6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Apr 4, 2018 at 4:21 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I would like to see a thread from those running 6112 coilovers. List your setting, tire size, wheel specs, shims, no shims, uppers, no uppers, diff drop, etc. Pics would be awesome if you can. In general just describe your setup please. Thanks.
    JediMedic86 and Mattyc like this.
  2. Apr 4, 2018 at 4:34 PM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    6112s top setting, TC UCA, no shims no diff drop. 295/70r18 STT Pro
  3. Apr 4, 2018 at 4:36 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    are those scs wheels? They look awesome
    yoshi82 likes this.
  4. Apr 4, 2018 at 4:46 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    6112's @ top setting. No shims. Bump stop extensions. 5100's in the rear with 1" tapered block . I have a slight rake exactly what I was going for. I'm still running my factory 18" rims with Nitto Ridge Grapplers (295/70/18's). Im also running Spider Trac 1 1/4" spacers.The difference between the 6112's and my old Trd 4600's is night and days apart. These 6112's absorb just about everything. I'm am very happy with this set-up. :thumbsup: 1 quick note. I rub on passenger front @ full lock in reverse. It's not even enough for me to remove flap. :D
  5. Apr 4, 2018 at 4:49 PM
    Rngr188
    Chad
    Harrison AR
    I've got the exact truck and love you're look. Not sure I can swing UCAs and wheels at the moment, I've got a bit before I need my factory tires replaced but in the mean time I might be able to we'll see.
  6. Apr 4, 2018 at 4:54 PM
    rons23
    Ron
    Kill Devil Hills
    Steve i got home yesterday and was cussing at the pollen on my newly detailed Tundra . Sprayed it off and it was like just leaving Jims after detailing it. That quartz product is Amazing. Water just beads off and disappears leaving no streaks nothing:thumbsup:
  7. Apr 4, 2018 at 4:56 PM
    Unlimited
    SCS Ray 10's!
    Olson and teedubbya[QUOTED] like this.
  8. Apr 4, 2018 at 4:59 PM
    teedubbya
    Austin TX
    Wish I could get my hands on some. Sold out :(
  9. Apr 4, 2018 at 4:59 PM
    Unlimited
    I know a lot of guys go with stock UCA's, so I would say that might be optional if you can get it aligned in spec etc. Also I got about $80 credit per tire at Discount Tire when I traded the stockers in.
    Laverga likes this.
  10. Apr 4, 2018 at 5:03 PM
    Rngr188
    Chad
    Harrison AR
    I do have to get this unexplained incident fixed at some point soon though. It's worse than the pictures show.
  11. Apr 4, 2018 at 5:48 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    6112's at 1.9 setting, driver side shim, CB+3 shackles, stock control arms, tires and wheels for now.20180302_221809.jpg
  12. Apr 4, 2018 at 6:14 PM
    Rngr188
    Chad
    Harrison AR
    What size tires do you plan to go with? Are you keeping the factory wheels or going aftermarket?
    pg_osborne89 likes this.
  13. Apr 4, 2018 at 6:22 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Think I'm gonna stick with the stock wheels but get em powder coated for now and plan on running 285/70r18 ridge grapplers.
    Derf77 and dannysmith604 like this.
  14. Apr 17, 2018 at 2:12 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    6112's at 1.9 with 1 coachbuilder shim per side. Rear is coachbuilder +2 shackle with 5100's SCS ray 10's with 295/70/18 Cooper ST Maxx.
  15. Apr 17, 2018 at 3:05 PM
    Unlimited
    Got the Toytec shackles done this weekend, the 1.5" rear lift makes a big difference
    BEFORE:
    AFTER:
  16. Apr 17, 2018 at 3:19 PM
    rons23
    Ron
    Kill Devil Hills
    Jason , what's your thoughts on the St Maxx
  17. Apr 17, 2018 at 3:59 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    6112, on top setting, with 1 CB shim on driver side to account for tundra lean. 5160 in rear with a CB +2 shackles. Stock wheels 275/70/18 BFG KO2. Also have the carrier bearng dropped since CB shackles came with spacers. 20180325_145005.jpg
    Winning8, rv740, Bluesttape and 13 others like this.
  18. Apr 17, 2018 at 5:02 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Maxed out the 6112s up front with a single CB shim on the driver side along with alignment. I have stock shackles and the icon (51200) add a leaf pack installed on the rear with 5160s. NO UCAs yet.
    Wheels are 18x9 +25 Method NVs
    Tires are 305/65R18 BFG KO2s
    This set up gives me rake ~0.75” lower in front from rear. Expecting the front to settle a bit more since I just had em adjusted. If I decide I need more rear lift I’ll probably go with 3/4” Total Chaos shackles.
  19. Apr 17, 2018 at 6:33 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I only have 10 miles on these so I cant say much. After reading the thread on them over at TAcomaworld and the discount tire eBay deal i couldn't pass them up. $200 a tire is cheap for 295/70/18. They look great though and balanced easy.
    rons23[QUOTED] likes this.
  20. Apr 17, 2018 at 8:56 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2015 MGM TRD 4x4 Crewmax
    Toyota spray in bed liner/ 30" LED Lightbar/ Pro Comp Pro Runner SS @ 2.5"/ Husky Xact fronts/ Weathertech rear/ NFAB steps/ 275/70R18 BFG KO2's/ LED interior from GTR lighting/ Tekonsha Prodigy Trailer brake Controller
    6112s top setting, Toytec shackles max 1.5 setting with 5160s, 295/70r18 Toyo AT2 xtreme. 18x9 Fuel Mavericks. +20 offset.
  21. Apr 19, 2018 at 11:50 AM
    FSUTundra
    FSUTundra Misplaced Texan
    Cody
    2018 MGM 4x4 CM TRD
    For y'all in here, how is the ride on the 6112s compared to stock?
    Considering them for my truck.
  22. Apr 19, 2018 at 11:54 AM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    They are a big improvement over stock.
    Seth and Tundyfundy like this.
  23. Apr 19, 2018 at 11:57 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I'm really enjoying the ride over stock. I'm glad I was able to get mine before they became sold out everywhere.
  24. Apr 19, 2018 at 12:07 PM
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Subscribed
  25. Apr 19, 2018 at 1:25 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Makes the traction control come on WAY less too
    cdavi060 and Rica25 like this.
  26. Apr 20, 2018 at 12:26 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    They are great! Firmer in a good way, even my wife noticed. If you aren't trying to get wild with the suspension, this is a great option.
  27. Apr 20, 2018 at 1:35 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Looks great! That's almost exactly what I'm thinking of doing, shackles and all. What kind of rake do you have with the shackles (if you've measured)?
    nowayout[QUOTED] likes this.
  28. Apr 20, 2018 at 5:07 PM
    nowayout
    nowayout New Member
    NY
    17 CM
  29. May 18, 2018 at 7:47 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Looking good :thumbsup: what's your offset, any rubbing?
    1TundraPilot likes this.
  30. May 18, 2018 at 7:54 PM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    Any more pictures you can share? Looks great.
