“epb activation stopped incompletely”
Discussion in '3rd Gen Tundras (2022+)' started by TundraTun, Mar 31, 2022.
  1. Mar 31, 2022 at 2:26 PM
    TundraTun
    TundraTun [OP] New Member
    Today while parking I received this warning message.
    electronic parking brake seemed to not engage all the way. I reached down and manually pushed the parking break button. Warning went away. If it happens more I will call dealer. Anyone else have any issues?
    2022 SR5 Crewmax
  2. Mar 31, 2022 at 3:05 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I had it happen to me once. Hasn't happened again. It seemed like maybe I turned off the ignition too quickly while putting it into park.
  3. Mar 31, 2022 at 3:10 PM
    TundraTun
    Yea I figured as much. Thanks for the reply.
  4. Mar 31, 2022 at 3:29 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Likewise. Happened once when shutting off too quickly when parking. Never happened since.
  5. Apr 4, 2022 at 12:22 PM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    This happened to me once as well as I shut the ignition off too quickly. I turned the auto park brake off and not an issue since.
  6. Aug 11, 2022 at 1:26 AM
    Pg1329
    Pg1329 New Member
    2022 tundra limited
    Just got my truck. Already happened to me twice should I contact my dealer?
  7. May 26, 2023 at 5:09 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Is this still an issue? Happened to me when I started the truck this morning.
  8. Dec 26, 2023 at 10:30 AM
    FirstTimeTundy
    FirstTimeTundy New Member
    2024 Black Tundra SR5 Premium
    I parked my 2024 SR5 (bought in late November) at home a few days ago and went out this morning and the battery was dead. Jumped it this morning and strangely no cabin lights were on and no obvious source of battery drain. The EPB error message was on the display when I started the truck. Not a good sign that the battery is already dying.
  9. Dec 27, 2023 at 7:36 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    No issue at all. You shut the truck off before the electronic break fully engaged and the truck is just letting you know.
    =JSG= and Mattedfred like this.
  10. Dec 27, 2023 at 7:58 AM
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    So you are saying things like wiper blades and windows will finish doing what they do even when you turn off the truck but the EPB won’t? I have to imagine it has something to do with the service campaign.
  11. Dec 27, 2023 at 8:01 AM
    Adam B
    Adam B New Member
    Why don't you try putting your truck in park and shutting it off immediately, then reply again.
    pwpblue and Mattedfred like this.
  12. Dec 28, 2023 at 8:20 AM
    Tundranewcomer
    That's ok. Doesn't matter. If it is designed to do that, then that is stupid. If it isn't designed to do that, then something is broken. Either way, seems like something the service campaign should address. Is it far fetched to think people will be turning off their trucks after putting them in park? The parking brake should be able to finish engaging no matter what.
    Okotoks Tundra likes this.
  13. Dec 31, 2024 at 6:48 PM
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    Just happened to me today. Not sure if I turned the truck off too soon. I read where this could happen if your battery is weak. I think mine is weak because the auto turn off feature says, “battery charging…” more than 50% of the time.
  14. Dec 31, 2024 at 6:52 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    My wiper blades stop in the middle of my windshield when I turn the truck off. They don't go down to the stowed position.
  15. Jan 1, 2025 at 5:32 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I just turned off my auto parking brake. I don't park on hills so there's no need for brake to set every time I put truck in park. If I need it, I'll set it myself. Problem solved.
    BlackNBlu likes this.
  16. Jan 1, 2025 at 7:11 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I've had that EBP message at least two times and I think that both were when I turned it off quickly.
  17. Jan 1, 2025 at 10:42 PM
    Observer
    Observer New Member
    Have had this happen a few times also. As I understand it and as has been stated when you put the vehicle in park it activates the parking brake and if you shut the truck off before it gets a chance to "completely" do it's thing up pops the message. The reason it occurs with me is I have gotten into the habit when i park in the garage or anywhere of immediately pushing the stop engine button to avoid the auto start/stop shutting the engine down only to start back up again before I shut it off. Which drives me insane. If I have disabled the start/stop prior to this I have no problems. As Raven has said you can disable your automatic parking brake and problem solved. The caveat to this though is if your parking on an incline it's puts all the pressure to keep the vehicle in place on the "parking pawl" in the transmission which is something you don't want to have to pay to fix if you damage it or shear it off. Hence, you will have to set the parking brake manually.
    P.S. For what it's worth it, I truly scare myself when I sound like I know what I'm talking about.
    CrayCray, sandiegosteve and Raven67 like this.
