the shark fin.. the last two pics are under a light rain. Can’t find a trace of water anywhere near third brake light, window seal or roof rack. This is the only thing I found, wet corners of the shark fin antenna assembly. I can wipe off and it slowly comes back. Also, hydrogen peroxide works amazing on removing the stains.. last pic.
    bulldog93 and panicman like this.
  5. Apr 30, 2024 at 10:07 AM
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Confirmation I suppose :
    I definitely went overkill, but if there’s one thing I don’t want to mess with.. it’s water:
  6. May 10, 2024 at 10:37 AM
    CringyDad
    CringyDad New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    Mine is super loose too...I have to pull up on it and blow water out from under every time I wash it. Good lord, is anything Toyota installed on these trucks not cheap plastic junk?
  7. May 10, 2024 at 11:24 AM
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    I can’t speak for the 3rd gen. But on my 2020, it seemed like a daunting task to do this fix but it really was not bad at all. Easier than I anticipated and super glad I did it.
  8. May 10, 2024 at 12:20 PM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Now I’ll have to go check out my ‘21. Is it a pita to remove the headliner? Do you just drop it from the rear forward I guess.
  9. May 10, 2024 at 1:17 PM
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Pop off rear headliner grab handles, then the top plastic piece around the rear seatbelts plus 10mm behind abs plastic circle. Then there are 4 push clips keeping the rear of the headliner in. With the rear window down, it’s super easy to stick your fingers above the liner and feel where the clips are and just pull down gently. I left the plastic around the seatbelts on.. just pulled away slightly allowing the headliner to push around it. There’s plenty of room to get in there and work with just the rear of the headliner pulled down slightly. There may be other threads with more specific details, but it really isn’t bad at all.
  10. May 10, 2024 at 2:59 PM
    Xcumminsguy
  11. May 10, 2024 at 6:24 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
  12. May 10, 2024 at 11:06 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Damn shark fin antennas. I had to deal with this on my Silverado and now the Tundra? Sheesh I despise these things.
  13. May 11, 2024 at 11:35 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    So the shark fin is only held on by one bolt?
  14. May 22, 2024 at 12:34 PM
    FiveO Enduro
    Buffalo, NY
    2020 Army Green Pro
    Yup, the pic above with the single bolt..
