GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in '3rd Gen Tundras (2022+)' started by Tsquare, Jan 16, 2022.
  1. Apr 25, 2024 at 10:30 AM
    #4801
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Stock non TRD suspension no rubbing at all, watched a vid on yt, and apparently you can fit 35's with very minor cutting of inner fender plastic and -18mm offset
  2. Apr 25, 2024 at 7:20 PM
    #4802
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Do you need to use hubcentric rings with aftermarket wheels? Just curious what everyone is doing.
  3. Apr 25, 2024 at 8:27 PM
    #4803
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Yes if the hub diameter do not match, most times the wheels do
  4. Apr 26, 2024 at 6:48 AM
    #4804
    SilveradoSwap
    I ordered an aluminum set, box says 95.1 to 106.1, ring says 95.1 to 106…grrr, lol
  5. Apr 26, 2024 at 12:11 PM
    #4805
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    Cheap (and also dirty, sorry) SR5 with cheap eBay 295/70/18 on AGP replica rims.
  6. Apr 26, 2024 at 3:34 PM
    #4806
    Chad365
    Chad365 New Member
    GA
    2023 HV MGM 1794 TRD OR 4x4
    Chrome delete and more to come WIP …. Lol
    got factory 3” lift , amp power steps, method wheels 295/70/18 (34.26) no rubbing or anything not even close ! +18 offset
    Also I remember someone asking about the spare , I have a full size spare it fits btw , a bit off center though , I’ll have to look into that lol
  7. Apr 26, 2024 at 5:49 PM
    #4807
    Momcar160
    Momcar160 New Member
    22 TRD Sport 4x4
    11.50s Fits the stock wheel perfectly with no rubbing. I went back and forth a million times about 12.50s and just decided an inch didn’t matter that much to me
  8. Apr 26, 2024 at 6:30 PM
    #4808
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I'm torn... I got a black tundra with no chrome.. do I go for the blacked out look with black wheels. Either a set of the TRD Pro BBS or Methods 18". Or do I go bronze wheels. Would be a 18 method for sure...
    Going with a 35x12.5.. maybe 37 if I can fit it.
    Opinions Welcomed!
  9. Apr 26, 2024 at 6:34 PM
    #4809
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, PPF,Tint, AMP PowerSteps, TRD Options+
    Here’s a shot of the blacked out look of my Nightshade Blueprint Limited with TRD Pro wheels to compare…
    az 3rdGen and Tundrastruck91 like this.
  10. Apr 26, 2024 at 7:35 PM
    #4810
    OVRLDAF
    OVRLDAF New Member
    After browsing and over analyzing everything in this forum and elsewhere, pulled the trigger on a set of Method 705 in 17x8.5 ET0 and Toyo RT Trails 35x12.50/17. With no lift, I did have to do the usual liner trimming, bracket and mudflap removal but so far so good. Went camping immediately after the install and got some much needed dirt therapy.
    BabyMoose likes this.
  11. Apr 26, 2024 at 10:33 PM
    #4811
    alkalinedevin
    alkalinedevin New Member
    2023 TRD Pro
    35X12.5r18 KO2's mounted up finally. No rubbing at all, lock to lock.
  12. Apr 27, 2024 at 1:13 AM
    #4812
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Looking good
    Stock height or levelled ?
    alkalinedevin[QUOTED] likes this.
  13. Apr 27, 2024 at 10:36 AM
    #4813
    SilveradoSwap
    Does the TRD Pro come with a higher stance?
  14. Apr 27, 2024 at 12:51 PM
    #4814
    osu1978
    osu1978 New Member
    1.1” in the front.
  15. Apr 27, 2024 at 1:46 PM
    #4815
    alkalinedevin
    2023 TRD Pro
    Thanks!
    Stock height / Factory Pro Fox Suspension has a level from factory up front.
    Welderdude80[QUOTED] likes this.
  16. Apr 27, 2024 at 3:47 PM
    #4816
    carbinefreak
    carbinefreak New Member
    After digging through this for a few months ended up pulling the trigger on Method 318 8.5x18 +40 with KO2 295/70R18's. No mods other than larger after market mud flaps, no rubbing lock to lock anf the tires are flush with the off road stock fender flares. I live up in the mountains of CO on dirt roads so I can't have any poke, this fit the requirements perfectly. Now to figure out what pressure to run, starting off at 36psi, the math works out to 31 but I don't think I should keep them that low.
    cabiczzz likes this.
