Off Road Build with DIY and Production Mods on 37’s
Discussion in '3rd Gen Builds (2022+)' started by PapaDave418, Apr 3, 2022.
  1. Apr 7, 2022 at 8:32 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Very cool! Congratulations on the new truck and all your awesome mods!
    PapaDave418[OP] likes this.
  2. Apr 7, 2022 at 11:22 PM
    PapaDave418
    PapaDave418 [OP] A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
  3. Apr 9, 2022 at 3:17 PM
    Tundra009
    Tundra009 New Member
    Concord, CA
    Thanks for sharing the mods Dave. I'd like to see your setup and get some ideas if you don't mind. I'm in Concord and into overland as well. I went w/ 20 other rigs to Indian Valley reservoir last weekend.
  4. Apr 9, 2022 at 11:06 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Great photos! I am sleeping on the banks of the Klamath River right now as I type. I led 14 rigs up to the Lost Coast of California. It’s been a great trip so far
  5. Apr 9, 2022 at 11:18 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Northern California Lost Coast
    AC178707-3484-41FF-A981-57AD19B38C74.jpg 5BEDC698-40F9-4EF1-AF19-45807A918AF5.jpg 969E5361-26D9-412C-88AB-7A96C4728B28.jpg 39EC220F-4199-4A19-87D6-EE1561642DA6.jpg
    Time to winch! 3D0AACFB-352C-4C50-8CB0-C239E6E19833.jpg 4B4B46BF-C3D0-414D-8771-366C086C9944.jpg
  6. Apr 11, 2022 at 8:26 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Wellllllll
    I need a new front emblem. The freakiest thing happened, I was driving 65mph on a highway and a stick fell from a tree in front of me and idk if it wedged against the grill or what but it literally plucked the emblem off like a bottle cap. Just the emblem, not a mark anywhere else on the grill. This all happened in 0.2 seconds.
    The stick wasn’t even big, like a broom handle, and it landed right as I was driving over it and suddenly the emblem flipped over the hood, off my windshield, and I didn’t see where it went. Mind you this is a busy California highway and I went round and drove by again to look but couldn’t find it without the risk of dying.
    TheDanimal likes this.
  7. Apr 11, 2022 at 8:46 AM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Somewhere in California, there's a piece of wood with the Toyota emblem stamped square into it :rofl::rofl:
  8. Apr 11, 2022 at 8:49 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    No joke and I want it back! Hahaha.
    Hwy 101 north of Novato!
    Tundra'25[QUOTED] likes this.
  9. Apr 11, 2022 at 8:58 AM
    Tundra'25
    Wincent
    Southern California
    Hey, at least your grille is blacked out now! You just have to ignore the four little rectangles
  10. Apr 12, 2022 at 9:51 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I got 2 mods done today, the first is simple. My HAM unit is under the front passenger seat and I wanted to add an extension for the mic so that it wasn’t stretching from under the far seat. So I routed the extension into the center console.
    There’s 4 bolts that I loosened
    I drilled a hole near the edge just big enough for the mic plug, then snaked it down and out under the seat
    The rubber mat forces a tight fit better than I expected when I put it back in
    Now the mic stores in the center console and can easily be used
    Anyone have a good solution for organizing the console storage?
    Black@Blue19, Glaurung and Tundra'25 like this.
  11. Apr 12, 2022 at 10:44 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    When I get my new KB Voodoo Pro-Max rack my plan is to install a KC HiLites rear chase bar that will have rear turn signals and amber dust lights. I needed to install 2 switches to signal the solid amber and flashing amber lights. The amber LED’s have a minimal draw so I’m switching them directly.
    https://www.kchilites.com/28-multi-function-rear-facing-led-light-bar-9801.html
    I found these switches to place in the lower left dash
    https://www.aironboard.com/online/p...imit=80&rockerswitch_type=15&toyota_model=454
    The corner boot has a twist off nut
    Lift the door sill straight up and it will unsnap
    Pull towards the rear of the truck on the corner boot
    To access the lower left panel un-clip the bottom panel, there are two screws, one pictured above, one pictured below. There are tabs to press in as well across the front
    Slide a narrow screwdriver into the clip slides to remove the OBII plug
    To access the lower left dash panel unscrew this screw
    Pull straight out on the dash and the clips will begin to unsnap, I started more towards the top
    There is a sideways clip to be mindful of
    I was surprised to find that each plug was wired up, even if it was a blank. I hooked up a switch to where the heated steering wheel switch usually is but unfortunately it didn’t work. Thought perhaps there was a chance.
    To remove a blank use a narrow screwdriver to unclip the sides
    The blank is on the right so you can see the clips
    The AOB switch comes with a diagram to wire the switch for dash illumination and when pressed. The great news is you can use one of the unused plugs. Talk about easy. I used the bottom far right plug as you look at the panel. The positive dash light wire and negative dash light wire are the same as on the plug. I cut them and used a butt crimp to splice them into the switch harness. I combined the white and black grounds as the diagram mentions.
    You can see the cut wires and the unused plug
    I routed the amber lights power wires (green and white) with the red wire from the battery through the firewall. There’s a rubber grommet that I used a coat hangar to poke and fish it through. I loop the wires through a crook in the coat hangar and tape it off to secure the wires, at least that’s how I do it. 3AABF9A3-1A89-458A-968D-72E3182EA78A.jpg
    6636955C-B751-4BFB-9DC0-E9D1F60C15AD.jpg A2039E63-2F98-49F5-AD45-AB0CB8490F31.jpg
    Reassemble everything in reverse order and this is how the switches came out!
    They didn’t have perfect matches for my light names but REAR LIGHTS is my solid dust light and REVERSE LIGHTS are the blinking ambers which I use less
    Dash lights on
    Switches depressed
    View from the driver’s seat
  12. Apr 13, 2022 at 8:38 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    We have a meet up this Saturday 1-3pm, you can see the truck if you are around. We have a big turn out and will be discussing airing up and down, air tools, compressors etc.
    https://www.overlandbound.com/forums/threads/east-bay-monthly-meet-up—pleasanton-ca.41199/
  13. Apr 13, 2022 at 8:46 AM
    Tundra'25
    Wincent
    Southern California
    This is too neat. Props to you for being the first to attempt things, lol
    Do the aftermarket switches dim along with the factory stuff, too?
  14. Apr 13, 2022 at 8:51 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yup! Did you expect less?
  15. Apr 13, 2022 at 10:40 AM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
  16. Apr 13, 2022 at 10:46 AM
    Tundra'25
    Wincent
    Southern California
  17. Apr 17, 2022 at 1:41 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    My side business PullKitchen had a nice little unsolicited video posted by one of our customers out in Florida.
    https://youtu.be/mcNBvy4G3Cg
  18. Apr 17, 2022 at 1:59 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I banged out a quick step today after Easter service, I need to add the 12 pin bulkhead plug that will power my rack and tent as it goes on and off my truck like a backpack for off roading and camping.
    Holes always look terrible
    12 pin plug that still needs the wiring to the truck, some of the wires will piggyback off the trailer plug wiring, some pins are for rack lights and tent power
    https://mypartsuniverse.com/products/deutsch-dt-12-pin-flange-pigtail-kit-16awg-boat-wires-abyc-nmma-uscg-certified
    Much better
    12 pin to the rack
    Also added a fire extinguisher using a QuickFist
    https://www.amazon.com/dp/B007HOKW50?ref_=cm_sw_r_cp_ud_dp_E750JHEHY72518TMXP3Z
  19. Apr 24, 2022 at 8:01 PM
    #49
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yesterday I finished wiring up my connections to run my chase bar, which has brake lights-turn signals- amber chase lights-and reverse lights. The chase bar is tapped into the trailer plug wiring on the backside of the bumper so I can still plug in a trailer.
    The wiring diagram is conveniently located A9F43E32-AC72-4F94-96C5-97D0878602FA.jpg78E57D0F-4FC9-438F-BA22-420AD348D8AA.jpg
    Splicing in using heat shrink connectors
    Again this wiring runs up to a 12 pin bulkhead connector
    Black@Blue19 and Tundra'25 like this.
  20. Apr 24, 2022 at 10:39 PM
    #50
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
  21. Apr 25, 2022 at 1:26 AM
    #51
    Tundra'25
    Wincent
    Southern California
    Hot damn :eek2::D
  22. Apr 25, 2022 at 2:10 AM
    #52
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well this is entirely out of my league and just amazing work.
  23. Apr 26, 2022 at 11:24 AM
    #53
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Got my Westcott Designs 3/2 lift! Goes on this week97B306A6-DD61-4760-BDF0-39DF05199BC5.jpg
  24. Apr 26, 2022 at 11:41 AM
    #54
    Tundra'25
    Wincent
    Southern California
    They keep saying that their kits are supposed to be anodized black. I saw some on YouTube and they also said to ignore that it's not black, since it's only pre-production
  25. Apr 26, 2022 at 12:15 PM
    #55
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Yeah I didn’t care, it gets crazy dirty and is an intermediate lift for me, till it all gets locked in for a good suspension lift with new springs-shocks-UCA’s
    ryanwgregg likes this.
  26. Apr 26, 2022 at 2:17 PM
    #56
    Tundra'25
    Wincent
    Southern California
    Ah, I see. Whoops, didn't think about checking the website lol
  27. Apr 27, 2022 at 6:01 PM
    #57
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Got my Westcott Designs 3/2 lift in today and I like the change! I went with raw aluminum as I don’t really care as the shocks get dirty anyway and nothing looks better to me than King blue.
    Before
    After
    B6CB52FC-55EE-460D-AD86-00C2CF6F1719.jpg D3932AB2-B851-431E-8A50-D1ADE1E444F2.jpg
    Upper spacer
    Lower coil spacer
    Good news is that at full droop the brake lines have plenty of slack with the 2” spacer
    Bad news…Tundras have no droop!
    mayan, romanlegion, HMNYC and 2 others like this.
  28. Apr 27, 2022 at 8:19 PM
    #58
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Heck of a setup, heck of a write up, and one vey nice truck with added goodies!!!:) Very nice indeed.
  29. May 2, 2022 at 7:25 AM
    #59
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Installed my RLM Signs 2022 Tundra Decal, I like it! It does cut down on glare as well. Makes my truck feel like mine :thumbsup:
    https://youtu.be/B6pe000orgA
  30. May 2, 2022 at 8:10 AM
    #60
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Btw these little babies really help with the center console squeaking
    25C97ACF-6A76-4536-AE13-19CA29B1375A.jpg 2A3C1CC5-C8FF-48B8-AC31-E4ACC911D474.jpg