  17. Apr 27, 2024 at 3:50 PM
    #4817
    SilveradoSwap
    Looks good, fitment is best for that type of terrain. Method wheels sure seem popular lately.
  18. Apr 27, 2024 at 5:58 PM
    #4818
    carbinefreak
    Yah they were cheap and quick to get, I really wanted some gram-lites but the lead time was insane. The hard part is finding high offset wheels over +35. This was one of them.
  19. Apr 27, 2024 at 6:08 PM
    #4819
    SilveradoSwap
    I had a set of wheels I ordered in March not going to ship mid to late June at the earliest. I passed once I realized how much poke there was gonna be.
  20. Apr 28, 2024 at 10:20 PM
    #4820
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Good taste. Bronze and black is always a killer match
    az 3rdGen likes this.
  21. Apr 28, 2024 at 10:21 PM
    #4821
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Nice setup.
    Chad365[QUOTED] likes this.
  22. Apr 30, 2024 at 8:10 PM
    #4822
    tacobronco
    tacobronco New Member
    Scott
    2024 Blueprint Crewmax Limited
    I have the TRD Off Road wheels, which I think are the same offset as yours, and no lift or suspension mods. I am running 275/65-20 BFG's, which is basically a 34 inch tire. No rubbing whatsoever. Nice thing is they also just barely fit in the spare carrier if you're into running a full size spare and a 5-tire rotation, which I am. A lot of people run 295/60-20, which is actually ever so slightly smaller in diameter, but wider, of course, and claim no rub. (It looked to me like 295s would be a little tight on the front of the upper control arms at full lock and in compression, but it's hard to visualize how the arm and the tire move relative to one another.)
  23. Apr 30, 2024 at 9:44 PM
    #4823
    jachal
    jachal New Member
    andy
    2023 Black Platinum Hybrid
    w ~1k payload
    Yaboy, ytank1, ullmsie and 1 other person like this.
  24. May 1, 2024 at 10:20 AM
    #4824
    ullmsie
    ullmsie New Member
    Limited DC TRDOR
    That thing is sweet.
    jachal[QUOTED] likes this.
  25. May 2, 2024 at 7:41 AM
    #4825
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    2022 TRD sport ( sits 1/2” lower in front.) Factory TRD 20” rims. Going to do the Westcott lift down the road. For now can I fit 295/65-20 on the truck stock? Does the 1/2” lower in the front matter? No mud flaps. Thanks.
  26. May 2, 2024 at 9:04 AM
    #4826
    DTieu1
    DTieu1 New Member
    Andrew
    2022 Toyota Tundra iForceMax
    Falkens Wildpeaks, 35x12.5x18
    Yaboy, ytank1, Boerseun and 1 other person like this.
  27. May 2, 2024 at 10:19 AM
    #4827
    Welderdude80
    JP
    Alberta
    working on it
    I ordered Toyo at3 and the next day I got an email saying they were back order and my other option is nitto recon grappler? Who’s running them ? Are quiet on hwy ? I’m currently on ko2 stock size and wanting go 285/65/20 (34.6). I find them really quiet will I be disappointed as far as road noise goes ?
    Bruski208 likes this.
  28. May 2, 2024 at 10:25 AM
    #4828
    DTieu1
    DTieu1 New Member
    Andrew
    Yeah, I love these tires so far, Ive had Toyos MT before, and those were loud. But its quiet, tread wear is great too
    Welderdude80 likes this.
  29. May 2, 2024 at 1:11 PM
    #4829
    nkawal
    nkawal New Member
    2024 Tundra Limited
    Been debating which tire to go with since I bought my 24 limited 2 months ago. I finally pulled the trigger and went with 285/60/20 Falken Wilpeaks AT4W. They were actually $5.00 cheaper per wheel than the popular AT3's. They should be delivering to the installer by saturday.
  30. May 2, 2024 at 3:29 PM
    #4830
    SilveradoSwap
    I hear the AT3 are quieter than the Recons.
